Question about Frigidaire Dryers
I have a frigidire electric dryer modle #FAQE7001LWO. When i try to start it PAU displays on the screen. I replaced the electronic control board and it still does the same thing. Whats the next move?
  • 90 Answers
SOURCE: Kenmore 11060052991 No start
have you checked the thermal fuse, if bad replace and clean vent.
Posted on Jan 05, 2008
SOURCE: dryer stops shortly after being started
Dust has gathered around the thermostar wtich tells the machine when the cloathes are dry Remove the dust The thermostst is located inside the door on the right hand side it looks like a small nail sticking out
Posted on Feb 20, 2008
  • 1028 Answers
SOURCE: Whirlpool electric dryer runs only when holding start switch
if you've replaced the board replace the relay to right of bd the one with 2 blue wires to ck before replacing just switch relays the other one with red wires controls the heat
Posted on Oct 26, 2008
WRMtech
  • 70 Answers
SOURCE: START AND RUN PROBLEM
check the motor relay. there are 4 wires( 2 are pink and black) this goes to the coil of the relay and must show resistance(closed) you can also jump out the 2 blue wires and see it the unit keeps running. The part number for the relay is: FSP3405281 approx 40.00US
Posted on Mar 01, 2009
Illeagle
  • 525 Answers
SOURCE: commercial dryer coin op programming
Below is Maytag's commercial laundry website where you should be able to acquire the information requested.
http://www.maytagcommerciallaundry.com/content.jsp?pageName=CustServ
Posted on Jul 17, 2009
I have a Frigidaire Affinity electric dryer Model # FAQE7001LWO. . The cycle will start for about 5-7 mins once started and then it shuts off and all lights on the unit start blinking. Please Help!
Google your model number and how to retrieve the error codes. It sounds like either the heating coil or control board is bad. I have a different model that does the very same thing...they run until the cycle tried to turn the heat on then it causes an error. In my case it is the control panel and I decided since mine is old and we are a family 6 (lots of use in it) not to repair it.
Aug 04, 2016 | Frigidaire Dryers
Error code PAU, what it means
The washer is stuck in "pause" mode. You can try pressing the Start/Cancel button to see if that clears it. If not, try unplugging the washer for about 10 minutes to force a reset.
If still no go, suspect problem with door latch/striker switch or failure of a cheap chinese control board. In fact, failure-prone chinese control boards are at the heart of virtually all premature failures of modern appliances. They usually only last just long enough to span the warranty period.
There should be an electrical schematic diagram attached to the back of the unit. You may be able to use that to identify the faulty part. Don't be surprised if the replacement board costs alot more than it's size and simplicity might indicate.
Sep 29, 2014 | Crosley Washing Machines
Runs for little while then stops and has the code PAU on the display. I tried unplugging the cord, I reset the circuit breaker. Still the same and now it won't even start.
Try taking the control board out and check for burned off traces. Solder back those points and it should work again. Just did it to mine and now it runs again. Still flashes PAU though.
Jul 07, 2011 | Kenmore 84072 Electric Dryer
Maytag neptune dryer won't start has power lights will come on but ut won't run flashed PF before it quit
Hello & Welcome to FixYa
PF error code means power failure and is displayed when the circuit board also known as the electronic control board goes bad and needs a replacement. Before replacing the control you can also check the thermal fuse which is inside the rear panel on the blower wheel housing and replace if it reads no continuity. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Start dryer and it quits and displays pf on screen?
The pf is for power failure .If the voltage is correct going to the unit 110 to 120 volts on each leg of the circut. then the issue is with the machine control board not sensing the voltage correctly. and the control board will likley have to be replaced...
Hope this helps with your concern..
Aug 14, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Affinity washer displays ERR. PAU and 43
HI. This is a strong indication of Main control board failure. Essentially, the board is having problems communicating with the other corresponding units in the washer. The necessary actions will be to replace the Main Electronic control board. The part number for your new control will be 137007000. I have also included a service manual for this unit, which will guide you through the replacement procedure. Click here to access the service manual.
The removal process for the electronic control assembly will be located on page 74 of the manual provided. Start on page 73, under "RELEASING THE CONSOLE" and work your way through page 74. Those instructions will help with the removal process of the control board.
Aug 10, 2010 | Frigidaire Affinity ATF7000E Front Load...
82822 / 82824 / 82826 Electric Dryer: kenmore HE2 electric dryer, beeps and all display ...
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 17, 2010 | Kenmore 82822 Electric Dryer
Kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Jun 12, 2009 | Kenmore 82822 Electric Dryer
Whirlpool Duet Dryer GEW9250P (electric)
Here is a list of possible causes. NONE OF THE LEDS LIGHT... Check to make sure that ribbon connectors P3 and P4 are inserted all the way into the machine control electronics board. (To access the machine control, pull the dryer away from the wall and remove the three screws from the top panel on the back. Slide the top panel rearward about 1/2" and lift. The machine control is on the left hand side. P3 and P4 are the "ribbon" connectors going into the board.) A PARTICULAR GROUP OF LEDS DOES NOT LIGHT... A group or combination of LEDs share a common electronic connection. If this connection is open, all of the LEDs in the group will be disabled. If this occurs, replace the entire console electronics and housing. ONE LED DOES NOT LIGHT... Press the button associated with the LED several times. If the LED does not light, the LED has failed. Replace the entire console electronics and housing. NO BEEP SOUNDS... If the associated LEDs do light up, the beeper circuit may have failed on the machine control electronics board. NO DRYER FUNCTION IS ACTIVATED WHEN A PARTICULAR PUSHBUTTON IS PRESSED... If the associated LEDs do light up, the machine control electronics board may have failed. AN E3 ERROR CODE IS DISPLAYED... An E3 error code means that there is a user interface or a software mismatch. It can also mean that a component on the console electronics,or the machine control electronics board has failed. Hope this little tutorial gets you where you need to go. Let us know how it turns out, will ya?
Sep 13, 2007 | Whirlpool GEW9250P Electric Dryer
Dryers Logo
139 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
