Question about Bissell ReadyClean DirtLifter Carpet Cleaner
Bissell dirtlifter powerbrush doesn't suck up the dirty water
SOURCE: Water will not come out to do floor work
HI, I have a very similar Bissell. My problem was that after unscrewing the top plate and looking at the pipes the pipes feeding the front sprays were full of gunge blocking the sprayheads. I managed to flush it through by carefully removing the T connector that feeds the front 2 pipes, placing it back so it stuck out of one of the holes and replacing the water tank and turning on while holding it over a bucket. Black and white bits came out but it did flush through. I am thinking of doing a youtube video - let me know if this will help you!
Chessvalley.
Posted on Nov 05, 2008
  • 175 Answers
SOURCE: Bissell Power wash /powerbrush sprays the carpet
It sounds like the suction isn't working right. Check the dirt tank to make sure it is on correct and check the red plastic filter on the dirt tank to make sure that it isn't clogged.
Posted on Dec 02, 2009
SOURCE: Will not **** the dirty water back in.
Can you see the front of your bissel? Does it show the water getting sucked up or stuck? My bissel had a crack on the front and I'm getting a replacement hopefully this fixes the suction problem.
You can also check the other parts related to the suction such as the rubber seal further down the path. If it's become hard and stiff consider replacing it with a new one.
Good luck
Posted on Jul 17, 2010
heatman101
  • 43501 Answers
SOURCE: I need a user guide for the Bissell Dirt Lifter Powerbrush Pro-He
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
afad
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Bissell proheat
heatman101 ;;
I don't have any suction with my bissell dirtlifter powerbrush...how can i fix it?
Check the Water Tank Filter on the cap of the tank (it looks like a screen) If clogged then the tank holds air and can't suck up water. You may want to check your User's Guide to see if there are any other filters that may need cleaning after each use. Hope that helps. If not Bissell has a Consumer Care service at 1-800-237-7691
Aug 25, 2014 | Bissell Vacuums
Readyclean powerbrush plus wont suck up dirty water
Hi Abby! We have a terrific FAQ that can help you with the suction.
Here's the link: http://www.bissell.com/FAQDetail.aspx?id=23699&cid=ccsocial
Oct 28, 2013 | Bissell Vacuums
Can i use this machine to do laminate floors
no not recomendid it will scratch all the laminate
Feb 06, 2013 | Unknown Bissell 2080-3 Bissell...
My Bissell Dirtlifter Powerbrush carpet cleaner will not roll. The back wheels roll fine, but when you put the machine down flat, the front part (where the roller is) sticks and will not roll.
I had the same problem. It would pull backwards but not go forward. A closer examination revealed the clear plastic part on the bottom in the very front of the machine had popped loose on one side.
If you look at the front of the machine, there is the clear plastic part on top where you see the dirty water being sucked up. The bottom half that creates the channel for the vacuum is where it came loose. It wouldn't create enough suction to draw the water up either. By taking out the two screws that hold the top part in place and removing it, I was able to snap the bottom back in. Works fine now. Hope this helps.
Apr 14, 2009 | Vacuums
The dirtlifter powerbrush do not trun.the belt are ok and i unplug it and trun it back . still not working
I have a Bissell Dirtlifter Powerbrush that will not spray soap. I assume the soap lines are clogged, but how in the heck to you "unclog" them? I've searched high and low on the Internet looking for that answer.......
Apr 20, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Chessvalley.
Nov 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell ReadyClean DirtLifter Carpet Cleaner Logo
95 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
