Question about Toshiba 50H82 50" Rear Projection Television
Picture distortion on bottom left of the screen
Hey,
Just happened. My tv was working great earlier but I just went to turn it on and now the lower left hand side of the screen has the green camera out of wack.I touched the auto focus but when the horizontal green lines appear the lower one has a curve starting on the left then spreading to the right.
I am not that knowledgable about it but I am also not scared to take it apart. It has served me well for 5 or 6ish years now.
Any help is appreciated
Thanks
  • 24 Answers
Probably bad convergence amp ICs on the signal board.NOT something to tackle unless you are experienced tech.because they will sometimes open resistors in the circuit also.
Posted on Jan 11, 2009
  • tvrepairex Jan 11, 2009
Yellow arch on bottom left of screen
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 30, 2009 | Toshiba 43H70 43" Rear Projection...
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Picture very dark
try to adjust the screen at the back of the plyback.a big parts inside the tv with a wire attach to the picture tube. thre's a two knob there, the lower knob try to adjust it
Oct 09, 2008 | Sylvania 6432GG 32" TV
Distorted Picture
the hyper module is defective needs to be repaired or replaced.
Aug 03, 2008 | Televison & Video
I have a Nikkai A15gy mini wireless TV/video sender, connected from a Sky box, sound is OK, but picture is distorted. The bottom 1/2 inch of the picture appears at teh top of the screen. Have tried...
Hey there Merch12, I had the same issue. I turned it off, unplugged absolutely everything and reset the trip switch in the house and left it over night, the next morning it worked like a GEM hoped that helped you! The same thing happened with my
<a href="http://www.reviewprinters.net/hp-laserjet-pro-m1536dnf-review/">HP Laserjet Pro M1536DNF</a> printer, I used the same technique but it didnt work
Jul 23, 2008 | Televison & Video
Picture Greatly distorted all of a sudden by many yellow lines
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jul 07, 2008 | Zenith D61W25 61" Rear Projection...
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Video distortion
unplug the tv before you go to work or for a couple of hours then plug it back in and let the tv warm up for 15 minutes and adjust the covergence
Dec 11, 2007 | Televison & Video
Purple and white distorted fuzzy lines running up and down and side to side on tv
I just had my lower Y-buffer board swapped out to fix a problem similar to yours. After an hour and a half of on-time, the lower half of the screen would flicker on and off with the same appearance you mentioned. Changing out this particular board fixed it for me. However, since it has gone from top to bottom on your set, it may be more of a main board problem for you (that controls both upper and lower halves). Beyond this, I don't know any more. I am considering getting a service manual to gain more knowledge about the various PCBs in the unit so I can fix any future problems myself.
Aug 19, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Toshiba 50H82 50" Rear Projection Television Logo
93 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
