Question about Refrigerators
Beaba Babycook motor dead?
Is there a way to fix a small appliance that won't turn on? I've been through 2 Beaba Babycooks that are less than 2 years old and they won't turn on when plugged in. It has worked before and stopped for no apparent reason. Regular maintenance has been done on the machine (cleaning and monthly descaling). Are there any parts we can purchase to fix it?
  • 65 Answers
SOURCE: Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Posted on Feb 16, 2008
  • 27 Answers
is the ice collection bin in the correct position? Is the icon displayed on the control panel to indicate the ice maker is on?
I hope this helps,
Posted on Oct 25, 2008
  • 42 Answers
SOURCE: Fridge freezer has stopped working
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Posted on Jul 02, 2009
protek480
  • 1714 Answers
SOURCE: The heat on our 2 year old Cabrio dryer just
Thermostat controls heat. There is also a motor centrifugal switch, in the element circuit, that the motor closes to insure the motor is turning. Try another heat setting. There is more than one thermostat. You may have blown the 'thermal fuse' too, which requires replacement.
It is possible that your element has failed also.
Tripped high limit. Must clean the lint filter and the exhaust vent tube and all the way in to the dryer. Hot air exit is restricted.
Posted on Jul 18, 2009
SOURCE: coffee grinder not working
My burr grinder also stops if the ground spout (where the coffee shoots out) is clogged. I use my grinder for an espresso machine so i always have the setting on the finest and so with the oils and the fine grind it clogs this spout pretty often. I"d check yours out too (ie remove the coffee ground bin and you can see the spout. If it is clogged uplug the machine and take a tooth pick and un clogg it. Don't jam the tooth pick in there to deep you don't want it to get shuved into the grinder wheels.
Posted on Feb 07, 2010
I have a 1986 nissan 300zx and I have a headlight problem. The right headlight raises up like normal when I turn the light on but the left one won't raise up. I have to do it manually. A couple of...
Check wiring to motor and it should read around 12v. (digital multimeter) unplug motor and check resistance at motor. It should read something and if not the motor is dead.
May 23, 2017 | Cars & Trucks
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
The speed lever on my KSM 90 won't lock in the off position.
Do you have a manual? You can download one from Kitchen Aid, small appliances. There should be a schematic and how to that will help.
Dec 16, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Jul 08, 2012 | Electric Razor Pocket Rocket Ride-on...
My motorola triumph won't send pictures mms
Check your APN settings
http://www.virginmobile.co.za/support/support-category/general-services/gprs-settings-and-usage/gprs-and-mms-settings-for-android-phones/
different locations you go sometimes have dead spots so less signal wont send mms. you can also connect to your home/public wifi to send mms,
May 03, 2017 | Motorola Mobility Triumph
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
