Question about Dyson DC18 all floors Bagless Upright Cyclonic Vacuum
Dyson DC18 will not turn on
When I recently plugged it in there was a little puff of smoke that came from the outlet - Now nothing happens when I press the on/off switch - Is there a fuse or reset switch somewhere to check?
  • Anonymous Apr 13, 2009
    I have the same issue. Was cleaning with the wand tool in the basement and turned the machine off to grab something else. When I came back, the machine won't turn on anymore. Tried various outlets, checking for blockages (to see if there was an auto-off) and short of breaking out the screwdriver, I can't seem to find a way to bring it back to life. :( :( ... and the service area is closed.
  • 4102 Answers
SOURCE: Dyson upright
hi this is an expensive repair and would probably be cheaper to buy new one the problem you have is with the motor bearings seizing its expensive to repair because when dyson made thes vacs they were made so you need special tool to take them apart so replacing the motor would require calling a dyson bloke out as i found out with mine when my switch failed i tried removing and replacing myself but when the bloke came out he used a thin piece of metal down the side of switch to press button to release switch after i payed him to do this 2 months later i got your problem and called them back they tryed selling me new one as the repair was 50 quid more than a new vac.
Hope this is some help sorry i couldnt give you good news
Posted on Jan 08, 2008
  • 83 Answers
SOURCE: My dyson aminal vacuum simply will not turn on. I
The power switch may need to be replaced. Call the Dyson helpline - they will give you the location of an authorized Dyson dealer in your area who will be able to replace the switch.
Posted on Jul 30, 2009
renevacdoc
  • 84 Answers
SOURCE: I have a Dyson DC17 animal vacuuum. Recently got
you need to check the clean out ports 1 directly under the hose on the bottom and the other where the removable filter is
Posted on Jan 02, 2010
SOURCE: Dyson DC 25 Ball - no power to motor
Same problem here. We noticed a loss of suction for about 5 minutes and the suction stopped. Beater bar still rotates but ZERO suction.
Posted on Apr 18, 2010
SOURCE: hi my dyson dc18 has great suction from wand but
My Dyson dc18 had the same symptoms. The wand worked well and the floor bar had no suction. After removing pieces & shoving my fingers into the machine (no blockage) I found the suction pipe rotates between two positions (floor and wand). It looks like a piece of plastic broke on the outside housing, so it no longer rotates positions when the wheels are raised or lowered. My son found we can move the suction by sliding a finger into the mechanism behind the wheel cover, and rotating the plastic piece clock-wise or counter clock-wise until it locks into position. It's a big pain but it works for now. I wish I could find a replacement piece online. Patty
Posted on May 23, 2010
Dc18, new brush bar motor fitted, still not turning. power to all connection. suction works ok..
Hi there, it's Jack at Dyson.
If you've tried to repair your DC18 yourself without success, we would usually recommend contacting us directly for some further advice. If needed, we should be able to arrange for a chargeable repair of your machine by a Dyson engineer.
If you're interested in finding out more about your options, you're welcome to call the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 12, 2015 | Dyson Slim DC18 All Floors HEPA Bagless...
Where is the motor on the dc18
If your DC18 is making an unusual sound along with a change in pickup performance, it's likely you have a blockage somewhere. Our online Support guide should help you locate and clear this:
http://www.dyson.co.uk/support/dc18/dc18-all-floors/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
If your vacuum's filter hasn't been washed recently it's also a good idea to do this. DC18 has one washable filter engineered to last the lifetime of the machine in normal use. This should be washed at least once every 3-6 months using cold water without detergent as shown in the video below. Make sure the filter is completely dry before replacing it - this could take at least 12 hours:
Please note, the post-filter is engineered to last the lifetime of the vacuum without maintenance, and should not be washed as this could cause damage.
Following these steps should resolve the issue, but if you would like some further help from our experts, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 10, 2014 | Dyson Dc-18 "slim" Upright Model...
Cannot reconect hose at base dyson dc8
Hi Joei, it's Jack at Dyson.
DC18's hose should clip back onto the machine without difficulty. It just pushes into place, and you should hear and feel a click as it locks securely. You might find the tips in our Support guide useful: http://www.dyson.com/support/dc18/dc18-allfloors/diagnosis-root-menu/dc18tilterwashvid/flo-dc18-gen-wand-suction/flo-dc18-gen-wand-suction-main/flo-dc18-gen-remove-the-wand-from-hose/redirect-to-flo-dc18-gen-check-the-hose/flo-dc18-gen-check-the-hose
If you'd like further guidance on reattaching it, please give the Dyson customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA), or 1800 239 766 (AU).
Jan 18, 2014 | Dyson DC18 all floors Bagless Upright...
My dyson wont turn the brush roll back on
I'm sorry to hear you're having difficulty with your DC18. You may need to reset the brush bar motor - this is simple to do, so please follow the steps shown in our online Support guide:
http://www.dyson.com/support/help.asp?article=1050&product=DC18-ALLFLOORS
This should resolve the issue, but if you'd like any further help, please give us a call on 1-866-693-9766 (US), or 0800 298 0298 (UK).
Best wishes,
JackDyson Online Customer Supporthttp://www.dyson.com
Jul 03, 2012 | Dyson Vacuums
I think the motor has gone on my dc18 all floor vac as it made afunny sound and smock started bilowing out of it
Hi Lynn,
I'm sorry to hear about this. If you haven't already contacted our customer Helpline, I'd encourage you to do so - you can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
We'll look forward to hearing from you.
Best wishes,
Jack
Mar 26, 2012 | Dyson DC18 all floors Bagless Upright...
Dyson slim dc18 turned off
If your DC18 shut off during use, it may have overheated due to a blockage, or because the filter needs a wash. Once the machine cools down, you should find it runs again - but to prevent this from reoccurring, please follow the steps shown in our online support guide:
http://support.dyson.co.uk/support/dc18/dc18-all-floors/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
In normal use, the filter should be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely before replacing it.
This should resolve the issue, but if you'd like any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Feb 14, 2012 | Dyson Slim DC18 All Floors HEPA Bagless...
The brush is not turning at all
Sorry to hear you're having a problem with your DC18. I note that this question was posted several months ago. Hopefully you've resolved your issue since then. If not, you may find it helpful to visit the Support section of our website, and follow these simple steps to make sure everything is correct with your machine:
If you've tried this and are still having difficulties, please get in touch with us free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
Kind regards,
Jack
Dyson Customer Service
Jan 15, 2011 | Dyson Slim DC18 All Floors HEPA Bagless...
Dyson DC18 wont collapse so that i can vacuum the floor.
The DC18 has a well-known problem with the undercarriages that prevents it from collapsing. There is a forum topic on this subject here: Dyson DC18 discussion.
Nov 13, 2010 | Dyson DC18 Allergy Bagless Upright Vacuum
Dyson DC18
You can download it here
http://safemanuals.com/user-guide-instructions-owner-manual/DYSON/DC18-_E
Jun 25, 2008 | Dyson DC18 all floors Bagless Upright...
Dyson DC18 all floors Bagless Upright Cyclonic Vacuum Logo
511 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
