Question about Powerwasher 2400psi 2.0gpm Pw2420 Gas Powered Pressure Washer 4
PW2420 will not start
Used it once 3 months ago & now it will not start-do change spark plug or something -it's less than 1 y/o
1996 jeep grand Cherokee will turn over but not start. weak spark. fuel at fuel rail. replaced PCM 1 month ago. replaced crank shaft sensor 3 months ago....
See if your getting spark at the ign. coil first (passengers side on that year) if you are change the crank shaft sensor making sure you mount it as close to the engine as possible so it never gives you trouble again.
Aug 20, 2013 | 1996 Jeep Grand Cherokee
I bought a used 1995 for escort. it has a miss an is getting worse. i changed the spark plugs. i took the spark plug wires off one at a time. 3 of them made the miss worse and 1 did nothing. it's
Not without more testing.
It could be a fuel problem or something mechanical like a valve.
You would do a compression test next to verify all 4 cylinders have normal compression.
If they do, and that 4th plug wire was providing spark to the plug, I would expect you to find something going on with the injector.
Feb 25, 2013 | 1998 Ford Escort
Oil on plugs that burn white smoke
I would`nt be too worried about the oil on spark plug threads be more concerned about white smoke! it sounds like head gasket problems.Good-luck.......
Jan 05, 2013 | 1997 Oldsmobile Aurora
Last time used 18 months ago, ran good, no problems. Tried to start it and it won't go...So I checked oil level..(good) removed the fuel bowl replaced old fuel with new fuel all looks well and cle
heat the spark plug for a few minutes then put back in the engine. sometimes works when you not used engine in a long time. it will take a good few goes to get the old fuel out of the carb, the heat helps burn old fuel.
Jul 09, 2017 | Motorcycles
1999 chevy k2500. changed spark plugs 4 times in 7 months. Runs good for a week then doesn't start. Changed spider, throttle body sensor. Still has no codes and once again won't start.
The next time it won't start ,pull a sparkplug wire and see if you're getting fire.Then we'll known whether its a ignition or fuel problem and go from there.
Jan 11, 2012 | 1999 Chevrolet K2500
I have a 84 ford f150 4.9 it was starting fine & running smooth. I didn't start it for about 3 months, tried to start it 3 days ago and it wouldn't start it's getting gas. I had the co
Verify if there is spark or not when cranking the engine over. If not, could be the pickup coil inside the distributor-this is what tells the control module what position the crankshaft is in, for delivering spark at the right time.
Oct 15, 2017 | 1984 Ford F 150
I have a 2002 merc mountianeer 104k miles. I bought it 1 month ago before reading about all the problems they have. The issue that Im haveing only happens when the car is somwhat cold. I start the car go...
When you don't know what to do & you never
work on your own vehicles,I would hope you have
a local repair shop you found & stayed with for 20
years,instead of hopping around to different places
as most people do.
You are correct & did make a mistake by not reseaching
vehicle problem & recalls.
The Ford Version is better
I could write a book on any number of issues,but you
still have to go through the entire vehicle once you buy it
You never buy any vehicle ,even a new one ,without working
on it.
You need to change spark plugs,all fluids ,etc
Anything less than laying it up for a couple of weeks
won't do the job.
Very,very few people do anything but drive a vehicle &
maybe change the oil once a year
You hear what good care they take,but in reality have no idea
what to ask a repair shop or any idea what so ever what is done there
Aug 02, 2011 | 2002 Mercury Mountaineer
What is the proper storage for a Briggs and Stratton power washer model #020443 ?
If it's going to be for 3 months, or less, tuck it away and cover it with a tarp. If it's going to be for more than 3 months, drain the gas and run the unit until it's used the gas in the carb. Pull the spark plug and give a light squirt of WD-40 into the cylinder, then put the plug back. If the oil is well used and starting to look dirty, change it. Otherwise, wait until getting it ready for use to change the oil. Cover with tarp. You want something that will keep the majority of water and dirt off, but allow moisture to escape.
Jul 07, 2011 | Garden
I got a 1999 ford ranger with a 2.5l it runs smooth at idle, an runs smooth while drive but bad fuel economy. when u rev up at idle an let go of the throttle it runs rough an then smooths out. ive...
You have two coils on this engine. Test each wire for spark with the engine running. You'll find at least one wire not sparking. replace the coil that has the wire that's not sparking.
May 14, 2011 | Ford Ranger Cars & Trucks
Onan 6500 less than 2yrs old and used once. Try
Your air filter may be stuck with dirt or moist. Try to clean or change it.
In all cases the problem is in the air duct, if it runs well without air filter.
Jul 17, 2010 | Watts Onan Portable Generator - 5000 ,...
Powerwasher 2400psi 2.0gpm Pw2420 Gas Powered Pressure Washer 4 Logo
122 people viewed this question
Top Powerwasher Garden Experts
Mike Carew
Karl H
Bill Boyd
Are you a Powerwasher Garden Expert? Answer questions, earn points and help others
