Question about Ovens
Belling XOU60G oven door wont close
Door wont close properly not sealing heat in
catriver
  • 878 Answers
SOURCE: The oven door are not closing all the way
spot, Maytag put out a service bullitin on this issue....TDC-0017B-B, They put out a new hinge kit...part #12002111 for single and 12002112 for double units. This may be covered under this service flash. Call Maytag service and inquire about the above mentioned service bullitin. Problem addresses doors not closing...Catriver..post back.
Posted on Sep 03, 2006
SOURCE: Whirlpool self cleaning oven, Super capacity 465, door will not close
I had the same FSE error which the whirpool web site advises that you will need to schedule a service appt to fix. Instead I leaded against the door while initiating the cleaning cycle and the door locks and oven cleans fine.
Posted on Dec 02, 2008
barkencoa
  • 3463 Answers
SOURCE: Re Neff B1451 oven door not sealing against oven body at top
The door hinges are not adjustable, the only solution is to replace both door hinges as it is the springs that are weak.
Go to; http;//www.youtube.com/watch?v=
Plz rate my solution.
Thanks.
Posted on Dec 30, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch oven door does not close tightly, takes FOREVER to heat
All you need to do is replace the oven door hinges. as the springs are weak.
It is a fairly straight forward repair to do.
To obtain new hinges, got to:
www.bosch-spareparts.co.uk
or
www.espares.co.uk/bosch
Thankyou.
Posted on Jan 05, 2009
barkencoa
  • 3463 Answers
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Posted on Jul 01, 2009
The door on my Nobel model: Nr.: NF 60 SS/1 will not seal when closed.
Oven doors can warp over time. Also, if the door has a heat shield that covers the window and locks the door during self-cleaning it can become misaligned and prevent the door from closing properly. Minor alignment and adjustment can be done by loosening the screws on the hinges and taking advantage of the slots provided for positioning the door before re-tightening the screws however if the door is warped too much you may not have enough adjustment travel available to properly re-align the door. The metal gasket around the door may also have become damaged and is preventing a proper seal and you might be able to locate replacement gaskets at an appliance parts house.
Nov 19, 2014 | Ovens
I have a Competence B 6139-4-m electric oven. the door does not close properly, have tried cleaning it as intruction manual suggests, the heat escaping from the oven has scorched my cupboards
the fault is unlikely to be the actual oven unit so therefore in order of least expense the things to check are:- the door seal being complete, the hinges not having been forced, the door not being buckled, self adhesive universal seals are available online from *spares etc. Hinges are easy to remove from the cooker and then can be unscrewed from the door and replaced. if it's the door I would have to say that's less likely to be available for a sensible price.
Feb 05, 2013 | AEG B1180-4 Electric Single Oven
Oven door does not close properly
When you say "oven door does not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
Sep 01, 2011 | Neff B1421 Electric Single Oven
I have an ILVE oven and the door is not closing properly so heat is escaping from top left and right sides, discolouring the white frame polyurethane. How do I adjust the door so that the bottom comes out...
Hi david23413, it's the ILVE service team here. Please contact our Service Manager, Peter Dale, on 02 8569 4672 to discuss your issue further.
May 22, 2011 | Ovens
We have a 30 in prostyle electric double wall oven - the oven takes forever to preheat and the doors do not seal tightly when they are closed.
Hello- Many ovens use spring-loaded hinges to carry the weight of the door. Over time, these springs weaken or the hinge gets bent just enough to not fully close door. The door gasket can also become flat and stiff, compounding problem. Any small gap releases heated air, and oven will not heat up properly. Replacing the door springs should solve problem.- Thanks -Ed
Mar 14, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
Heat escaping, uneven baking, longer cooking times
Either the seals need to be replaced, or you may have weak oven door hinges, and the door is not closing properly.
Only solution would be to replace both hinges if this is the case.
Thankyou.
Feb 01, 2010 | Neff U1421 Double circotherm Electric Oven
Oven door fails to close properly. Heat escapes when cooking. Seals appear to be ok. Please assist if free, as offered.
Probably mal-adjusted hinges. Open the door fully and there USUALLY are small holes in the hinges to insert a nail into to hold the hinges open while working on the door.
Nov 25, 2009 | Fisher Ovens
Oven Door will not close properly
Don't buy Bosh. This is a common problem with them and they are not interested in a fix (ie a thinner door seal would help or adjustment to springs...
Feb 11, 2008 | Ovens
Kenmore oven model# 790.79383401 door not closing
Do the hinges come out with the door or does the door slip off the hinges? If the hinges are on the door then there is no adjustment if not there should be an adjustment but you may have to pull the range out to properly adjust if it is a built in range. Also check the door lock.
Jan 15, 2008 | Ovens
Ovens Logo
13 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
