Question about JVC Car Audio & Video
Jvc check wiring and press reset
When the unit is turn on a message check wiring and then press reset appears. wiring is correct
2 Suggested Answers
smarthome2
  • 1114 Answers
SOURCE: listening to sirius satellite radio and "reset 8" message flashed
The Sirius tuner is bad. 1000's were sold and 1000's have been replaced! The new model will work with your unit and does not fail, it's manufactured by DEI not Audiovox. Or, you can check Ebay for a rebuilt tuner for around 40-50 that has the problem fixed and corrected. Hope this helps.
Posted on Sep 26, 2009
I have a jvc kd-r45 it keeps on saying warning unit check wiring then reset
The check wiring message suggests a short probably in a speaker wire. Check that the terminal leads for the speakers are properly covered in insulating tape. Check the rest of your wiring, if you can, to check for any section where the insulation is worn and could come into contact with anything. Next remove the faceplate and use a pen to press and hold the reset button. The button is near the bottom of the middle of the receiver.
If the error persists, then another section of the wiring is making metal on metal contact with the car or another wire. You should contact a JVC dealer or the company that provided the kit with the KD-R45.
I hope this helps.
Jan 27, 2015 | JVC Car Audio & Video
My JVC KD-R426 keeps on saying warning check wiring and reset system. I've tried everthing but it still does the same. What must I do
Not sure if this will help any other owners since my answer is 4 years late, but this is what I found from another user. Apparently if you mess with the wiring too often, it goes in a safe mode which you need to do some button trickery to unlock the device from it's safe mode. These are the Steps.
1.Disconnect power supply
2.Press [MENU] and [UP arrow] buttons and keep holding.
3. While holding the buttons [MENU] / [UP arrow], connect the power plug again
A. The display will show "DC ERR"
*** if it still shows "Chk wiring ..." repeat the steps above until you get "DC ERR."
4. Press [UP arrow]; the display shows "DC1 ERR"
a. Press and hold [UP arrow] and it will show "DC1 OK"
5. Press [Down arrow], the screen will show "DC2"
a. Press and hold [DOWN arrow] and the display will show "DC2 0"
6. Disconnect the power from the back of the unit.
7. Remove the Face Unit.
8. Reconnect the power from the back.
9. Use a sharp object and press the [RESET] hole for 3 seconds and release.
10. Reinstall the face unit and turn on the power.
Oct 04, 2012 | JVC Car Audio & Video
How to reset map update message on jvc nx7000
Here's the solution from the JVC Customer Service. BE WARNED: this will wipe out all your customizations, including but not limited to favorite addresses and radio station names.
"As for turning off the message about the maps on the radio, please follow the next steps.- Please follow this procedure to perform a factory reset and remove the message.
1. Turn ON the radio
2. Set the Source to "Tuner" mode
3. Simultaneously press and hold the [Disp], [Map] and [Down] buttons for more than 2 seconds
- You must press the buttons in that order
4. When the "Service Menu" Screen appears you may release the buttons
5. Touch the UP/DOWN arrows to highlight "Initialize All"
6. Touch [Enter] to initialize the unit
7. The unit will be initialized and the unit will reset on its own.
Apr 20, 2012 | JVC KW-NX7000 Car DVD Player
I get the error code FSE1, lock won't engage message for the bottom oven everytime I turn on the top or bottom unit. The message will not go away until I turn the top unit off. The bottom lock keeps...
F5 - E1 Self clean latch will not lock
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Apr 19, 2011 | KitchenAid Architect KEBS208S Electric...
How do I set the clock?
I found this on Page 22 of the JVC KW-XC777 Manual
http://resources.jvc.com/Resources/00/00/97/49688ien.pdf
1. Press and hold SEL (select) for more
than 2 seconds so that one of the PSM
items appears on the display. (See
page 23.)
2. If “CLOCK HOUR” does not appear
press >>| or |<<
repeatedly
until it appears.
3. Adjust the hour.
4. Press >>| or |<< until “CLOCK
MIN (minute)” appears on the display.
5. Adjust the minute.
6. Finish the setting.
To check the current clock time while the unit
is turned off, press DISP (display).
The power turns on, the clock time is shown for 5
seconds, then the power turns off.
I hope that helps.
May 25, 2010 | JVC KW-XC777 CD / Cassette Player
Listening to sirius satellite radio and "reset 8" message flashed
Sep 26, 2009 | JVC KD-G230 CD Player
ERR message appears
Press the RESET button on the rear of the unit while it's turned on. After that unplug the AC adaptor and wait a while before plugging it again.
Jul 31, 2009 | JVC RA-P11 Portable Audio System - Made...
Jvc model no.ca-hxd7 system no. hx-d7
Check back speaker wires! this is protection mode! There is a short circut! look for stray wires touching metal or each other!
if this does not do it then unit will have to be fixed by a pro!
Please use the ratings and help keep this area FREE!
Jan 23, 2009 | JVC MX-GT88 CD Shelf System
Error message No Disc
Unit has bad disk t-table motor
May 06, 2008 | JVC MX-J200 CD Shelf System
JVC GR DVL 9000 digital video camera EO3 problem please help.
Manual says any message E01-7 is 'a malfunction of some kind'. Recommends remove the power supply, battery pack etc, and press the reset button. Wait for a few minutes for the indication to clear, then resume normal use. If it doesn't clear after 2-3 attempts, take it to your dealer.
Sep 16, 2007 | JVC GR-DVL9000 DV Digital Camcorder
Car Audio & Video Logo
21 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
