Question about Kenmore 94812 Top Load Stacked Washer / Dryer
DOES NOT DRAIN WATER
HI I HAVE A KENMORE 41794812301 WASER/DRYER WASHER DOSE NOT DRAIN ANY WATER IT GOES TO SPIN CYCLE BUT DOSE NOT DRAIN ANY WATER. I CLEAN ALL HOSES .IS IT PUMP OR SWITCH HOW I CAN FIND OUT .CAM I JUST DO A SIMPLE OHM TEST ON MY LID SWICH FIRST ???? PLEASE HELP ME THANK YOU LUKAS
  • Garyann Feb 06, 2008
    My Stack washer/dryer is model # 417-99872990, It will not drain water while in the regular or wash & wear cycles, but will drain while in the delicate cycle. It spins but does not drain.
  • HJHHENRY Jun 23, 2008
    Frigidaire front load Gallery washer goes through cycle but does not pump out water of spin. When water is removed it will spin.
  • 87 Answers
If motor runs or sounds like it is trying to run, you have a sock caught in the pump. If no noise at all you have a bad lid switch
Posted on Jun 08, 2007
Washer won't spin. Motor goes thru cycle but not spinning
My kenmore washer won't spin - EASY FIX (PART ONE ...
? 5:45
www.youtube.com/watch?v=fRxKs2EEfbU
Feb 1, 2013 - Uploaded by Michael Borders My Kenmore washer's agitator stopped spinning my cloths during the wash. NO BIG DEAL!!!! EASY and ...
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - If your old or new washing machine does not spin we have some diy fix tips ... Fix Washing Machine That Won't Drain - Washer Not Draining ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Nov 02, 2015 | GE GTWN4250MWS 27" top-load washer with...
Dryer spins but no heat
Conventional dryers are usually accessed by removing the rear panel. I would think these would be the same. Unplug the dryer and remove wires from heating element. Test for continuity with an ohmmeter. If there is no reading, the heating element is bad. Disconnect wires from the hi temp thermostat and test with an ohmmeter and if no reading it is bad. Sears has these parts available.
Nov 07, 2013 | Kenmore Dryers
Kenmore model 970c44102 front load will not drain while spinning
sound's like the water pump is going out I got a old washer and it dose the same
Sep 15, 2012 | Kenmore 98702 Stacked Washer/Dryer
The water is not spinning out. the water is pouring out onto the floor when the spin cycle starts. not leaking when in wash cycle
You may have a pump that's bad. When it goes into spin cycle it assumes the water will be drained within a period of time before it goes into high speed spin. If it goes into high speed spin and the pump hasn't done it's job then you will get a bad mess, flood, water all over.
Rich
Western Appliance Repair
Appliance Repair Meridian
Oct 09, 2010 | Kenmore 9380x Top Load Stacked Washer /...
Kenmore dryer works kinda on timed cycle does not work n the automated one kenmore washer also will not spin or drain all the water out of the clothes we just moved so we cleaned it all the hoses and
sound like you have more then one problem
to the drain
http://www.youtube.com/watch?v=Qa6OsgJqLmc&feature=channel
how to unplug the drain
http://www.youtube.com/watch?v=nr6tIO5iNSc
every 2 month is recommend to do the following
http://www.youtube.com/watch?v=2uHyLMWmymM&NR=1
Hope this helpful?
May 12, 2009 | Kenmore 84072 Electric Dryer
My washer will not go to spin cycle,.
Hi my name is joyce,
first lets try to get the water out of washer, put on drain cycle, after it drains water out take clothes out of washer, then lets see if it will run on spin cycle, it may have to many clothes, if this does not help then you have a transmission problem, this will defenently need a technichan to look at it. if you need I can look in you area and see if I can find you some assistance.
Joyce
Feb 06, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable kenmore model 41794702300
We have had that happen too. You will need to take out what ever has blocked the valve on the drain. Ours was a bobby pin! My model is a bit different but if you follow the drain hose underneath you can find it. Remember you are dealing with lots of water. I think I scooped out the water first and have some towels ready. Or hire somebody to do it for you. I hope that helps.
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 94812 Top Load Stacked Washer / Dryer Logo
132 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
