Question about Uniden BC350 Base Scanner
My bearcat scanner bc350a isn't picking up channels like it used to
I have had it for a couple of years, and its always worked but suddenly it isn't picking up any channels. Once in a while it will pick up the local channel, but nothing out of town like it used to. Have the frequencies changed?
3 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: Uniden Bearcat BC 350A scanner won't pick up 800 channels
You BC350A provides coverage of popular bands between 29 and 512MHz, so it is not capable of receiving signals in the 800MHz range. Sorry, but you'll need a different scanner to follow the action.
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
For information on current scanner models and their capabilities, visit:
www.ScannerMaster.com
Posted on Jan 02, 2010
Ironfist109
  • 3018 Answers
SOURCE: I have uniden bearcat ubc120xlt scanner ican not
  • Hi, I can help.
  • I would not say the scanner is worthless as it has many uses. But this scanner is not digital capable and any digital signals will not be received on this scanner.
  • You can still do plenty of listening on it though.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Aug 30, 2011
Tip
Sewing Machine Needles
Did you know sewing machine needles can be machined wrong? If your machine isn't picking up the thread, try replacing the needle. If the scarf isn't in the correct place, the hook can't pick up the thread.
on Mar 05, 2015 | Singer Sewing Machines
Does not pick up standard channels for recording let alone digital channels
Are you trying to pick up standard analog channels (the kinds that have a fuzzy gray screen when there's no signal)? Those stopped functioning in 2009 when the nation ended the analog broadcast. You can only get digital channels now, except for a low-power broadcast station here and there. Nowadays for analog, TVs mostly pick up only radio stations.
Jan 29, 2018 | LG Televison & Video
My Vizio LCD HDTV isn't pickup up all of the cable channels, but my other older TVs are?
Did you retry a working TV again on the same input, as it looks like a case of loose contacts in the RC Jack, cable or connectors or some strands of the cable touching the ground. Then check whether your Vizio TV supports the system/format of the cable. If your cable is licensed to be used only with the other TVs, like sensing the identity of the PC used, it could also be a problem
Aug 22, 2012 | Televison & Video
TV won't pick up channels 7-13
These are what once were VHF channels and are still mostly assigned to local stations.
You didn't mention the source for your received signals, if antenna, cable or satellite and it does make a difference as to the possible source of the problem.
If you are receiving via antenna, then the problem is within the set itself. If from one of the other two sources requiring a 'box,' then the problem is likely within the cable or satellite box that is between your incoming signal and the set.
Jul 29, 2012 | Magnavox 39" LCD 1080p HDTV 39MF412B -...
Hi i have the sv2000 with the built in dvd player. can you please help me i have no remote for it and i need it on channel 3. do you know how?
Take a look and see if this is the remote you need. If there isn't a channel button on the television itself that is working or a channel scan feature that you can access with the buttons on the television itself you will need the original remote. If you are able to get a channel scan going, make sure you have whatever you're connecting to the television all set up and running so that the scan will pick it up.
May 07, 2011 | Televison & Video
How to open Hitachi LS-1000-EMEA 1TB external drive ? Want to open the case but do not see any screws, maybe it is a "one-way-only" assembly, something like "click-in" and thus cannot be opened again ?
Get a couple of guitar picks. With the unit upside down, you will see a curved ridge above the power and USB sockets, use your thumb to apply pressure upwards to this ridge. This will allow you to push a guitar pick between the dull plastic lid and the shiny plastic case, this is so the lid can slide clear of the case. Next go to the front of the unit and wrestle the other pick into the curved leading edge between the lid and the case. When it's in, you should find the lid will rise up a couple of millimeters. Now PUSH the pick towards the back of the unit. For me, the lid flew off undamaged and I could now access the circuit board and drive.
Jan 10, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
Will not pick up FOX channel!
if you did get the channel you should be able to add in a digital amp (25db gain) and pull that channel back in
Jul 10, 2009 | Olevia LT32HVM 32 in. LCD Television
Problem with overheating.
Hi Dear. Always Pick n Place notebooks very carefully. When need to pick with both hands you can pick it in any direction but when need to pick with single hand, always use vertical position, without pressing and forcing any area. Place it on any flat surface where you are sure that exhaust system of CPU's fan is well ventilated. Heating problem may occure due to many reasons. Verify CPU fan function in BIOS, Clean CPU cooling fan and exhaust system with Electric Blower. NEVER use continuous charging, plug out charger wire when battry is 100% full, charg again when low battry alerts. This will increase battry life & backup time.
Apr 15, 2009 | Dell Inspiron 1525 Laptop
I have a radio shack pro 96 digital trucking scanner.the other day we finally put up my outside antenna for it.it worked fine all through xmas and new years.the other day turned it on and it would not pick...
The very part of your scanner that makes it a scanner is inop. YOU can find it but IT won't scan. Back to radio shack for warranty before they change their mind.
Jan 09, 2009 | Computers & Internet
Uniden BC350 Base Scanner Logo
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
