Question about Motorola Mobility HS820 Consumer Headset
How do I turn it off?
I was able to pair the HS820 to my phone and it works fine. How do I turn it off? I held down the middle button but that just redialed my last number!
    Problem Solver:
  • 5 Answers
On my blue tooth you have to press & hold it for it to shut off other wise it will redial last call.
Posted on Jun 14, 2009
Motorola HS820 - cannot hear anything nor can others hear me
It turns out it was the Blackberry's problem, which could only be solved by a 're-boot' - take off the back of the Blackberry, pull out the battery for 10 seconds or so, and replace it. The BB will 'reset' and all was fine then.
Feb 16, 2010 | Motorola Mobility HS820 Consumer Headset
Can't hear with bluetooth
That means the pairing is not successful.Follow the steps
1.Turn on mobile bluetooth and set the status to shown all 2.Tun on the bluetooth mobile and keep pressing the button on the  bluetooth for few seconds. 3.You will notice that light is continously ON and not blinking 4.Now find the device from mobile via search option 5 When it detect use this code 0000 to pair. 6.When the pairing is successful ,select option button and click connect.. 7.Now you should hear from your bluetooth..
Dilip Bagdi
Dec 27, 2008 | Motorola Mobility HS820 Consumer Headset
Pairing Motorola HS820 with Blackberry 8310
there is really no fail safe method to pairing a bluetooth device.
The main thing is recognition. i,d suggest trying to press the different buttons on the transmitting bluetooth device, whilst attempting to pair. i.e volume up/down or on/off et,c. to enable the device-blackberry to find and sync. i,d think the device that needs to be configured or setup correctly is the blackberry rather than the bluetooth device.
try changing the phone settings. to accept all incoming signals on bluetooth, or disable encryption.
hope this helps.
Mike @ Compurepair.
Oct 06, 2008 | Motorola Mobility HS820 Consumer Headset
HS820 won't activate 'voice dial' on Blackberry Pearl
Did you find a resolution.  This is the same problem I am having with the Curve.
May 22, 2008 | Motorola Mobility HS820 Consumer Headset
Motorola hs820
you have to press and hold the button for a few seconds, it will then flash 3 times and then stay solid blue, this is now in pairing mode, get your phone to find the headset and then pair usually with the numbers 0000, then thelight will flash then it is paired.
Sep 30, 2007 | Motorola Mobility HS820 Consumer Headset
My Phone Does Not Locate My HS820 Headset
Try the following:
1) Make sure the HS820 is fully charged up.
2) Remove the battery and SIM card from your phone for about 1 minute and put them back in.
3) As soon as your phone is booted up, access the "find devices" function for adding your HS820.
4) Hold the HS820 button down until the blue light is solid.
5) Then do whatever your phone requres to "search for devices."
6) Here's the key: as the phone is searching for devices, PHYSICALLY TOUCH touch the HS820 to the phone.
I couldn't get my HS820 to synch with my new Blackberry Curve the normal way and ultimately got it to synch by going through this process.
Sep 11, 2007 | Motorola Mobility HS820 Consumer Headset
Motorola HS820
the always on light mens that it is in pairing mode and wont go out until it has paired with a phone, if you wish to turn it off, press and hold for 3 seconds, it will then flash 3 times and then go off. Try pairing again by pressing and holding the button until the light stays on.
Jul 10, 2007 | Motorola Mobility HS820 Consumer Headset
Headset will not pair up eith razr phone.
Have you pressed and held the button on headset until light is always on, as this is in pairing mode, then search devices with your phone.
Jan 15, 2007 | Motorola Mobility HS820 Consumer Headset
Motorola Mobility HS820 Consumer Headset Logo
155 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
