Question about Samsung HLN437W 43" Rear Projection HDTV
I have a samsung HCP4752W and one we were watching it, turned it off went to bed and the next day there was fluid around the bottom amd on the flood. the T.V. turned on but there was no picture. The red tube was replaced and the green and blue wheren't? Do you know how to text the picture tube?
  • ang4faith Jan 12, 2009
    This one dont have a color wheel, this model has three color tubes with fluid in them.
  • 20 Answers
HCP-4752W does NOT have a color wheel as it is not a DLP set. my hln-617w is a DLP set.
Posted on Apr 10, 2012
    Champion:
  • 240 Answers
Theas units have a comen problem of the color weel failing, first check the lamp then the wheel and all fans.
Posted on Jan 11, 2009
The sound on my Magnavox CD130MW9 stopped working
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 21, 2012 | Televison & Video
Lg50pc1d purple screen
try to unplug the set for a period of time?
Mar 12, 2012 | LG Televison & Video
Tv won't turn on light blinks on front
can u help my tv wont turn on samsung hcp4752w
Oct 25, 2011 | Samsung HC-P4752W 47" Rear Projection...
My Samsung SK01 42" TV
Power board assy' is defective. Check those bulging caps right into secondary circuit.
Jun 08, 2011 | Televison & Video
1996 gmc truck will not start. I pulled in the
ok sounds like a fuel problem if all the fluids are ok and there is gas in tank try removing gas cap and have someone turn on key but not try to start and while they do that put your ear next to filler pipe and listen for a humming sound like an electric motor it will only humm for a second or so if it is working if you hear nothing at all i would guess your fuel pump went out. they are electric and they are located in the fuel tank . youcan also give a quick hard thump on bottom of fuel tank sometimes this will vibrate pump enough to make it come on and let you start it to move it to a safe location to service it but as soon as you shut it off it will not restart. the last pump i purchased was around $80.00 and you either have to drop tank down or remove bed to change it. if you have a lift i would drop tank if you have a couple guys handy and are mechanicaly inclined youcan remove truck bed and get to it that way . i removed bed took about 4 hours from start to finish by my self.
Mar 18, 2010 | 1999 Chevrolet Silverado 1500
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Amim 30I
Have you tryed, a reset and a hard reset?
Try contacting dell.
If dell is no use, try asking from a local pc repair shop.
Its possible that the device has got a hardware issue and the mainboard might need to be replaced possibly high price. around the price of a new one I guess.
Feb 04, 2008 | Dell Axim X3 Pocket PC
Hotpoint W/D valve problem
yes change inserts around leave top off test and watch. red is for hot water black for cold
Nov 20, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Messed up Image
bad connection on convergence amps or need to replace them
Oct 11, 2007 | Mitsubishi VS-50805 50" Rear Projection...
Flooding
Check the water inlet valve (An electromagnet valve, located at the pipe's entrance to the machine. Any obstruction in the valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!! Good luck!
Sep 04, 2007 | GE WPGT9360EPL Top Load Washer
Open Questions:
Samsung HLN437W 43" Rear Projection HDTV Logo
131 people viewed this question
Henry  Thomas
Henry Thomas
