Question about HP Pavilion Elite M9500T Desktop PC
Download driver for atapi dvd d dh16d3s
Drive not working - error 39 - unable to load missing or corrupted driver
  • 64 Answers
SOURCE: cd rom and dvd drives were not visible.
Hi purushoth,
So neither of the ROM drives are available, or just the one? Your jumper settings may or may not be correct; in some systems, even having the IDE cable placement and jumper settings correct may still leave errors such as this.
Basically if you dink around with the settings (for example just try changing the Slave and Master) it will work (provided there's nothing wrong with the drives or IDE cable). I'd also suggest setting both to Cable Select as some systems (such as Sony VAIOs) oftentimes will only allow optical drives to function with that setting.
Ben
Posted on Mar 05, 2008
  • 351 Answers
SOURCE: Error 39, corrupt DVD/CD-Rom Drive
Dear NICK,
its a windows registry related problem, you can fix it through :
This method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 (http://support.microsoft.com/kb/322756/) How to back up and restore the registry in WindowsLog on to Windows by using an account that has administrator rights and permissions. Then, follow these steps. Step 1: Start Registry Editor loadTOCNode(3, 'resolution');Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor. Step 4: Restart the computer loadTOCNode(3, 'resolution');If a CD recording program no longer works after you restart the computer, you must reinstall the CD recording program.
Posted on Mar 24, 2008
latinmcgyver
  • 208 Answers
SOURCE: cd-dw drive corrup or file missing
use filtercheck 4.6 in cdr-zone.com forums to remove upper and lower filters.
Posted on Nov 16, 2008
  • 6 Answers
SOURCE: after system recovery to factory
Remove it from device manager by right clicking it and selecting uninstall, reboot and let windows auto detect it again, reload your drivers, visit the manufacturers website for the correct drivers.
Posted on Dec 21, 2008
RescueTechLA
  • 2653 Answers
SOURCE: optiarc dvd rw ad-7561a ata driver
weird. Try using Windows System Restore to revert back to before installing dameon tools. You can try installing it again but I would re-download just to be safe. It it happens again you might want to try alcohol 120% instead.
Posted on Feb 21, 2009
Atapi dvdrom 16x , wont work because driver is corrupted or missing
dowload driversat http://www.lg.com/ca_en/support/product/support-product.jsp
Dec 04, 2010 | LG 16X Internal DVD-ROM, E-IDE / ATAPI/...
GMA 4082n device driver not working properly code 39
The dvd does not need driver, you need to reinstall Windows.
Jul 18, 2008 | Toshiba Satellite A135 Notebook
Got an error code 39 on my laptop what does it mean
error code 39 is:
Windows cannot load the driver
The driver might be corrupt or missing
suggests re-installing correct drivers
Sep 12, 2010 | Toshiba Computers & Internet
Error Code 39 for NG3046P HKW136D SCSI CdRom Device. "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
goto my computer and right click, enter properties and find deice manager click on the (+) sign on dvd/cd rom drives, right click on update driver, use the internet once option and see if it finds an updated driver, if this dosent work reply to this post, good luck.
Aug 12, 2010 | Dell Inspiron 1525 Laptop
My DVD rom drive is not working I cannot "see" it on the system I have this error message "windowns cannot load the device driver for this hardware. the driver can be corrupted or m missing error code 29...
Check in device manager. To do this. 1st right click my computer, 2nd Click properties, 3rd click hardware, 4th click Device manager, 5th check that the computer is seeing the DVD/CD-ROM drives by double clicking the DVD/CD-ROM drives words or click the + symbol next to DVD/CD-ROM drives, the drop down menu will list your device if it’s there. If a device is listed double click the device. If it says it’s working properly click driver in the top bar and uninstall, then re-boot, the system will re-load the driver on re-booting. If the driver was corrupt it will re-install it correctly.
If the system cannot find the driver on re-booting it's missing from the systems file, go to the Support Fujitsu site and download and install the driver. Its free all you have to do is put the laptop details in the appropriate boxes and all the drivers for that laptop will be listed.
From your description of the error message it’s no doubt a corrupt or missing driver.
Hope this helps.
Feb 24, 2010 | Compaq Presario V4000 Notebook
Pioneer dvd-rw dvr-k17a
Hi, the error code that you have on the CD/DVD drive is a known issue from Microsoft. The error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)".
Since you are using a Toshiba laptop; you can click on this link http://tinyurl.com/toshibadvd and click on the repair tool on the resolution. This is applicable on both Windows Xp and Vista and will delete the upper/lowerfilters on the registry.
In case that the error code still exist you need to manually delete the upper/lowerfilters under the registry by clicking on this link http://support.microsoft.com/kb/929461/en-us . You need to go the "Run" screen then type in "regedit" and click OK or hit the enter key.
This will surely fix the error code that you have on the CD/DVD drive.
Thanks
Nov 13, 2007 | Toshiba Satellite A100-S8111TD Notebook
HP Pavilion Elite M9500T Desktop PC  Logo
70 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
