Question about Sharp Rrmcg1236ajsb Remote Control
Programming for Sharp RRMCG1236AJSB remote
No manual. What buttons to precede code settings for Phillips/ Magnavox tv
  • 6 Answers
SOURCE: comcast remote code for 42in sharp aquos lcd
the 10093 code worked perfectly!!! YOU ROCK! the codes in the comcast manual dont work. i don't have an aqquos, but a regular sharp hdtv... purchased in nov '07
Posted on Mar 23, 2008
SOURCE: Programming the Acquos Remote
I got a a sharp LC-32D43U and for my motorola cable box i use hte code 31 from jerrold, i take it from the manual and i got it tryin every single code unti i get one that works.
Hope it works for you
Posted on Oct 21, 2008
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
I had the same problem... and was lucky enough to stumble upon this. Here is the screenshot.
Posted on Feb 11, 2009
SOURCE: Require Remote Control Set Up Codes
I have a slingbox and I am based in the UK. I need help from someone to create a binary file I can use within the slingplayer software to control my sharp TUTV502H remotely....
I can get most of the buttons working using code 44 of code 62, hope this helps.
There is another issue I am experienceing in relation to controlling the TUTV502H remotely which is outlined in this post http://www.hifi-remote.com/forums/viewtopic.php?t=11625&sid=fd5131f04cda102df8771e07d138f64b
It sounds as though someone who knows what they are doing might be able to help...?
Thanks in advance.
Posted on Jan 12, 2010
I NEED TO PROGRAM A MAGNAVOX TV WITH A PHILLIPS UNIVERSAL REMOTE CONTROLL
Find codes and methods here.
http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
If those codes dont work try the last three(or four) numbers of your TV's serial number.
On my universal remote is just a matter of holding down the TV button till the light stays on, then punching in the three digit TV code. When the TV turns off it's the right code. But read your manual for your controller.
Oct 08, 2010 | Universal Remote Control Universal IR...
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
INo manual, need set-up and codes please
Philips 807,002,020,022,422,122,222,322,520,919,521,621,430,247,901,402,408,109,210,310,715
Magnavox 807,002,502,919,224,430,247,402,408,109,715
Zenith 713,502,606,409,710,507,714,405,712,015,916,008,002,115,415,...
Sharp 509,913,907,603,002,502,224,228,202,111,813
Dec 05, 2009 | Emerson Televison & Video
I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Oct 19, 2009 | Philips Magnavox Learning Universal Remote
I have an older Phillips Magnavox TV Mar 2000 model number TP3284C102 and the remote died. I am trying to program a new remote (a samsung) I hit the set button and run the channels but cannot get it to...
The code number should be listed in the manual sheet for the remote control, or from the Samsung web site. If not found, a new OEM remote for the Philips TV is available from Amazon for $21.
Oct 18, 2009 | Philips TV Tuner Video Capture PCI Card -...
Need codes for a philips universal remote code sheet
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 21, 2008 | Philips Magnavox Learning Universal Remote
Universal Remote control code on Sharp 13H-M60
Hope this helps :)
Jun 19, 2008 | Televison & Video
PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
Hope this helps :)
Jun 18, 2008 | Philips Magnavox Learning Universal Remote
Need code for phillips remote
Hope this helps :)
Jun 09, 2008 | Philips Televison & Video
I don't know how to program my remote anymore!
I had the same problem and typed in the model of my vcr instead of the remote model. This is the site I found, although my tv is not on the list, I followed the steps at the bottom of the page and found that code 08 worked for my Phillips TV. I hope this helps all of you with finding your codes and programming your remotes.
http://www.remotecodelist.com/remotes/sharp/sharp_vch982.html
Jan 14, 2008 | Sharp RRMCGA342WJSA Remote Control
Sharp Rrmcg1236ajsb Remote Control Logo
105 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
