Question about Pride Go Chair Travel Power Chair
Led lights flash and Pride Go chair won't move.
At first the wife said the chair won't move. I thought it might need charging. I charged the batteries. When I turn on the chair the battery charge light goes on then off. The next thing that happens is the speed setting led will go left to right 4 times and then the lights go out completely. I have checked the drive levers to the extent that both levers are in locked position.
  • Anonymous May 25, 2009
    WHEN I TURN THE CHAIR ON THE CHAIR DOES NOT MOVE.THE LIGHTS FLASH FROM LEFT TO RIGHT.WHEEL LOCKS ARE ENGUAGED.
    Problem Solver:
  • 13 Answers
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
Posted on Feb 02, 2010
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
I'm borrowing a Jet 3 Ultra from the local Am. Legion for my Mom to use. They know nothing about it except they were told it had a new battery. I plug it in and all the LED's light up with the...
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Jun 25, 2011 | Pride Used Mobility Jet 3 Power Wheel...
I charged the batteries for 12 hours and then turned the chair on. The batteries appear to be bully charged, but the chair will not move. The joystick is flashing 8 times. Apparently a joystick fault? ...
There isn't too much you can do to fix this problem. You will have to have the joystick replaced. If Medicare paid for the chair then they will pay for most of the repair costs contact the provider that sold you your chair to have them order a joystick from Pride and repair the chair for you Hope this helps
May 04, 2011 | Pride Mobility Products Pride Jazzy 600
Chair was charged last night and now the power light flashes and chair will not move
NEW BATTERIES NEEDED TRY CHARGING CONSTANT FOR 16 HOUR IF POSS OR OVER NIGHT. IF BATTS KEEP FAILING THEN SERCH NEW BATTERIES ON THE WEB A PLACE IN WALES DO THEM NEXT DAY DELIVERY GOOD VALUE
Dec 24, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Wheel chair won't move. Batteries have been charging for several hours and have some charge but chair will not move.Any suggestions? Thanks
Romp, Did you check the freewheel levers chair will not move if you are in freewheel. Levers are in front next to seat posts and need to be facing forward. If you are not in freewheel then check the number of lights you have on on the joystick and that they aren't flashing. Also check that your speed control is not on the lowest setting even with some charge a slow speed setting will not let the chair move. Now by some charge you mean lights in the green on the joystick? If the lights aren't flashing then I'm kinda unsure other than even with some charge the batteries don't have enuf current to drive the motors and need to be replaced Hoe this helps
Aug 22, 2010 | Pride Mobility Products New Pride Mobility...
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Mar 31, 2009 | Pride Jazzy 1113 ATS Indoor Power...
The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Mar 12, 2009 | Jet Health & Beauty
Pride Go Chair Travel Power Chair Logo
873 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
