Question about Sharp Office Equipment & Supplies
Clear Toner cartridge error code on Sharp FO-5700 fax machine
Our Sharp Fax machine displays the error message: "Clear toner cartridge" and will not send faxes. We seem to be receiving faxes okay, but cannot send them. I tried turning off the machine, removing the toner cartridge, unplugging power source and unhooking from phone line. Still getting error message.
    Dedicated:
    Visited the website for 20 consecutive days.
  • 344 Answers
Get the User Manual for your FO-5700 fax machine here:
http://www.sharpusa.com/Support/ProductDetail.aspx?model=FO-5700
Good luck.
Posted on Jan 03, 2018
  • 2072 Answers
SOURCE: Problem with Sharp FO-1460
What happens when you make a copy?
If that is blank, you have a bad scanner.
Posted on Jan 10, 2008
leroyal
  • 2120 Answers
SOURCE: Error on Sharp fax UX-B700
Do you have a DSL or any kind of digital phone line?
Posted on Oct 26, 2008
  • 48 Answers
SOURCE: sharp fo 4700 display error ( polygon )
You have a bad printhead unit(laser unit) . The polygon mirror is not rotating within a specific amount of time. I recommend you to replace your fax unless your willing to spend between 200 to 500 dollars.
Posted on May 25, 2009
  • 48 Answers
SOURCE: Sharp FO-4650 fax machine
You have a bad printhead unit(laser unit) only if the problem persist. The polygon mirror is not rotating within a specific amount of time.
  • 48 Answers
SOURCE: Sharp FO 5700 - Please Wait For A Moment message
Hold down the stop and start key while turning on the fax, let go when you see 1 for yes 2 for no for memory clear. Press 1.
REPLACED THE TONER CARTRIDGE WITH A REFILLED ON AND GET THE ERROR MESSAGE "SYSTEM ERROR F2-70"
Most Copier Cartridge have chips on them that tell the copier I am new, Replacing the toner/refill, does not change the chip info as long as the chip says I am empty its empty to the copier, replace the cartridge with a new OEM cartridge.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 17, 2015 | Sharp FO-2081 Copier
How to fix clear toner counter in a fax machine FO-4970
On my Sharp FO-4970 I am receiving a Clear Toner Counter -- anyone know how?
Feb 25, 2011 | Sharp FO 4970 Fax
How do I fix CLEAR TONER COUNTER?
Flip up the plastic piece above the Number Keys (Rapid Key overlay), Hit the Life key, Hit the #2 , Then press START.
Nov 25, 2009 | Sharp FO 5800 Fax
How do we "clear toner counter" from the display screen
Reset the toner counter by pressing
the LIFE key (flip up the Rapid Key overlay if necessary), the "2" key,
and the START key.
Oct 21, 2009 | Sharp FO 6600 Plain Paper Laser Fax
Flashing light, with the words saying clear toner counter, how do I do that?
Shake your toner then press LIFE 2 START. If the problem persist replace your toner then press LIFE 2 START. Your life button is located under the page plate(flip it over).
May 07, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Sep 08, 2008 | Sharp FO 5700 Plain Paper Laser Fax
SHARP FO-5600 - THE MACHINE HAS AN ERROR MESSAGE IN THE DISPLAY AREA "CLEAR TONER COUNTER". I CANNOT FIND ANYTHING IN THE MANUAL ABOUT THIS MESSAGE
CDURHAM,
I found the answer to this on page 22 of the PDF manual that can be downloaded from http://www.sharpusa.com/files/fax_man_5700.pdf.
May 06, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Sarp FO-5700 it doesn't noved.
Can you do a copy?
is paper tray in base of machine up or down?
Are drum and toner ok?
Do you have network card attached?
How do you know that fuser is ok?
Nov 04, 2007 | Sharp FO 5700 Plain Paper Laser Fax
Error message Sharp FO-4450 Fax machine
Press life "2" start for toner.
And life "3" start for drum.
These will reset the counters.
If you are having a "check drum error" then you have broken the sensor arm that is attached to your lid.
Call a technician in your area.
Jeff
Sep 19, 2007 | Office Equipment & Supplies
50 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
