Question about Whirlpool Duet GHW9150P Front Load Washer
Erroe code F H
We are getting an error code flashing F then H
  • 8 more comments
  • ShanWit Jan 04, 2008
    I will get an error code of FH ( flashing) and the water flow will get slower until it stops. I trun the machine off and turn the dial to RINSE/DRAIN. All goes well. Put a new load in and no error code. I do alot of laundry and this has started happening about 2 times a day> Any suggestions?
  • KimRN Feb 12, 2008
    I also have the H and F error code. I do a ton of laundry--3 teenagers, sports uniforms and my husband and I both wear uniforms also. I love this washer when it works but it does seem to break down a lot.
  • good wash Feb 27, 2008
    had to move the machine worked fine before, now put in clothes starts to fill and turn but the machine keeps filling too much water then get the flashing f - h code
  • Anonymous Mar 26, 2008
    how do you get the filters out to clean them? i took the the hoses off hoe do i get the blue things off?so i can get nto the filter
  • jvanhoorn Jun 02, 2008
    Part way thru a wash cycle we get the F H error code. Checked the inlet screens, tried new hoses. The problem still persists. Sometimes it keeps pumping water in until it's 2/3 the way up the front door.
  • smittyme Jul 31, 2008
    I have the same prob H/F about half way though wash i checked the line filters but dont know how to get to the pump filter top check it.
  • blessedby3 Aug 16, 2008
    machine stops and flashes F H
  • denetclaw Aug 22, 2008
    The wash cycle starts and the F H error codes flash on and beeps continuously until I restart the cycle. The cycle does finish, but I'm hesitatnt to start another load until the problem is resolved. Is there a way to troubleshoot it without having to haul the appliance 45 miles to a service center?
  • jedicazador Oct 15, 2008
    I have the same problem, however on any setting my machine spins a few times then flashes the F H. No water is distributed into the machine. I have great water pressure the screens are clean. Still no water water into the unit and the F H any help would be great the dirty clothes are starting to pile up.
  • Anonymous Feb 05, 2009
    I have a Whirlpool Duet front-load waher and get the f..h flashing along with beeping about half way through the cycle.
    President:
  • 878 Answers
Jse, most of the time when I run into this problem it's because of the flow meter. This is a reed device that sits in line with the water inlet valve and monitors the water coming into the machine. Things to check; make sure both water valves are on and that the inlet valve screens are clean. (You get to them by removing the hoses to the washer). The drain pump filter is clean. (Remove the bottom panel and unscrew the pump filter and clean out). The inlet valves are actually working. That the drain hose is not too far down the standpipe causing a siphon. All the harness connecting to the inlet valves, pressure switch, drain pump, flow meter and main control are seated properly. You will have to remove the top to get a look at these. Three screws on the top backside and it slides of toward the back. If all these things check out. Then I would suspect the flow meter itself. Easy job. Catriver..
Posted on Jun 07, 2007
When adding a water softner to an older home the calcium flakes off the hot water side. It wrecks havoc with your filter screens. Every hot water outlet needs regular cleaning until the pipes clear.
This fix confirms that. Looked like a solid block of calcium when hose was removed.
Posted on Jan 07, 2008
Erro code e000086-0000
CANON IR 105 ERROR CODE E000086-0000
May 26, 2014 | Canon Imagerunner Ir 105 Copier Printer...
Last week canon R2018 showing erroe code E007, so we turned it off and on and it worked........for one week and has gone back to showing erroe code E007
u have to replace the fixing film of the fuser unit as this error is caused by that. so u have to get it replaced by a tech .
Sep 23, 2011 | Office Equipment & Supplies
Error on my ps3
google the erro code type ps3 erro code put erro code here_
Dec 15, 2009 | Sony Playstation 3 (PS3) Console
Error 01 0n epson dfx 9000
i have a problem on my printer epson dfx 9000 with erro code 01 turn off your priner any one with solution?
Aug 29, 2009 | Epson DFX-9000 Matrix Printer
Erro code SC541
Fuser error.
Fix problem (Fuse, lamp, or thermistor), then reset code by entering service mode and powering off/on machine
May 11, 2009 | Ricoh Aficio 450 Copier
Error message Oxd0620230, hp 5610 all-in-one, i have tried all the power resets. the cartridge stalls when the code comes up but it don't always stall in the same position. lights flash... also have the...
error message Oxd0620230, hp 5610 all-in-one, i have tried all the power resets. the cartridge stalls when the code comes up but it don't always stall in the same position. lights flash...
May 02, 2009 | Office Equipment & Supplies
Erro 5
Err 5 is the code shown when the flash isn't correctly released.  Try cleaning the area around the built in flash and make sure it can pop up freely
Jan 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Whirlpool Duet GHW9150P Front Load Washer Logo
1,479 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
