Question about Panasonic SC-HT40 System
I have an old Panasonic SA-HT40 surround sound system. When the unit is powered on the error message "F76" shows on the display and then the unit shuts off immediately. The user manual instructs to un
Panasonic Error message F76
    New Friend:
I have the same problem with my Panasonic model SAHT-40. I get the same code plus popping and shortly reads maximum overload then cuts off. I disassembled my unit and discovered that my fan fails 2 work causing the unit it over heat. I called Panasonic 2 place an order 4 a cooling fan. This model is obsolete they dont even manufacture parts 4 this unit anymore. The closest that I can get with my credit card is Samsung model AH31-00056B cooling fan through Panasonic. I hope that this solution helps all of u out with ur unit!
Posted on Jun 13, 2017
  • 4234 Answers
SOURCE: Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Posted on May 15, 2008
SOURCE: SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
Posted on Apr 14, 2009
  • 5 Answers
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Posted on Jun 22, 2009
  • 374 Answers
SOURCE: panasonic surround sound system model # sa-ht95
Error code ' F61 ' on most Panasonic models indicate that the built-in diagnostics has sensed a fault at the output stage. This would normally refer to a failed output amplifier IC (?P/N RSN704D66P?). In some instances, the fault could also be triggered by:
  • strands of Speaker wires inadvertently touching each other;
  • faulty speakers;
  • failed Cooling Fan of the output IC.
Options then are:
  • consider a DIY (do-it-yourself) repair only if familiar with electronic components & circuitry, use of a DVM/VOM and a soldering iron. Access to a Service manual would be an advanatge;
  • seek the services of an authorized service center specially if the unit is still under warranty;
  • consider other options based on downtime, cost of repair, parts of availability, age of unit and prices of comparable but newer models.
Good luck
Posted on Mar 06, 2010
  • 189 Answers
SOURCE: Error F61 on Panasonic Stereo System SA-AK80
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
Posted on May 12, 2010
I have a panasonic SC PT960 system. Haven't used in months. Turned on,got error code F76. Tried unplugging and plugging back in to reset, but it did not work. What is wrong with my system?
"F76" is a power supply problem. Could be something really simple or something much harder to figure out. These units aren't really user serviceable and it's way too old to still be in warranty(?) so maybe you've been whapped with a subtle hint to upgrade to a blu-ray HT system. You'd be able to keep the rest of the system and just replace the head unit.
Jan 02, 2017 | Panasonic Audio Players & Recorders
Panasonic sa-pt770 will not power on
When power is applied do you get any LED light or display that shows?
Dec 27, 2014 | Panasonic Sa-pt770 Receiver
Sa-100bt i have an f76 error after taking unit apart i have found that there is a black wire next to where the fan plugs in this wire has been disconected does any one know where it goes thanks
Usually that is just to wrap around the fan cable to make sure it doesn't go into the fan. F76 error can be either the fan is not turning, or the amp is bad.
Apr 16, 2013 | Panasonic sa-ht930 Home Theater Audio...
Hi i have a Panasonic surround sound model SBWA15 which is about 5 years old. The machine switches off and displays 'F76' in the display screen. i took it to a repair shop and they say the outputter has...
I have PANASONIC MODEL NO. SB-WA15, the radio works but when i try to work it witht he t.v. it does not come through the speakers. what do i do? i need help before the superbowl tonight!
Aug 05, 2010 | Panasonic SC-HT17 System
When i turn my sa-ht40 on it says power overload
i have also the same problem with a panasoni SA-HT40. when i turn it on I see on the display OVERLOADED, and then thue unit turns off.
please help me
Jan 13, 2010 | Panasonic SC-HT40 System
Fault code for sa ht 17
Hi,F76 is the error displayed when the fan goes faulty in the unit.
Aug 11, 2009 | Panasonic SC-HT17 System
Error Code "F76"
spoke to a friend at an authorized servicer and he said he has never heard of that code but from what yourm describing its eather the outputs the speakers or the power supply Oh and a sevice manual is availiable at the or from the panasonic web site as I've been there. good luck
Apr 10, 2006 | Panasonic SC-PM08 Shelf System
Panasonic SC-HT40 System Logo
302 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
