Question about RCA VR646HF VHS VCR
No color in young RCQ VR646HF recorder
I have an RCA VR646HF VHS recorder relatively unused and only a few years old. I can no longer get color out from this unit. I tried the usual... change tapes, change cables, clean heads, tune tracker, try tapes in out units... none of which restored the color. Otherwise the black and white output is great. Any guidance to a solution or detailed repair manual whereby I could do more testing etc on my own. thanks Paul Despault desp50@yahoo.ca Jan 2009
  • desp50362 Jan 12, 2009
    Hi doogie 812,
    THank you for this interesting idea to do with drying out capacitors. I will try it shortly and report on results. Interestingly enough, I had not used the VCR in about a year. It worked fine before, but not now. This suggests to me that the problem is not due to wear. Your idea of aging of components makes sense. I am not an electrical technician but am a long background in mechanical engineering and should be able to grasp any good ideas to try.
    Thanks,
    Paul,, desp50362
  • Doug Linday May 11, 2010
    Question; Does it pass EE color (does the electronics pass color from video in to video out)? Color problems with VCRs can be very complicated to troubleshoot. Color recording on most video tape is what is called color under. The color carrier frequency for NTSC is 3.58MHz it is super heterodyned down to around 767 KHz. That being there is a lot that can go wrong leaving you with no color. My favorite diagnosis for any problem is coupling capacitors. Capacitors dry out over time. Sometimes you can get lucky and the dielectric will regenerate its self. Just leave the unit on for a few days. No tape, then just record anything for a few hours. Play back the end of the tape and see if the color returns.
3 Suggested Answers
techman007
  • 1112 Answers
SOURCE: camcorder won't record
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Posted on Dec 27, 2009
budmrtn
  • 11361 Answers
SOURCE: RCA L46WD22 LCD tv (3 year-old unit)...No picture,
The back lights inverter is working because you can see the "Unusable Signal' on the screen, if the inverter is dead, yoo will see nothing on the screen at all.
If the T-CON (LCD controller) is dead, you will see just gray glowing screen with no pictures or text.
You may have problem with video processor in the main logic board (tuner, audio, source selector).
Parts for your TV:
http://www.shopjimmy.com/catalogsearch/result/index/?q=RCA+L46WD22+&stock=all&limit=100
This is going to be difficult repair since you do have a way to try out the replacement board to be sure that is the problem. RCA service person has that advantage of parts in stock to try out.
I estimate the board from Jimmy to be about $150, from RCA will be twice as much, plus labor.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jun 28, 2010
Want to copy vhs to dvd.
I convert VHS to DVD using a Toshiba DVD Recorder that I purchased from Costco a few years back. I plug the VCR into the DVD recorder using RCA jacks, press PLAY on the VCR and REC on the DVD recorder and let it sit and record. I can record up to 8 hours of video onto one DVD at low quality. After this, I finalize the DVD so it can be read on other DVD players.
Jan 03, 2012 | Hitachi DV-PF33U DVD Player/VCR
How do I connect my panasonic vhs 188 camcorder to a dvd recorder?
On these old models of VHS camcorder, I recall they have either RCA outputs, or BNC connectors which will require a BNC adaptor (to convert to RCA).
Using a 3RCA lead, connect the camcorder to the video (and audio) inputs of your DVD recorder.
Sep 19, 2011 | Panasonic AG-188 Camcorder
How do I upload my old videos recorded on a VHS C tape from this RCA CC6151 VHS Analog Camcorder to my computer so that I can save them and play them on YouTube or my computer?
You can get videos from this camera, or any analogue video source, into a computer. You just have to play them into an analogue video interface port. These are available as expansion slot cards for a PC, or sometimes as a USB plug-in interface. They will come with drivers and probably software to digitise the video input and record it to a file. Lots of third party video editing software will also be able to accept the input from this kind of port. You don't need any "driver" related to the camera, it is just a video signal source. The connecting leads will be standard RCA signal plugs, like the ones you use to connect to a TV or VHS recorder. You probably already have a lead for this.
Once you have the video on the computer, you will need DVD "Authoring" and burning software, which will usually come as part of the same package. You can download such software for free from the internet- my first stop would be www.download.com.
Jan 14, 2011 | RCA CC6151 Camcorder
RCA Tv color problem
try degaussing the picture tube
Jan 31, 2010 | Televison & Video
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
VHS -DVD RCA Flashes in blue color
if i understand your statement, you are having an issue copying either VHS to DVD or vice versa, most media today has built in copyright protection to prevent what you are trying to do, there are PC softwares to bypass these, but you will have to hook the player to your PC using a TV Tuner, or an Application called VHS to DVD or something similar,
Jun 15, 2009 | RCA DRC8030N
No video on the camera viewfinder or miniscreen
At seventeen years old, it is well beyond the expected lifespan of any domestic camcorder. Replace it.
May 23, 2017 | RCA CC4393 VHS Analog Camcorder
Recording issue
if it is really old there might be a switch on the front under the little door to switch record speeds.
Apr 24, 2008 | RCA VR615HF VHS VCR
Record from a VHS player
This is an easy one. It took me a while to figure it out too. You are on the right track but you need to use the remote control. You will go from record/pause to record and of course you have to use the mini to triple RCA cable that comes with the camera. I can't remember if there is an internal setting in the menu that needs to happen but I don't think so.
Videoteacher
Jan 07, 2008 | Canon ZR70MC Mini DV Digital Camcorder
RCA DRC-8295N
It sounds like you got the old electrical surge blowout going on there bud. It could be as simple as a bad regulator transistor or IC. the onlt real way to tell is to troubleshoot this unit by getting a service manual and a meter and checking your standby and switched power supply. Now since this is a recorder maybe it is wort a look at by your local repair depot or is there any warrantee left on it at as my book says it has a 1 year warrantee but just dont volenter any info how it went out if ya get my drift. Good Luck
May 22, 2006 | RCA DRC8300N DVD Recorder/VCR
RCA VR646HF VHS VCR Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
