I have toshiba high defination but no picture ther is a sound
    Problem Solver:
  • 5 Answers
Get a refund for it or get the techinians of the company
Posted on Jan 11, 2009
Sound no picture 56h80 toshiba
This set will blank the picture for several different reasons:
No filament voltage to the three tubes it uses.
No high voltage to the three tubes it uses.
No vertical or horizontal sweep (prevents all three tubes from having the screens burnt with a line.
Some of these can be tested but most require a schematic etc.
Set has several fuses and some do not look like fuses--called pico fuses.
Jun 11, 2012 | Toshiba Televison & Video
Had a lighting storm yesterday. Now have no picture or sound could it be as simple as a fuse?
Yes that can be just a fuse
;thers is 2 fuse in it/1 for ac line
and one for dc...
hope that help you
A.S. eletroniqu
Apr 08, 2010 | Toshiba TP50F90 TV
Rca hd52w59 making a high pitch buzzing sound
is this just a whine since you describe no problem with the picture it dosent jump or change color or flicker. there may be an easy fix this sounds like some coils oscillating and i tell you what can be done you can take some silcon and put on these coils to dampen then vibrations. now ther may be other problems but without looking this is my first gues ...where are these coils? ll037 on the power supply deflection board
Jun 17, 2009 | RCA HD52W59 HDTV Projection Television
Driver for Audio device on high defination audio bus, Intel motherboard
audio driver for high deffination
the mother board is foxconn 945 - cmx series
Jul 17, 2008 | Intel D102GGC2 Motherboard
Driver : sigmatel High definition Audio Codec
Hi, Yes its correct XP driver is not included in the Driver disk. I will give you link that will work With Windows XP well.
Here is the driver (Linked)
Please post if your question if you need further assistance
Good Luck
Jan 31, 2008 | Toshiba Qosmio F25-AV205 Notebook
There audio but no picture
I don't know how you connect the unit to the tv.
Let's just start on basic:
composite video/audio(yellow-video, white/red-audio) connect to TV composite video/audio input behind the TV.
If the audio works but no picture,try to use another video input behind the tv.if that still doesn't work,use a different video cable!
Jan 20, 2008 | Toshiba SD-V392 DVD Player/VCR
Initially No Picture when Turned on but sound normal and 5 minutes later Picture is all RED and then Picture becomes NORMAL (all normal colors)
theres a high voltage block that all three of the anode leads attach to and sometimes a small crack happens across this block and will not let some or all of the crt's get the high voltage all at once untill it heats up a bit. now if this is not your problem i would make sure that all three crt sockets are attached to there tubes all the way as maybe justy maybe there loose and will only work after ther expand a bit. Now another problem that could cause this problem to occor origially would be that someone left off a crt ground strap and the crt arched and popped and caused the problem with the High voltage block. And no I cant see a tube being bad then comming on at first UNLESS when you say the red comes on is the picture all red with small retrace lines(small white lines)in the screen with no picture except for red???? No video only a red blank screen is what i mean. If thats what its doing then yes Ive seen heater to cathode shorts on a picture tube that would cause this problem but to be sure your really gonna need to have the set looked at.. Good Luck
May 17, 2006 | Toshiba 40H80 40" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
