Question about Whirlpool Dryers
Whirlpool gas dryer super capacity imperial 6 cycle infinite temp isnt getting hot?
Illeagle
  • 525 Answers
SOURCE: Our dryer, described below, takes
Your complaint is:"Our dryer, described below, takes between 4 and 6 hours to dry, though it's advertised as "heavy duty" and "extra large capacity.""
White Kenmore 5.8 cu. ft. Super Capacity Gas Dryer
Sears item# 02690412000 Mfr. model# 90412
Based on the information provided above, I am unable to provide a positive solution to your issue. Your model number is incomplete! I have provided some common solutions to help guide you in your search. This information is for a non-specific brand model, gas dryer.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these:
Vent
Flame sensor/gas valve
Internal ductwork
Cycling thermostat
Lint Filter Vent: Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Also note that, to maximize drying efficiency, the vent should be as short as possible.
Flame sensor or gas valve coils: This is the most likely cause. Click links below. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3449&PPStack=1 http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3229&PPStack=1 There's a flame sensor near the igniter. If it's defective, the gas may shut off prematurely. Another common problem occurs when one of the electrical coils on the gas valve fails intermittently. If this happens, the flame shuts off before the thermostat sends a signal, which can greatly prolong the drying time. If the sensor or the coils are causing the flame to shut off, replace them.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 14, 2008
SOURCE: whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Posted on Feb 02, 2009
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool model number LGV7646ANO gas dyer will not heat up
Can you hear a click like always? If not then it has to be either the fuse, ignitor,or sensor. If you hear it clicking then the operator coils are dead. HERE is a link that shows pictures of these parts and locations.
Posted on Feb 09, 2009
  • 1144 Answers
SOURCE: whirlpool dryer not drying all the way
As a general rule, your symtoms indicate that there is a lack of heat. Causes?= Obstructed vent. This causes overheating of the elements and they go out on a safety to prevent them from burning up.
One or more elements not working. Burnt out, bad safety (not working like it was designed to do), control to elements has malfunctioned.
Overload of clothes is possible but not probable.
On a long shot, check the plug, recept., and breaker. You may have lost a "Leg" of power to the unit and this is causing a "Low Voltage" condition.
Hope this is of some help.
Posted on May 09, 2009
bozcro
  • 867 Answers
SOURCE: turns on but doesn't heat up
most likely heating element needs to be replaced.most can be accessed by removing back panel. also a thermostat switch may be faulty.
Posted on Aug 09, 2009
I have whirlpool duet gas dryer. It is leaving brownish moon shaped streaks on my white clothing. I have looked inside and cannot find anything that looks like it is causing this. Can you help?
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 15, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Dryer wont stay hot
Assuming you have removed the lower access panel (two or three scres all the way at the bottom of the lower front panel) to view the glow plug (ignitor), if you see the ignitor cycle on but the gas does not ignite after the machine initially heated in the beginning of the cycle you will want to replace your gas valve coils. They are the round black things mounted to the top of your gas valve.
This should solve your problem.
Good luck to you!!
Jul 13, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Turns on but doesn't heat up
Aug 09, 2009 | Dryers
My Whirlpool Imperial Series WGD5550SQ0 has low heat, does not start the way it used to. My wife has to alter the settings to make it work. What could be the problem?
The 'operating thermostat' is not working correctly. It should allow heating up to about 155 degrees F and then open for a short period and then re-close. This is the cycle during drying.
Jul 09, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryers Logo
94 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
