Question about Cell Phones
HAIPAI X710d not charging
Suddenly neither the original nor the spare battery are charging on mains or laptop via USB
5 Suggested Answers
muscularmod
  • 66 Answers
SOURCE: Battery charging via USB port
yes it will charge
Posted on Dec 08, 2007
SOURCE: not charging from mains
my samsung g 600 is not charging i think this is short please help me with diagram
Posted on Jun 01, 2010
  • 4 Answers
SOURCE: Omnia 2 charging problem
I have the same problem with mine, It charges fine when its turned off and plugged into the wall charger but dussnt recognize the charger when its on. kinda retarded. Could be a manufacturing fault thats coming up now =(.
Planning on sending it in coz its still covered under its warrenty. I suggest you do the same if yours is, otherwise u might just have to charge it from the usb port from now on... kinda dissapointing from samsung, thought they wouldve defntly got everything together after the original omnia failed so much
Posted on Sep 26, 2010
ashlocked
  • 1140 Answers
SOURCE: my 5230 nokia will not
* try to reset or restore the phone
* try to use another usb cable or charger
* use connector or charging pin is damage
* or theirs a problem with the components in the man board (better bring it to the service center)
Posted on May 29, 2011
How to charge the battery without a computer
A bit light on details, but any item that can be charged via a 5 volt USB socket in a computer can be charged by a 5 volt USB mains adapter.
usb mains charger Google Search
Aug 29, 2017 | The Computers & Internet
Why won't my camera turn on or charge?
Battery may have died suddenly, as they can ! If charging from mains lead , check fuse , if charging from USB lead , check lead, connection. Re set camera , or take battery out, then re insert and try again to charge battery
Jun 08, 2015 | Panasonic HX-WA10 HD Camcorder - Blue 16MP...
We have purchased a EPC mini-netbook 7". Suddenly we are unable to charge it either via the AC adaptor or from computer to computer via usb. What do you think the problem could be?
If you are able to use the power supply charger I will assume the laptop is usable. There are two possibilities, the main battery is bad and will not charge, or the charging circuits on the motherboard are faulty. Since this a new laptop it should be returned to rectify the situation.
Jan 14, 2011 | MSI Wind U100-016US Laptop
Hello. I live in Sarajevo. Bought U9 recently and have several problems. The main is that charged battery lasts very short time and it just turns off without any warning. I must say that the charger is not...
Get Motorola original battery and charger.
For USB charging you need to install drivers. Not sure our drivers posted on our site currently provide support for this old model though.
Mark
Motorola Support
Dec 08, 2010 | Motorola Mobility MOTO U9 Pink Cellular...
Thanks
Do you charge it from an outlet of via usb cord? If from an outlet, the charger just might not work anymore, but the usb cord that you use to put media on the mp3 player will charge it also.
Sep 06, 2008 | SanDisk Sansa e260 MP3 Player
Sony Ericsson K770i Phone won't turn on red light apears on the top left, any suggestions?
This has happened to me twice - the first instance occurred when I'd only had the phone a few days and the second occurred today after months of trouble-free use.
On both occasions the phone wouldn't charge via the mains charger - it wouldn't switch on even when plugged in and neither the battery or the charger were warm to the touch after hours of charging, indicating that nothing was happening.
The solution for me was to connect the phone to my PC via the USB cable - nothing happened at first, the PC didn't recognise the phone and it remained lifeless. However, I left it attached to my PC and after 10-15 minutes it suddenly whirred into life.
The battery was COMPLETELY flat despite my attempts at mains charging, so I let it charge via USB for a while then transferred it to the mains charger. This time the mains charger worked.
I've no idea why, but this has worked for me twice so give it a try.
Jun 07, 2008 | Cell Phones
Can I power my laptop through th usb port
I know you've either fixed your problem, or thrown the laptop out(still a "fix") but for posterity, and for anyone with a similar problem...
There are two answers, depending on your laptop.
First, NO, there is currently no way to charge your laptop battery by putting power into the usb port.
There ARE commercial external batteries. sadly, they will connect to your failing power-socket.(see http://www.laptop-battery.org/Power/External-Batteries/ENB003L.html)
If your laptop has a external battery charging dock, for spare batteries.... you could go that route.
you'd probably still want to follow the last suggestion.
GET IT FIXED!
Seriously... anyone with fairly good soldering skills can probably fix that powerjack. It probably pulled/pushed the traces off the main board and will require superglue, solder, and maybe a bit of fine wire, to fix. The biggest obstacle will be the dissassembly, and proper reassembly of the laptop case. It'll take a while, but once fixed, should return your laptop to 100% functionality.
I have saved 3-4 laptops with this technique. One, I even swapped the power jack to a more common size. This was to allow the use of a non-proprietary power brick(the original had fried itself).
Mar 22, 2008 | Computers & Internet
How to charge a psp with the USB
hi there
i actually have a friend who have a psp slim and he has this accesory(not actual accesory) thats like this.
http://crave.cnet.com/8301-1_105-9775502-1.html
if i could remeber when i tried it one time, it just prompts that the psp is charging.
hope this helps.
Feb 04, 2008 | Sony PlayStation Portable (PSP) Console
Cell Phones Logo
98 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
