Question about Gladiator Refrigerators
Gladiator GAFZ21XXRK00 compressor is running but freezer is not cooling and there is a leaking air noise from underneath freezer opposite side of compressor that lasts for about a minute when starting
The compressor is running but freezer is not cooling and there is a leaking air noise from underneath freezer opposite side of compressor that lasts for about a minute when starting freezer after it has been off for a few minutes.
  • 33 Answers
SOURCE: Kenmore frig will not cool
if compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
Posted on Jan 01, 2008
22yooper
  • 828 Answers
SOURCE: Fridge not cooling compressor works intermitently
If the compressor starts and runs for a few seconds it could be the relay. Or it could be the compressor itself has failed. When a compressor starts and runs for a short period it is possible that the relay contacts are arced together which would have both the start and run winding in the motor engaged at the same time for more than 3 seconds. This would result in the compressor tripping out on the thermal overload. It depends on what type of relay your compressor has. If it is a thermal relay, unplugging the refrigerator for about 15 minutes would allow the relay to cool off and reset.
Posted on May 10, 2008
  • 531 Answers
SOURCE: freezer not freezing/compressor not running
relay on compressor
Posted on Apr 06, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Posted on Apr 22, 2009
thutch6911
  • 15 Answers
SOURCE: Whirlpool side by side does not cool at all
Simple Fix. That's cost around $40. You need to replace your relay/overload. Its mounted on the compressor. It should have a black box over it. Take it off then pull the part off the compressor and replace it with a new one.
Posted on Jul 30, 2009
A/C Troubleshoot,Set up gauges on low and high side. Low side reading 200 high side 550. Compressor working fine. No visible leaks. Freon blowing out on opposite side of LP connect? Hot air in car.
Check to make sure that the engine cooling fan or fans are working. Sounds like there isn't any air flow through the condenser. Also it won't hurt to wash out the condenser and radiator.
Jun 14, 2017 | Cars & Trucks
Gladiator freezerator converted to regular frig 5 yrs ago but freezer is not getting cold enough. Also loud banging noise from the compressor during the winter months. thxs Mike
The first thing to investigate is the condenser coils to see if they are clean. If they are caked in dust and lint/dirt then they cannot shed the heat created when the compressor pressurizes the refrigerant gas. This is on the high (pressure) side of the system. the compressor pressurizes the gas and them it is cooled. Then it goes through an expansion valve resulting in the gas expanding and getting cold. this cold gas passes through coils inside the unit absorbing the eat inside and making the inside cold. So if the condenser coils are clogged up and cannot cool the gas then the machine will not work. the gas will return too hat to the compressor and it will be running really hot, perhaps knocking. Use a vacuum cleaner and a brush to remove the dust/dirt. lint etc. clogging the cooling fins and then see if the machine doesn't work better. after 5 years this sounds very likely to be the issue. It is quick and easy to do and costs you nothing. If it is not the problem then at least yu will not be paying a technician by the hour to try it first!
Dec 02, 2014 | Gladiator Refrigerators
Amana side by side freezer not cooling enought
With so little information all I can say is check to see if the coils underneath the refrigerator or in back behind the cover are blocked with lint or the fan is running that draws air across these coils and cools the compressor is running. Check to see if there is frost building up in the freezer on the back panel. If so then you have a defrost issue. This could be caused from a bad defrost timer control, a bad defrost heater or defrost thermostat. also check to see if the freezer fan is blowing. There could be a bad thermostat that controls the cooling it may be shutting off too soon. Check the door gaskets around the freezer and fresh food sections. If they are torn you could be losing cool air and drawing in warm air. There are so many things that could cause a poor cooling condition. All is usually fixable but the worst case scenario is a weak compressor. lets hope this is not the case.
I hope this helps.
May 25, 2014 | Jenn-Air JCD2389G Side by Side...
Our gladiator bottom freezer/refrigerator stopped working while we were on vacation last week. The motor still runs, but the air blowing out is not cold. We cleaned it out, unplugged it and plugged it in...
It is possible that your compressor has redduced in pumping or the gas pressure has redduced, ;leakage of gas. Sicne you had put off the fridge for sometime and tried again without any result, I think the compressor needs a good check. Since the fridge has to cool definately when the motor runs we must start from here . I hope you check this out or maybe get help to confirm definetely with an estimate. Good day.
Aug 02, 2010 | Gladiator GAFZ21XXMK Bottom Freezer...
Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2010 | Jenn-Air JCD2389G Side by Side...
Not cooling, fan making noise and now humming
Oct 27, 2009 | Admiral Refrigerators
Side by side, refrigerator works, but freezer does not The freezer just started thawing everything. We can still hear something running in the refrigerator.
This is unusual. The more common set of circumstances is that the freezer works but the refrigerator doesn't. The cold air in a side-by-side is produced on the freezer side and is than transferred throughout the freezer and to the refrigerator by a fan in the freezer.
You say you hear something running in the refrigerator. This could be the freezer fan. It is located behind an access panel in the freezer. This fan should run.
You should also hear the compressor (underneath the refrigerator) running. If this doesn't run, you will not get cooling. Also, there should be a compressor fan (underneath the refrigerator close to the compressor) running. This fan removes heat from the refrigerant coils and transfers the heat to the outside. If this fan doesn't run, proper cooling cannot be obtained.
Check these things out.
Oct 20, 2009 | Refrigerators
Won't freeze on freezer side ( defrosting) and won't get cold on refridgerator side
If you have confirmed that the unit is defrosting and the freezer isn't getting cold. Make sure underneath the refrigerator is completely clean and the fan is running underneath the refrigerator next to the coils. If this all checks out then you have a bad compressor or lost of refrigerant due to a leak in the system. One last thing: Is the cooling fan running in the freezer?
Oct 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Gladiator ref is not cooling properly
Check to see if there is cold air coming from the freezer to the refridgerator side through the vent holes The compressor maybe getting weak or the freon charge maybe low. Does the unit run a long time before it shuts off? 50 degrees is not cold enough for a freezer. You should be around 32 or less.
John
Sep 28, 2009 | Gladiator Freezer GAFZ21XXRK
Whirlpool Gladiator Freezerator not cold
Just had the same problem on my Freezerator, the compressor would cycle on for a few seconds and then off for about 5-10 minutes. No cooling. Replaced the overload sw and the start capacitor and system running cold and tru. Beer cold again, 0deg in freezer. Parts are available on the web, P/n 2169373 for the capacitor and 213615000 for the switch and housing...may be different # for the sw....PTM
Jul 15, 2009 | Whirlpool Freezers
Refrigerators Logo
26 people viewed this question
Top Gladiator Refrigerators Experts
christian nielsen
Brian Coughlan
Charlotte Sharp
Charlotte Sharp
Are you a Gladiator Refrigerator Expert? Answer questions, earn points and help others
