Question about Jenn-Air JED8430 Electric Cooktop
The cook top display control lock ? i need to unlock the controls
Kitchen air cook top
thanks
  • Jyackle5
    Jyackle5 May 11, 2010
    DO you have a model # that I can look up
  • ISABELLA
    ISABELLA Jul 14, 2014
    YES IT IS A KECC 5508 I ALREADYU TRY THE 5 SECONDS TO UNLOCK AND STILL DOESN'T TURN ON
  • 8,197 Answers
To Unlock Cooktop: Touch and hold CONTROL LOCK for
5 seconds.
Posted on Jan 11, 2009
After cleaning f1 appears on display
This means the oven lock is activated. The cook top touch panel is likely causing some problem.
Try to press the child lock button and see if F1 goes off. Otherwise the control panel will need to be replaced.
Oct 18, 2011 | Jenn-Air JED8430 Electric Cooktop
Cook top is obsolete. burner on right side turns on but heats up slowly
that happens when the controll knob rheostat becomes weak and break down internally you just need to replace the controll switch
Jan 19, 2010 | Jenn-Air JED8430 Electric Cooktop
Display on clock fade out but if i cover it for a few min it come back up mod. jenair cook top sve87600b
I've often seen the display on these units go dim due to a failure in the control board. It may well start out as an intermittent failure. Your comment about covering it reminds me that some ovens have an ambient light sensor to automatically dim the display but I don't recall seeing that on your model.
In either case, it sounds like the classic failure mode we often see.
If you can have the control removed, we may be able to help you, we repair oven controllers at www.fixyourboard.com.
Best Regards,
Bruce
Oct 10, 2009 | Jenn-Air Cooktops
Spark igniters continue to spark:
let it all dry out
thumbs up
Aug 17, 2009 | Cooktops
Why does my jenn gas cook top burners all flicker when turned off
hi im gerbee,i will sujest to clean the area were is the place of ur knob control try to remove the control knob then clean it by using a vaccium coz sometimes the problem is very dirt of the control knob.
Nov 30, 2008 | Cooktops
Switch for cook top fan
i think that there is a sub for that switch.
i tried finding it but cannot find the sub.sorry
Oct 11, 2008 | Jenn-Air JED8430 Electric Cooktop
Candy sprinter
Great.. finally. i manage find from solution from user guide.. L is Locked. below is the instruction. will check out tonight.
The locking function holds the current settings, or prevents anyone from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on. To lock the hob : -Press the on/off button     . -Press simultaneously " - " button and " + " button of the front right zone (PVD 633 front left zone), and then press again on the " + " button of this zone. The hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds. To unlock the hob : -Press the on/off button      . The locking indicator " L " is displayed on all zones. -Press simultaneously the " - " button and the " + " button of the front right zone (PVD 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Jun 24, 2008 | Cooktops
Have a baumatic ceramic hob displayin letter 'L'
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Mar 28, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
476 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
