Question about Eagle Air Tools & Compressors
Eagle river 5 gallon tanker air compressor - does not start, what do I check?
  • 1388 Answers
SOURCE: Air compressor head gasket diagram
Campbell hausfeld has all their manuals on line at www.chpower.com / you can enter the model # of the whole unit or just the # of the pump. Also you can enter just a partial number example wl650 for a list of models is that range. Use caution when installing gaskets for chpower oiless pumps. Some of their gaskets are very brittle. After installing parts, turn pump by hand to make sure all parts are in their proper place and that there is suction. Enjoy
Posted on Dec 02, 2008
  • 89 Answers
SOURCE: kobalt air compressor problem plastic tube gets a hole
EVERYONE WANTS TO MAKE EVERYTHING PLASTIC THESE DAYS. REMOVE PLASTIC LINE AND REPLACE WITH 1/4" FLEXIBLE COPPER ( ANY KIND ) JUST PICKUP A SMALL ROLL AT A HARDWARE STORE. MAKE SURE YOU GET A COUPLE OF FITTINGS, NUTS AND/OR FERRELS. HOPE THIS HELPS, JODY
Posted on Apr 20, 2009
  • 68 Answers
SOURCE: i have a electric air compressor craftsman 3.5hp
The pressure switch controls the cut-in and cut-out points for the motor. Some switches have a differential adjustment besides the pressure adjustment. The differential controls the spread between cut-in & cut-out, (say in at 80 PSI, out at100 PSI)
Try looking for these if you didn't get a manual.
Good luck
Posted on Apr 27, 2009
SOURCE: Campbell Hausfeld Air Compressor won't start
The compressor starting problem is common to most of the small portable compressors. Poor design and undersized components are to blame. If you have one of these units i suggest looking into a product called the Smart Start by Conrader Valves. It is interchangeable with the standard air filters and allows the compressor to start without fail. check it out- www.conrader.com.
Posted on Jul 23, 2009
compman66
  • 169 Answers
SOURCE: Hi, I bought a used Air Ace air compressor. 5 Peak
send me a photo of the compressor and if there are any model numbers or serial numbers and I will see if I can identify the pump for you. my e-mail is steve@morrismachineservicesllc.com
Posted on Jan 15, 2010
Testimonial: "I will get that info over the weekend and sent it to your e-mail Thanks"
What grade of oil do air compessors use
iso 32 // 30wt. compressor oil, or no additive mineral oil, never use automotive oil in a air compressor
May 06, 2014 | Eagle C5160v1 - Single Stage - 5hp 60...
5 gallon compressor tries to start then stops
it sounds like the unloader is not working so it's trying to start with to much head pressure. One cause is a bad check valve another is a bad pressure switch. Those are the more common problems.
Jan 04, 2013 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Motor heats up
It could have a bad motor start relay.
Jul 27, 2012 | Eagle C5160v1 - Single Stage - 5hp 60...
Locate pressure relief valve on c5160v1 eagle compressor
it is located on the 4 port manifold on the bottom of the pressure switch
Jul 05, 2012 | Eagle C5160v1 - Single Stage - 5hp 60...
Eagle iron horse 80 gallon tank 6.5 hp motor takes long time to pump up air seems like compressor is working overtime
long overdue for an answer. likely a split valve plate gasket or split interstage tube. cover the inlet filter on each cylinder with your hand. If good suction, it is ok. If it has low suction or is blowing hot air out, you have a valve or gasket problem.
Aug 02, 2011 | Eagle Air Tools & Compressors
I have an Eagle River compresoor it is 5 or six gal but put oil in it and ran for fifteen minutes like says turned it back on but blows air out bottom of tank out hole that has threads but has no valve or...
You are missing your discharge tap, or drain valve(there are several names for it. It is usually 1/4 or 1/8th national pipe thread. I would be shocked if you found a supplier for the exact Eagle River part because I just looked for 15 min and found nothing by way of a breakdown or parts list for any model. The good news is, once you determine the thread size, you can generally install any drain valve assuming there is clearance between the compressor in its resting position, and the floor.
In my shop I use RolAir because they are fairly cheap but work well. This is actually a Emglo part.
EMGDC18 DRAIN ****, BRASS, 1/8" 2.35 LIST COST
EMGDC14 DRAIN ****, BRASS, 1/4" 2.10 LIST COST
Follow this link for a Rol-Air dealer near you(type in your zip code) and they should be able to UPS out the one you need. I hope this helps.
http://www.rolair.net/ziplocator/index.html
Dec 05, 2010 | Eagle Air Tools & Compressors
Wont pressure up
Check drain plug on bottom of tank, check hose connections on top of tank.
Lugnut61
Jan 14, 2009 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Air Tools & Compressors Logo
64 people viewed this question
Top Eagle Air Tools & Compressors Experts
John Trevino
george parkes
Bill Boyd
Are you an Eagle Air Tool and Compressor Expert? Answer questions, earn points and help others
