Ruud contour acheiver 90 plus trying to replace bad thermostat with Nest there is a black wire which goes to a "V" Not sure if this is also a power wire? the other wires are red to 24 V; blue to 24 C; Green to G; yellow to Y1;White to w Any help to connect to Nest second generation thermostat?
chillmaster
  • 104 Answers
SOURCE: Manual Thermostat replcaement with Programmable Digital unit.
Hopefully there are markings on the old t-stat as to what terminal is what.
on the honeywell 8000 use the heat pump labeling and then the standard wiring would be
R- red
AUX-white
Y- yellow
B- O/B
C- black
G- green
There should not be a bare wire, it probably just has the insulation stripped back way too far.
You should probably open the furnace and compare the terminal label in the furnace to the wire color. normally yellow and blue pass through the furnace and are wire nutted to wires going to the outdoor unit. In the furnace the white wire will connect to the w or w1 terminal. also, you will need to set the Honeywell stat to have the following parameters.
170-7
190-1
200-0
other parameters that I did not specify, you may read the manual and make your own decision but I recommend factory settings for the other parameters
Posted on Jun 18, 2008
SOURCE: I have a Ruud thermostat want to change to totaline p274-0200-c
new stat
S1
S2
O/W2/B
R
C
Y/Y2
G
W/W1
Thanks for your help
Posted on Nov 25, 2008
peyton32034
  • 410 Answers
SOURCE: thermostat wiring goodman model aruf032-ooa-1b
is this a heat pump or straight cool with heat strips?
Posted on Mar 16, 2009
bobicehouse
  • 1524 Answers
SOURCE: wiring transformer
You have a "Multi-Tap" transformer, and should have a white label on it with wiring.
Posted on May 04, 2009
  • 4 Answers
SOURCE: replacing old thermostat with new digital
Wire nut or tape the black off. The red is normally 24volt supply power to the t-stat. Blue may or may not be the common. Have a voltmeter?
Posted on Jun 24, 2009
New Nest thermostat, Model 2.8 Software version 4.0.1 keeps getting a low battery and shuts off and shuts down the furnace. Please help.
Do you have a common wire? The nest thermostat needs the common 24V C wire installed to keep the battery charged fully. Nest should tell consumers of this problem, but they don't. Its required for any powered thermostat. Even the new fancy Honeywells with touch screens etc..
Gotta realize the battery cannot run the display and wifi plus all the sensors for very long.
Jan 23, 2014 | Nest Learning Thermostat 2nd generation
My parents have a Ruud Acheiver central air unit coupled with the Acheiver furnace (not sure which model but approx 4 years old). Power went out for them after a storm on Monday. When power came back on...
If you held the contactors at the condensor in and the outdoor fan and compressor started, you have a control circuitry problem. The thermostat is more than likely wired incorrectly. The red wire at the t-stat is the 24VAC hot. If you touch it to the green wire the indoor fan should start. If you touch it to the wire that is going to the coil on the contactor you pushed in (color unknown as I am not there) it should fire the compressor and outdoor fan. Thermostats can be very tricky sometimes. Based on what you have written it is definitely a control voltage problem. If you do not have 24VAC you need to check the input power on the transformer and make sure you are getting 24VAC output.
Whatever you do....do not take the red wire on the t stat and arbitrarily connect it to any other wires. One of those wires is the neutral side of the transformer and if you touch the hot red to it you will have a direct short and will need a new transformer.
If this has helped you please give me a rating I can be proud of. Thank you and best of luck.
Aug 03, 2011 | Ruud UAKA037 Air Conditioner
MY AIR CONDITIONER RUUD ACHEIVER 80 IS FREEZING UP
Hello Sheri Turn the thermostat off BUT the fan switch ON/AUTO to the ON setting this will speed defrost time give it 3 hours.Replace the air filter.Was it clogged?Is any thing at all blocking the intake grille?Poor air flow is a cause of ice.Turn it back on and see if it freezes up again.If so, have the freon level checked it might need a recharge.If not a bad/neglected filter will do it every time.
Jul 26, 2010 | Ruud UAKA042 Air Conditioner
I have a ruud 90 plus achiever gas horizontal furnace. the unit will run once i turn the thermostat off then on. it will cycle a few times go off and then will not come on. any suggestions?
Sounds like it could be a dirty or bad flame sensor.
When the burner lights ,there is a flame sensor in the flame and it is suppose to sense the flame and send a signal back to the control board which will keep the gas valve open, if it gets dirty or is bad it doesn't send the signal back to the board and the board will shut the gas valve off and after three tries it will lock out the furnace and you have to reset it to get it to work again.
The flame sensor looks like a wire and it's in the flame usually it will get gas deposits on it, then it won't work.
You can clean this sensor with an extra fine piece of steel wool, but before you attempt to do this DISCONNECT ALL POWER TO THE FURNACE.
Jan 04, 2010 | Ruud UBHC Air Conditioner
We have a Rudd acheive 90 plus (11 years old) that fires but will not stay running. Any suggestions?
I have not worked on any Rudd 90s but in some furnaces a flame sensor on the opposite side from the igniter can get dirty. It looks like a 0.08 " wire sticking out of a ceramic holder.Cleaning the wire with scotchbright will often cure the problem . Good luck
Nov 04, 2009 | Ruud UBHC Air Conditioner
My Ruud Achiever 90 Plus not blowing cooled air
Look on the condensor, (outdoor unit) at the very bottom of the rear panel and you should find a red reset button. push it. If that does not solve the problem, and the outdoor unit is running (make sure both the fan AND the compressor are running) then you are looking at a low refridgerant issue and possibly dirty coils.
In that case, clean the coils and have refridgerant added.
Sep 23, 2009 | Ruud UBHC Air Conditioner
Ruud Achiever 90 plus not blowing air
the motor is bad or start capicitor
Aug 29, 2009 | Heating & Cooling
I have a Ruud 90 Plus Model UGRA furnace and blower starts immedi
NO BECAUSE THE BOARD IS TELLING THE FANS TO STARTARE THE CONTACTS FUSED TOGETHER OR STUCK IN THE CLOSED POSISTION CHECK THIS FIRST
Aug 10, 2009 | Heating & Cooling
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
