Question about Behringer XENYX 802 Mixer
How do i connect my mbox 2 mini to behringer xenyx 802 mixer?
  • 5603 Answers
SOURCE: Behringer Xenyx 1622FX. Power supply has failed,
Suspect a broken circuit trace or broken solder. If they use a 7805 three terminal regulator, check the solder around those pins...
Berhinger does NOT release schematics except to their service facilities... I know... I have tried... I repaair a lot of their stuff and have to trace out the circuits.
Power supply circuits are rather easy except for the switching regulators if they have failed totally.
If only the +5 is dead, you should be only a filter cap and a diode or two away from the problem... Transformer leads and electrolytic leads with their weight are favorite to pull out of solder... On Behringer, often the traces are narrow and can have a crack in them.
Posted on Jan 13, 2010
  • 5603 Answers
SOURCE: Connect xenyx 2442fx to computer
If you want to record in stereo, the quick and dirty way is to get a 1/4 inch stereo to 1/8 inch plug cable and go frrom the headphone output jack. (Use a Wye connector if you need to listen on the phones)
All the other outs are TRS and XLR balanced and the computer audio (mic) inputs are unbalanced. You would need special cables to connect those.
Posted on Feb 08, 2010
technical114
  • 1851 Answers
SOURCE: whow i connect my xenyx 1002 mixer to audiophil 2496 sound card
You must connect:
the main out of the 1002, or the ctrl room out of the 1002 at your power amplifier's input.
the line in 9/10 of the 1002 at your 2496's line out.
the cd/tape out of the 1002 at your 2496's line in.
in case of a cd connect it's line out at line in 3/4, or line in 7/8 of 1002
some mic at the mic 1 or mic 2 of 1002.
That's the way you're going to have control for:
the mic level from channel 1 or 2.
cd level from channel 3/4 or 7/8.
pc playback from channel 9/10.
master speakers from main mix or ctrl room.
All the above connections are not absolute and may vary depending on your needs.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Posted on Feb 24, 2010
SOURCE: Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Posted on Mar 24, 2010
  • 5603 Answers
SOURCE: Behringer XENYX 1622FX, won't power on. Phantom power works(?)
After reviewing the schematic, I don't understand how the Phantom power can REMAIN on with the power switch off... this CANNOT occur except for what energy is left in the 48 volt supply filter cap... This might last for minutes after the fuse went... UNLESS you have devices connected which are backfeeding the 48 volts. (which would be a disaster)
The 48 volts, +/- 12 volts and +/- 15 volts and the +5 volts ALL come from the SAME switching power supply. I suspect one of the filter caps went or the primary switching regulator a TDP245Y chip.
You should ONLY work on the line side of this using an ISOLATION transformer since the line side has lethal voltages.
To do testing, one replaces the fuse and puts a 60 Watt light bulb in series with the hot side of the inout line. The lamp "acts" as a resetable fuse and limits the current for testing. When all is well again, the lamp will remain out with the power flowing through it.
The D1 diode bridge and C7 input rectifier and filter are first things to check. You can do those with an ohmmeter.
I will caution you to ALWAYS power any and all equipment from the SAME power source. Plugging in devices from across the room will set up ground loops and any ground fault will fry equipment.
Posted on Apr 05, 2010
I got behringer 802 audio mixer and a mic..what else do i need to start singing..
Please verify if your computer has a sound card. You will need a provision on your computer for audio input. Let me know.
Dec 26, 2014 | Behringer XENYX 802 Mixer
Please can you tell me the difference?
The microphone preamps are different. The Xenyx has lower noise mic preamps.
Nov 04, 2013 | Behringer Eurorack Ub802 - Ultra Low-Noise...
My behringer xenyx 802 premium 8-input mixer worked fine for 1 day but now it sounds watery and behringer support was no help at all
Sounds like it may have failed. Yes, it is likely that it needs to be returned. Another option is to unplug all inputs and outputs. Plug in ONE device into the board, and use the headphone jack on the board. Does it sound the same? Just basic troubleshooting may help.
Oct 02, 2012 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
How can i connect a Behringer xenyx 802 mixer to a Fisher TAD 9315
What you've done should have worked on the video input. The phono will not sound like you'd want. Have you made sure the mixer is working correctly by trying it plugged into a different amp using the same outputs and cable?
Mar 14, 2017 | Music
I'm looking to run 5 live instruments through the behringer xenyx 802, is this possible? Would the split channels force the instruments to pan? Any help would be much appreciated?
You could use the Left inout of one of the stereo channels. You can pan it with the balance control as needed... HOWEVER remember these are LINE LEVEL signal levels into the stereo jacks... so if you are using instruments with low output you MIGHT have to use a preamp to go into these jacks. Try it... nothing ventured, nothing gained. Using a keyboard into these jacks would NOT be a problem.
Sep 01, 2011 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
Hi all i own a behringer XENYX 802 audio mixer. this device is powered by a power supply that as input to the mixer gives 18,5 x2 Ac, 150ma. i would like to know in which point of the circuit i can...
You would need TWO DC supplies as they use AC so they can create both a plus and minus 15 volt power source to run the internal op amps.
Here is a schematic for the 1202 which has same power supply configuration as the 802.
http://elektrotanya.com/behringer_xenyx_1202.pdf/download.html
Scroll down to the little link "Get Manual" and download the service manual and schematic. You will find the power input in the upper left corner of page 5.
Mar 29, 2011 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
How can i setup mu xenyx 802 with my pc? i also hve fca202...
You can do it one of two ways when coupled with the FCA202. First, You can just come out of the main outs on the 802 via 1/4 in to the 202s 1/L in and 2/R in. Second, you could do two separate channels (ie. Vocal channel and Guitar Channel) using the L/R out on the 802. Use the pan knob to send the instrument to the selected channel. So, If your Guitar is on channel 1 pan hard left and you will only get it out of the left channel sending to channel 1 of the 202, and your vocal is in channel 2 pan hard right and you will only get it out of the left channel sending to channel 2 on the 202. Good Luck, Cody J.
Dec 17, 2010 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
I have a compaq v2000 and what Im tryin to do is conect my Mbox mini and the Xenyx 1002 to the laptop is that posible ? how can I do that ?
Should be possible. For system safety electronically, power ALL interconnected equipment from the same receptacle/plug strip. Use Balanced lines, either XLR or TRS wherever possible.
Dec 15, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Is there a reset button on my 802?
I do not remember if the powersupply is external or not either way there is no reset button the powersupply may not be putting out any voltage.
Dec 01, 2010 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
I have a behringer xynyx 1204,and a protools personal studio,with mbox2 mini,and im just wondering if its possible to plug the mic into the mixer,instead of the mbox,and still be able to record vocals into...
It is possible, you can simply put a Y-cable for Mic or a splitter for the mbox and the Mic. You can plug the mic directly to the mixer then the other jack on the splitter connected to the mbox.
Jul 25, 2009 | Behringer Music
Behringer XENYX 802 Mixer Logo
70 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
