Question about Intermatic & Indoor/Outdoor Rain Tight Timer
My rain tight intermatic outdoor timer no longer switches contact
My intermatic timer no longer funtions. Is anything can be done?
  • 1 more comment
  • dackerscd Jan 12, 2009
    No I can not turn on load via off/on switch.
    In fact with timer detached from power, when I put ohm meter between one leg of ac power (male plug) on timer and one side of female plug I get contact, But when I try this with other side of these plugs I don't make contact no matter what position I put off/on switch in
  • Joel Wiedeman May 11, 2010
    If you are only controlling 120Volt then wire nut together the neutrals and try again. This way you would only be controlling the "hot". The contact points on the neutral points may be bad...
    can you manually turn on the load via the off/on switch in the timer?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Habit-Forming:
  • Intermatic Expert
  • 112 Answers
The way the message reads the timer was working and then quit. most likely the contacts or clock motor has wore out. but by u sayiing u can't get power manually i would say the contacts or relay that switches the load is bad.
i would try to buy a timer that was the same and put the guts in the old box if its alot of trouble to change out.
one other thing u can check, is the timer getting its operating power from the circuit or is the something else controlling the timer. if there is something else controlling the timer, i would check that to see if i had power there.
Posted on Jan 13, 2009
Manual switch works timer doesn't.
Timer that worked before and stopped working: could be clock motor or trippers
New timer installation: possibly the wiring from breaker box and wire to Load are reversed.
Open following links to troubleshoot Intermatic timer.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Jul 27, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
How do you wire a Toro Rain Sensor 53769 to Intermatic Timer T8845PV
The rain sensor only connects to Intermatic sprinkler timer IF the timer has the rain sensor terminals.
Not all Intermatic sprinkler timers have that connection.
For example R8815P101C and R8816P101C have rain sensor terminals
I think the rain sensor terminals are located to the right of main wiring terminal block.
There are two screw terminals.
The rain sensor plugs into a power source, and then sensor wires connect to the timer.
Apply no voltage to the sprinkler timer terminals.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
May 01, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
We replaced the battery for our Intermatic Rain Tight Outdoor 7 day digital timer MODEL HB71R70 but the instructions to reset the timer have been misplaced. Could you please supply us with step by step...
Hi Maggie.
Intermatic no longer makes HB71 timer, and I cannot find instructions for the timer.
Intermatic website is offline on weekends starting March 2011, but I have searched the site numerous times over past year and they do not post that manual.
However I might be able to piece together steps if you add a comment and include in-focus photo of timer and buttons. Also include anything you can remember about setting the timer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
My understanding so far is that this timer has 2 slide buttons, and several push buttons.
Typically slide button timers require both slide buttons to be in one position for setting timer, and another position for programming timer, and another position for operating timer. The complicated steps are why timer has been replaced with newer models with sleeker programming.
If you do not want to bother sending photograph, or working on the problem, then buy another outdoor timer for 20$
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
http://www.amazon.com/Woods-59403-Heavy-Duty-Outdoor-Digital/dp/B002KS7EOK
http://www.homedepot.com/Electrical-Dimmers-Switches-Timers/h_d1/N-5yc1vZ1xg8Zbm2d/R-100685861/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Apr 23, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I need contact points for Intermatic #ML300RTW or more specific contacts for, #PB912M10 clock
ML300 is a Power Pack for outdoor lighting
A search of Intermatic site shows they no longer sell the product
Malibulights.com does not have any parts either
I have searched the web for parts in order to help fixya visitors, and I can't find any trippers or clock repair parts at all.
I bought a new Malibu 330Watt at Home Depot thinking the manual or box would show information>> but the new Power Packs have a digital clock, not the old dial clock with trippers.
Look like you have to buy a new Power Pack to fix the old one.
Oct 26, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Describe your Intermatic &
Is the time clock rotating through the off tripper? If so, and the pump stays on, it's not wired right. Check the wiring at the clock for the pump.
Jul 01, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
311 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
