Question about Garmin Nuvi 350 Car GPS Receiver
Not charging. Placed the Garmin Nuvi 300 in the glove box with the USB plug in. When closing pressure was placed on the plug bending the internal connection attached to the PCB. Would like information on how to open case. I am in Australia. I have plenty of experience in electronics. Thank you in advance.
  • danrw Jan 14, 2009
    There was no solution offered. What I needed was to disassemble my unit. The onlyadvice was that I needed special tools & send it to an authorised dealer such as yourself. The other advice I was seeking was how to align the ribbon connecting the PCB to the touch screen as there is not much length. No advice was forthcoming.
    Regards Dan Woods
I removed the plate cover on the aerial, then slid the hinge pin to the right to release the aerial holder then removed the two fixing screws from the top of the unit that had been obscured by the aerial receiver. I then removed the PCB fixing screw to access the PCB & re-soldered the mini-USB plug to the outside rail.I did get side tracked after that so will re-assemble today. Wonderring which is the best method of aligning tapes from touch screen to PCB as you would be aware there is not much length.
Regards Danrw
Posted on Jan 11, 2009
My garmin in nuvi 1350 will not charge it keeps saying the battery is low
Nuvi 1350 charges in 4 to 8 hours. If your Nuvi is not accepting a charge, you may have a loose or bad USB cable. Note that the Nuvi can be charged with a phone charger. Charging it with a connection to a computer moves charging time toward 8 hours and more towards infinity if you don't have the driver installed on the computer. Turn the Garmin off. If the driver ins installed in the coputer, plug the Garmin into the computer and then hold down the power button on the Garmin for 30 seconds.
Sep 10, 2017 | Garmin GPS
Garmin nuvi 215 is not detecting secondary map which I have placed on sd card. What is the solution?
The map must be named "gmapsupp.img" on the SD card and not "gmapprom.img" like on the internal memory of the unit.
Sep 12, 2013 | Garmin nuvi 215 GPS Receiver
Brand new Garmin Nuvi 1490 T out of the box. How do I charge it? The only devices in box were a car charger (my commute is 5 minutes daily) and a USB connector? Should I just plug the USB into my computer?...
Garmin satnavs come with a charge out of the box.
In some cases your device may have lost a charge during shelf life. In this case you can charge these units in three ways:
  1. Place unit on computer with USB cable for approximately 8-12 hours
  2. Place unit on Garmin specified AC adaptor for approximately 4-6 hours
  3. Place unit on 12V vehicle adaptor for approximately 4-6 hours.
Some cars continue to supply power to the cigarette lighter socket when turned off and others don't. If yours doesn't you can charge it from your computer. There's no indicator to show that it's charging or when it's charged. However when you disconnect the satnav from the computer and turn it on there's a battery state indicator which shows if it's fully charged or not.
Aug 16, 2010 | Garmin nuvi 1490T GPS Receiver
How long does it take to charge up we just bought a new one and it was plugged in the car for 2 hrs and only lasted about 2 hrs
Garmin satnavs come with a charge out of the box. In most instances you will not need to charge before using. Your device will charge while attached to your 12V vehicle power cable.
Your device should be fully charged after applying one of the steps from above.
Aug 09, 2010 | Garmin nuvi 250W GPS Receiver
Garmin will not come on. Hasn't been plugged in for a month.
Given that you've tried other chragers, it seems likely the problem is battery related - especially if you've already tried steve's suggestion. How old is your nuvi? It is not uncommon for GPS batteries to go down after a year or two as they are subjected to temperature extremes and repeated charges and discharges. If the battery is the problem, it makes more sense to replace it for $30 than to spend another $300 on a new GPS. This can be done easily enough:
The company that produced the video sells a kit which includes the battery and tools necessary to do this yourself if you'd like. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+205W&Show=ExtInfo
I hope this helps. Happy travels!
Best,
Rob
Jul 07, 2010 | Garmin nuvi 205W GPS Receiver
Hello, My Garmin 260 ran out of battery 3 months ago. I did not attempt to recharge it until two weeks ago. i used a usb cable and plugged it into my computer overnight. It still did not charge... what...
http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+260&Show=ExtInfo&gclid=CLzv0pac46ECFQQTawodklsxIg.
This place has the battery and tools come with it!. its super easy and way cheaper than buying a new garmin. 2 screws and unplug the old battery and plug in the new. I did mine and I never messed with the internals before.
May 03, 2010 | Garmin nuvi 260W GPS Receiver
I left my garmin 205 in my glove box of my truck for the week after charging it for about a day n now i go to use it almost a week later i plug it into the cord plugged into the cigarette lighter it...
  • Please try to call the Garmin Technical support and then check if the device is still under warranty so that they can replace it.
  • You can also try if they have any promo on going so that you can take advantage of the promo.
Mar 28, 2010 | Garmin nuvi 205W GPS Receiver
My Garmin Nuvi 300/350(2 years old) comes on and
I solved the problem by charging internal battery using the 120V. charger that came with the unit. I was not aware, that the cord in car was not charging my Nuvi and that it was running OK. until the battery was low and quit. I have to check this cord. Peter W.
Oct 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 260w no power.
Yes, you need to charge it. USE the charger that came with it for best results. Some off brand chargers will NOT work.
You plugged it into your car and nothing? Even if the batteries are bad it should still work. Is it the Garmin charger?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
  1. Unscrew and remove the silver or black, round end piece.
  1. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  2. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
113 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
