15-K67-011003 motherboard layout
Layout
apple_rom
  • 40 Answers
SOURCE: Processor Overheat
Biostar M5SIB is Socket7 motherboard and can support maximum upto AMD K6-III 500MHz (83MHz*6) - with patched BIOS. You can download BIOS Patcher at: http://rom.by/articles/BP/index_english.htm or use another already patched bios: http://home.hccnet.nl/j.steunebrink/M5sib_j2.zip Intel Pentium III has Slot1 or Socket370 CPU-connector and you can`t use it at your Socket7 (M5SIB) motherboard.
Posted on May 23, 2007
KatFishGR
  • 90 Answers
SOURCE: I want to get a layout diagram of the tyan s2507 motherboard
The manual for that motherboard is located here -
ftp://ftp.tyan.com/manuals/m_s2507S_100.pdf
You will need Reader installed in order to open the PDF document. If you don't have Reader, get it free from http://www.adobe.com
Posted on Oct 29, 2007
  • 12 Answers
SOURCE: i don't know the parts of the motherboard.
What motherboard would you like to know the layout of? Although, many motherboards are different, most of them have the same basic parts. From back to front, you have the communication ports; (usually from top to bottom, varies by manufacturer)mouse/keyboard, usb 1.0/1.1/2.0(make and model dependant) serial, paralell, vga/monitor, then sound: midi, headphone/speaker out, line out, microphone in.
then on the board, processor, somewhere near it, cache, i/o chip, north bride chip, wich is responsable for memory(ram) access, ide(cd rom/ hard drive access) ports and power connector/s,
memory slots
then the south bridge chip witch controls isa port(old), pci slot, agp/pci-e slot (video card) along with the cmos battery, bios, and various other slots/connectors (such as fan, power button and so on) and chips, wich vary by manufacturer and model.
Posted on Dec 27, 2007
  • 119 Answers
SOURCE: front panel pin layout. I need the front panel pin layout especially for the HD IDE active LED.
Howzit
Trial n Error is your best bet on the control pins panel there are two rows, with the power plugged in,with a screwdriver touch adjacent two pins together at a time starting with the top row then the bottom row, when you touch the right two pins your motherboard will power-up, then place the power-switch plug onto those two pins (the writing on the plug facing innwards toward the mainboard) the two pins for the reset switch and 99.9% of the time located directly next to the power switch or directly above the the power pins on the other row. For the LED lights you will have to just try the different pins and the Power LED will remain on as long as your mboard is on, but to find the LED pins for the Harddrive you will have to plug in your HDD and then when it powers up try the pins and the led for the HDD will flicker on-off, that would be the correct one. Dont worry your mboard will not be damaged by this in any way. Goodluck and let me know how you go. Thanks
Regards
Posted on Jan 31, 2008
map9966
  • 2351 Answers
SOURCE: pinning layout for Micro Star WS 6330 motherboard
Hi Hunter45,
Download the manual from MSI, click on the link below.
MSI K7T Pro MS-6330
You'll need winrar or winzip to uncompress the manual & you'll find there are 5, *.pdf files rather than just one for the hole manual.
http://global.msi.com.tw/index.php?func=searchresult&keywords=K7T+Pro&table=download
File name: 6330-1.PDF will show the MB layout. Page 1-4.
You ca see the 2 USB pins to the left of JMDM1.
JFP1 close up;
Open file 6330-2.pdf, page 2-22 for the pin layout for the MB USB's.
If you need more information, post here.
Good luck Hunter45!
Thank you for trying FixYa.
Mike
Posted on Jan 19, 2009
Front panel wireing layout for the P4P3 400 motherboard
www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=58206&
Nov 11, 2013 | Intel Computers & Internet
Searching for a motherboard wiring diagram on a lg optimus logic
If you are looking for a technical wiring schematic layout on ANY motherboard you aren't going to find it. Those are patented and not released by manufacturers. If you want only the layout of the motherboard, go to the manufacturers website and use their Support section to find yours. OR your computer manufacturer's website may have the manual for your model and that will have a layout diagram.
Sep 27, 2013 | LG 6871QCH083A Main Logic CTRL Board - In...
Hello can i connect 2 fans to the motherboard? 1 is at the rear,,can the other 1 go anywhere else with 3 pin connectivity??
Hi, this link will show you the manual to your Motherboard, Page 12 section 1.4 Motherboard Layout. this page will show the layout and you may need to zoom in to see it clearer, there is No.5 CPU Fan Connector (CPU_FAN1) next to the CPU slot and there only seems to be 1 more Fan connection No.15 Chassis Fan Connector (CHA_FAN1), this seems to be the only additional fan connection, normally you would connect a side door/panel fan, the rear fan connections direct to the PSU.
http://download.asrock.com/manual/775Dual-880Pro.pdf
Sep 17, 2010 | Asrock 775Dual-880 Pro Motherboard
SP283983 001 pin layout
You need to get the motherboard number and look it up at the manufacturer site under support you should be able to download a tech specs for that board showing the pin layout [owner manual may have it too.
Oct 31, 2009 | Computers & Internet
Pinning layout for Micro Star WS 6330 motherboard
Hi Hunter45,
MSI K7T Pro MS-6330
JFP1 close up;
Good luck Hunter45!
Mike
Jan 19, 2009 | MSI MS-6330 Motherboard
Where is the FP1 connector on the Foxconn 945G7MA-8KS2?
Hi Sean, FP1 front case connector is located below the battery, bottom right hand corner.
To download you're manual click on this link.
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=945G7MA-8KS2&TypeID=en-us0000001
Motherboard layout is on Pg. 5
Front Panel Connector: FP1
(Please refer to the 18th item of motherboard layout.)
This motherboard includes one connector for connecting
the front panel switch and LED indicators.
Close up of FP1 found on pg. 15
If I can be of more service, just post & let me know how thing go.
Enjoy!
Mike
Apr 29, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Pin layout for the Front Audio Connector
Hi HomeCPU, if you do not have a manual for the P4M9007MB-8RS2H motherboard than lick the link below & dowload it.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000243
Goto Pg.4- Front Audio Connector Board layout.
Than to Pg.13, Audio Connector: F_AUDIO detailed pic of pin loacations.
please vote...
Feb 22, 2008 | Foxconn P4M9007MB-8RS2H Motherboard
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
