Question about Sony Audio Players & Recorders
XDR-DS16iP how to Pre set Radio
How to preset radio
5 Suggested Answers
SOURCE: How do I reset the radio alarm preset on Timex (T307S) Clock Radio
if the radio alarm is still showing the nonexistent 98.5, you would need to reset the radio alarm. Press and hold button 1 (top left hand side) until the display starts blinking. Then press the preset button for 98.1. It should then display 98.1 on your radio alarm. good luck this is the most difficult set of instructions I've seen yet
Posted on Oct 02, 2007
SOURCE: presetting radio stations on my pioneer rx370 tuner
Using the tuning buttons, select your station. Then press memory, select the station call#, and then press memory once again.
Posted on Jan 27, 2008
SOURCE: Station preset on AWR1-1W bose radio
I found out you tune the radio to the station you want to preset, and hold the preset button (1-6) that you want to assign it to until it beeps. And it's set.
Posted on Jan 09, 2009
welcomejee
  • 10594 Answers
SOURCE: I have lost instructions
Please download required Instruction Manual from HERE.
Posted on Feb 03, 2009
The time does not automatically set on my sony alarm clock XDRC706DBP
Afraid I have the same problem and I have to manually set.
good luck !
Jul 07, 2014 | Sony Xdr-c706dbp Dab / Dab Digital Alarm...
Xdr-c706dbp time settings changes all the time
Yes - I'm in Sydney and the clock intermittently changes time to -11 hours which is GMT - it has always had this problem and I have never found a fix. HELP
Jan 08, 2014 | Sony Xdr-c706dbp Dab / Dab Digital Alarm...
My Sony radio XDR-S55DAB has completely stopped working. Initially all that showed on the display unit was the symbol for a dead battery but this also appeared when it was mains connected. I have pressed...
I have noticed exactly the same issue with my Sony XDR-S55DAB
Even if it has batteries installed but only working off mains electricity, after several months it will not start when the power button is pressed and I have to replace the batteries.
The radio will work again if you just replace the batteries with fresh ones
Try this next time the batteries go flat; disconnect the radio from the mains, replace the batteries with fresh ones, and leave for a couple of minutes (you do not have to switch on!).
You can remove the batteries if you like then reconnect the mains cable and press ON
If your radio behaves exactly the same as mine, it will spring into life so how come?
In the "olden days" ie pre-2000, small portable radios often had a physical switch which connected and disconnected the power supply be it battery or mains.
Nowadays, many radios don't have a "proper" switch, but a "function" button - press it on, and the radio operates, press it again and the radio stops - to enable this, a very small amount of charge is required to keep the central "brain" alive in order to notice this, and in the case of the Sony XDR-S55DAB, this only seems to be supplied by the battery, not the mains adapter.
My advice is simply keep a spare set of batteries handy and replace them whenever your radio wont turn on. Using the mains adapter allows the batteries to lastfar longer than using the batteries on their own.
It is completely counter-intuitive that a "battery/mains" radio needs batteries to work off the mains, but this is the only design fault can find in an otherwise excellent radio.
Aug 15, 2013 | Audio Players & Recorders
Chrysler 300 radio cannot pre-set tuned stations
If radio has save button then tune your station push save button then push a number on preset you want it saved to. The radio automatticlly stores the strongest station in your area.
Feb 20, 2013 | Chrysler Cars & Trucks
How do I set the clock & preset the stations. I bought the radio 5/4 /11 & there was no brochures or warrantee in box.
Setting the Clock 1. Press and hold the CLOCK button until the hour begins to flash 2. Use the left arrow and right arrow buttons to change the hour. 3. Press the CLOCK button again. Use the left arrow and right arrow buttons to change the minutes. 4. Press the CLOCK button again to save.
PRESET Stations the PRESET stations: 1. Tune to desired station. 2. Press and hold the PRESET button until the PRE-SET indicator on the display begins to flash 3. Use the left arrow and right arrow buttons to select the PRESET location for the station. Ten locations (0-9) are available. 4. Press the PRESET button to save the location. To tune a PRESET station: Press and release the PRESET button to step through the PRESET stations.
http://www.northerntool.com/downloads/manuals/142796.pdf
May 06, 2011 | Milwaukee Tool 49-24-0200 AM/FM Radio
I need to set the clock on a CD/cassette radio in a 1999 Ford E 450...also how do I set preset stations too?
Station Pre Set:
You can save 4 pre sets on this radio (1-4) tune the radio to the station you want to save then PUSH and HOLD one of the pre set butons until the sound returns, the station is saved to that pre set. Repeat for the 3 presets.
Clock:
Hour: Push and hold the CLK button and at the same time push the SEEK button to adjust. < decrease hours > increase hours.
Minute: Push and hold the CLK button and at the same time push the TUNE button the adjust. < decrease minutes > increase minutes.
Jul 14, 2010 | 1999 Ford Super Duty F 450
Can't set the radio stations
When you find a frequency that you
want to store in memory, press one of pre-
set tuning buttons 1through 6 and hold until the
preset number stops flashing.
The number you have pressed will flash in the
preset number indicator and then remain lit.
The selected radio station frequency has been
stored in memory.
The next time you press the same preset tun-
ing button the radio station frequency is re-
called from memory.
May 29, 2010 | Pioneer DEH-2800MP CD Player
Need operating manual for Zenith Model Z253W radio
1. Tune the radio to the frequency you want to preset, using the "Tuning/Set" buttons.
2. Press "Time Set" button to enter set mode. Note it says "Preset" below this button, because it is used to set both time set and presets.
3. Select the preset number you want, using the "Preset" buttons.
4. Press "Time Set" button again to exit set mode.
5. Repeat the above process for each preset.
Nov 15, 2008 | Zenith Audio Players & Recorders
'87 Honda Accord factory radio
Find radio station you want to program and then hold on which number you want it to be programmed to like preset 1-2 and so on, when you hold (1) for about 3-5 second you'll hear a beep then release preset button and its programmed to 1. Good Luck
Nov 15, 2008 | 1987 Honda Accord
How to pre set satitions
Your Sony is equiped for 5 AM presets and 15 FM presets.
1. Power your unit "ON".
2. Set the desired band - AM or FM.
3. Hold the "Mode" button down no more than one second. The "preset" indication just be gone.
4. Manually tune in the desired station you want to preset.
5. Hold "Enter" until preset indication re-appears. The number of the preset should be blinking.
6. Using the tuning buttons, change the the number to your desired "preset" number.
7. Push the "Enter" button to set the preset.
Remember, you can't have more than 5 AM presets (a mistake I made).
Phil20124
Jul 16, 2008 | Sony Walkman SRF-HM33 AM/FM Radio
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
