Question about Whirlpool Washing Machines
Whirlpool super scour supreme doesn't drain water at end of wash
SOURCE: washing machine leaks
Go to fixitnow.com to find out how to remove cabinet. If it's a big leak it's most likely a hose; if a little leak, more likely the pump. Both easy to replace once you have cabinet off.
Posted on May 14, 2009
  • 278 Answers
SOURCE: ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Posted on Oct 16, 2009
  • 239 Answers
SOURCE: Whirlpool LT5000XSN1 - Stackable Thin Twin,
The lid switch is likely bad. It should click when lid is opened and closed.
Kelly
Posted on Mar 22, 2011
  • 86 Answers
SOURCE: have a whirlpool AWO 3551 washing machine. Door
My daughter had the same problem for about two years. A repair man came out and told her to call the company and tell them she wanted it fixed under a recall. She said the computer board had to be replaced and it was recalled due to a flaw in the machine. The service man came back again after she called, and he fixed it for free.
Posted on Jul 16, 2011
Macmarkus
  • 2605 Answers
SOURCE: A working, no problems, Whirlpool Ultimate Care ll
Hello, welcome to FixYa.
Based on your post I understand you have a problem with a washer, further to that your description "it would fill and wash but at end of wash cycle would not shift to pump out, nor go to rinse cycle nor spin"
leads me to believe it is a faulty lid switch.
The scenario you describe is usually associated with a faulty or broke lid switch...but I don't know if you checked that yet or if you know how.
The lid switch failure is definitely a common problem with these models. Here`s how you can repair it pretty easily...or even just to gain access to check it.
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...but with your model number it will cover yours)
Here`s a helpful link for changing it out, though it will have subtle differences it is a good tutorial on accessing and changing the switch.
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...(if it is indeed a LSQ9549L model...if not please post the correct model number)
Let me know how you make out. If this is something you think is not within' your scope of expertise please call a pro. I think you'll be fine with the tutorial video in the link.
I will try to help in any manner I can of course as well, if you need it. Good luck.
Thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Posted on Jul 21, 2011
Whirlpool Supreme 80 washer
it sound like the water pump has an object in the housing preventing it from operating, take the back off the machine to get to the water pump and take it apart to clear the blockage good luck eric
Jan 01, 2018 | Whirlpool Washing Machines
Whirlpool LSR8233EQ1 Overflows
I would check the water height sensor. It is a tube rising from the bottom rear of the tub and has a sensor on the end. Probably full of washing powder/soap.
Nov 30, 2017 | Washing Machines
Washer doesn't spin and drain
Possible blockage in 1 of the outlet pipes causing it to not drain out fast enough and keeping the clothes wet.
Dec 22, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool dishwasher wont wash
if the bottom tub is filling with water but not washing the issues is with the wash motor, some of this model use a start capacitor that can fail, if it has a capacitor on the side of the motor it may have failed but are difficult to diagnose but are cheap to replace so worth trying, if this doesn't help or if it doesn't have a capacitor then the fault is with the wash motor.
Mar 08, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
Doesn't spin fast enough to remove water from tub. makes a steady noise that doesn't get louder or softer just stays steady
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Water doesn't drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 08, 2011 | Whirlpool Washing Machines
My dishwasher doesn`t drain. there is water at the bottom at te end of every wash... what`s wrong? how can i fix it?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 06, 2011 | Whirlpool Dishwashers
Washing Machines Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal De
