Question about JVC AV-32230 32" TV
JVC TV - No Pic or Sound-Blinking Red Timer Light
Hi, I'm having a problem since the storm here the other night, i.e. continuous blinking timer light and no picture or sound. Any posible solution short of taking the tv to a repair shop? Ed Holley Virginia Beach, VA
  • michael Oct 10, 2011
    timer blinking problem on jvc tv av-14fgt2
  • 934 Answers
No sir... Nothing short... The red blinking timer light indicates the the protect circuit has it shutdown. That's happened because something has probably shorted along the B+ line. If it were here in the shop I would be checking the following: IC911 Str-G6624 regulator PC921 Tlp421 F905 5a Pico Fuse C931 160v/100uf cap and the HOT of course 2Sc2539 One or more of these parts has probably failed but usually not all of them.. So it's not an expensive repair. Now, while you're having that done also have them do the following modifications for greater reliability if it hasn't been done already: Remove D701 you don't need it. Install C705 (47uf/16v) in space provided (near Ic701 Pin 22 ) Replace jumper W122 with ferrite bead (Qqr0582-001z) Add a cap(47uf/16v)between pins 61 and 64 of Ic701 neg to pin 64 and pos to pin 61 This is per a JVC bulletin that the shop you take it to may or may not have. It's a simple and inexpensive modification and will add a measure of reliability to the years this set has left. As a footnote, take the set into the shop yourself and pick it up when it's done. This will help keep the cost down. All-in-all should be less than $150 if all the parts above got replaced. If you have any questions don't hesitate to ask. Hope this helps Bill 360-642-4993
Posted on Jun 07, 2007
Blinking red light on pic off/timer
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 15, 2014 | Sony BRAVIA Televison & Video
Blinking timer light, No picture or sound.
Ur high voltage is dead,the FBT,the flyback transformer,the big black block of plastic with a red wire with a cap hook to the CRT(tv tube).That is dead.
Sep 27, 2009 | JVC AV-36D302 36" TV
Tv shutting off timer light blinking
The problem you describe is not really related to a timer function being set. The unit is in shutdown and the light is blinkng to let you know there is a problem.
There are several possible causes. the most common is a failure in the vertical deflection circuit due to a bad vertical IC and possibly a capacitor, zener diode and resistor.
Feb 19, 2009 | JVC AV-27530 27" TV
No picture and no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 11, 2017 | Samsung Televison & Video
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
Wont power up, red blinking light (on timer)
Refer to the trouble-shooting section of your manual. Usually, with this technology, the lights (Lamp/Temp) on these sets are also used at diagnosis/fault indicators... so, your manual should tell you what a flashing TIMER light represents. If the manual, doesn't provide this information, then ring JVC and ask one of their technicians.
Jun 26, 2007 | JVC AV-36F702 36" TV
I believe I've answered this one or one identical to it:: If not, No sir... Nothing short... The red blinking timer light indicates the the protect circuit has it shutdown. That's happened because something has probably shorted along the B+ line. If it were here in the shop I would be checking the following: IC911 Str-G6624 regulator PC921 Tlp421 F905 5a Pico Fuse C931 160v/100uf cap and the HOT of course 2Sc2539 One or more of these parts has probably failed but usually not all of them.. So it's not an expensive repair. Now, while you're having that done also have them do the following modifications for greater reliability if it hasn't been done already: Remove D701 you don't need it. Install C705 (47uf/16v) in space provided (near Ic701 Pin 22 ) Replace jumper W122 with ferrite bead (Qqr0582-001z) Add a cap(47uf/16v)between pins 61 and 64 of Ic701 neg to pin 64 and pos to pin 61 This is per a JVC bulletin that the shop you take it to may or may not have. It's a simple and inexpensive modification and will add a measure of reliability to the years this set has left. As a footnote, take the set into the shop yourself and pick it up when it's done. This will help keep the cost down. All-in-all should be less than $150 if all the parts above got replaced. If you have any questions don't hesitate to ask. Hope this helps Bill 360-642-4993
Jun 07, 2007 | JVC AV-32230 32" TV
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
JVC AV-32230 32" TV Logo
247 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
