My km2550 kosira after make twenty copys km 2550 earer p0410 soluition
After twenty copys make km2550 earer p0410 after off machine and on machine working then fifteen copy makes then earer code p0410 solution please
faeq8
  • 7 Answers
SOURCE: Kyocera KM-1510
BD steady-state problem • BD steady-state problem is detected. (jam code 98)
BD steady-state problem • The VTC detects a BD error for 800 ms after the polygon motor rotation has been stabilizad.
Poor contact of the connector terminals. Defective LSU. Defective main PCB.
Check the connection of connector CN18 on the main PCB and the continuity across the connector terminals. Remedy or replace if necessary. Replace the LSU. Replace the main PCB and check for correct operation.
Posted on Dec 31, 2008
  • 26 Answers
SOURCE: error code C0F37 on Kyocera mita KM-C1530
This code is not documented, the firmware must be reloaded and a service tech can only do it ...
Posted on Feb 21, 2009
SOURCE: getting SC541 code on our copy machine. what does that mean?
It must be a Ricoh copier,and the model doesn't matter. This code is a fuser warm-up error, and can only be reset in service mode by a technician after the problem is fixed.
Posted on Mar 24, 2009
  • 118 Answers
SOURCE: i have 3 color copy machines irc3200n,clc 2620 all the machines
the cause of the problem is ,the transfer belt is not rotating properly ITB rollers must cleaned throroughly (cleaned by isopropyl alcohol) to prevent slippage of transfer belt that causes mis alignment /misregistration of color,but copying BW is ok,In other words ITB unit needs servicing ,Run also gradation adjust QUICK and FULL adjust (for IRC 3200)
Posted on Aug 04, 2009
  • 239 Answers
SOURCE: OUR XEROX COPY MACHINE MAKES A SQUEALING NOISE
On this model most squeeling noises come from the fuser assembly.
If it is that loud replace the fuser assembly.
Other known prolbems is with the fuser fan in the back.
To see if it is the fuser fan, take off the back cover.
When the machine makes a copy unplug the fan very momentary. See if the noise goes away.
If the noise is still there, then it is possible the fuser is causing the problem.
Make sure the correct fuser is installled on this machine model.
Posted on Oct 26, 2009
Error c3200 on km2550
Clean the slit glass or open the glass and clean the mirrors from the dust.
Mar 25, 2017 | Kyocera Mita KM-2550 All-In-One Laser...
Kyocera KM2550 printer prints test page but cannot print word documents and pdfs
Try loading paper in the bypass on the left hand side of the machine.It may be that you are trying to print a document that is a different size to the paper that you have loaded in the copier.
Jan 13, 2014 | Kyocera Mita KM-2550 All-In-One Laser...
BLANK COPIES FROM KM 2550
first chek dev unit toner? pls insert toner 1087+ 1087+ 130 set dev enter ok then 10 mnt wait and check drum and dp closing time corect sitting or chage edge of dp unit you cleang time smothing wrong?? comng blnk copy
Aug 03, 2012 | Kyocera Mita KM-2550 All-In-One Laser...
Kyocera km 2550, copies are faint in the centre
If your prints or status page prints normally and the light/faint area is only when making a copy then the mirrors in the optics need to be cleaned. They can get dusty or build up a film on them. You must turn off and unplug the copier then remove the large glass that you place your original on. There are two screws to the left of the large glass if you remove them the piece of plastic that holds the glass in place on the left can be removed. Left the glass off. If you are careful you can grab the center of the mirror base that houses the lamp that comes on when making a copy and slide it slowly to the right. This will allow you enough space to clean the mirrors. Use a clean lint free cloth with a mild glass cleaner (with no amonia). Put everything back to were it was and plug in and turn on the machine and you should be all set.
Dec 14, 2010 | Kyocera Mita KM-2550 All-In-One Laser...
I want add a KM-2550 as a printer on an XP machine. I know what the host name of the KM-2550 is. The KM-2550 is definitely on the network because I pinged it from the XP. How do I find the name of the...
u can come to know from the server
where its physically installed
goto printers and faxes
then oen printer properties
and there is a tab named shared
see the name there
and write it
and then
u can add to the other macine
and can install
Jun 18, 2010 | Kyocera Mita KM-2550 All-In-One Laser...
Program
IF it says downloading program it sounds like it is trying to update the firmware. Did someone stick a compact flash card in the CF card slot. If so removed the CF card and reboot the machine.
Jan 05, 2010 | Kyocera CS-2550 Black and White Copier
I am trying to set up newtwork scanning on our Kyocera KM 2550 multifunction machine and I can't find in the manual how to do it?
cool... ok here is what you do goto usa.kyoceramita.com then downloads... then where it says choose product... choose legacy copier then choose product then... where it says select subcategories... select manuals you need the scan system f operations guides both the setup and functions editions...
Dec 22, 2009 | Kyocera Mita KM-2550 All-In-One Laser...
How can i set up KM2550 to scan
install the paper port software from the printer driver cd and use it to scan
Dec 16, 2009 | Kyocera Mita KM-2550 All-In-One Laser...
Duplex copying
sorry but you haven`t duplex on your machine. you need to buy dublex unit or you can print on one side end insert the paper again and print on the other side.
May 19, 2009 | Kyocera Mita KM-2550 All-In-One Laser...
19 people viewed this question
jasbo
jasbo
