Question about Dell Inspiron 1100 Notebook
Switch monitors between a inspiron 1100 & lattitude d600??
Ok my laptop is an inspiron 1100 and the monitor is smashed, I have a lattitude d600 that was given to me for parts. The monitor size appears to be the same, does any one know if these are compatible? If so, how do I go about doing this without causing any more harm to my pc?
  • 176 Answers
Im not sure if the're compatible. The're the same display type ( TFT active matrix) but that would also depend on your video card. Your best bet is to buy an external 15" lcd monitor as you can find one for under $100.
Posted on Jan 11, 2009
Dell Inspiron 1100 screenn is white. Can hear
Chek for loose connections of your screen. Nothing with the equipment, its with the monitor's internal wiring.
Aug 10, 2009 | Dell Inspiron 1100 Notebook
Dell Latitude D600 with video projector
Hi there if you have plugged into your external vga port all you have to do is press fn + f8 that should now show the image on both laptop and external ie projector
Regards Al "alstech"
Display Functions
Switches the video image to the next display in the following sequence: the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, and an external DVI monitor only.
<Fn> + up-arrow key
Increases brightness on the integrated display only (not on an external monitor)
<Fn> + down-arrow key
Decreases brightness on the integrated display only (not on an external monitor)
May 29, 2009 | Dell Latitude D600 Notebook
I-INC monitor to use with my Dell Laptop, no signal to monitor?
When Windows logo disappear on the I-INC, do you still see it on the Laptop monitor?
All laptops have function keys to switch the screen between the external monitor (I-INC) and laptop monitor. On your laptop, it is Fn+F8 key. Press them once and wait for 3 seconds, it will switch the image between 2 monitors (external monitor ONLY, laptop monitor ONLY, and both).
During start-up, do not close the laptop cover. Because it may put your laptop into a stand-by mode and turn off the screen. You need to modify this Power Option setting within the Control Panel.
Mar 28, 2009 | Dell Inspiron 1100 Notebook
Monitor Display on TV
Try the following:
Power up the projector first. With the laptop hooked up but not powered on once projector is warming up begin booting laptop. If there is still no display once its projector is fully warmed up and laptop booted you can try using the (fn) key with the laptop monitor switching function key usually F4 which switches the display monitor to show on external, external and laptop or just laptop. If this all fails try changing resolution of laptop to something that might be more projector friendly.
Let me know how you go.
Mar 23, 2009 | Dell Inspiron 6000 Notebook
Inspiron 1150 lines on screeN problem.
Connect an external monitor to the laptop and see if it also has the vertical lines. If the external monitor looks fine, then your laptop’s LCD display panel is bad. If the monitor has the vertical lines displayed on it, then your graphics card or motherboard is bad.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 10, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Inspriron 1100
laptops are very specific about what you can replace parts with.
Take it back to where you bought it and ask to exchange for a 14 "
If you want to see a bigger picture on that laptop the only way is to plug in an external monitor; in the back there should be a plug for an external monitor. Plug this in to any computer monitor. You will have to adjust the resolution.
May 13, 2008 | Dell Inspiron 1100 Notebook
Laptop monitor has a big black spot
If it is actually booting, then you should hear some beeps as it starts, if there are actual problems with the system &/or hard drive.. You need to count the beeps & report them here, so we can decide what the problem is.. If the system is starting up ok & it's a screen related fault, the easiest way to test is to connect an external monitor, via the external monitor port. Most laptops have them. In fact I know the Dell 1100 does. Once you have connected the monitor, there is a sequence of keys on the keyboard to press, to switch to the external monitor. This will prove where the problem is..
However, I have some sad news for you.. Apparently there is a law suit against Dell (Class Action in fact) for overheating CPUs.
I think your 'video' problem is most likely because of that, then a faulty screen. There is a rather complicated procedure for fixing the problem here:
This something you should really think about doing, if it's already not too late. I know it looks complicated, but if you know someone who knows how to use tools, it should be done.
Also, if you want to join the class action.. Here it is:
Lots of luck with all this. Feel free to talk if you need help.
May 03, 2008 | Dell Inspiron 1100 Notebook
Laptop to pc
If it's you're intent to hook up a monitor to you're notebook, go ahead. The notebook screen will automatically display on the monitor.
Apr 27, 2008 | Dell (04U621) for Latitude D600, Inspiron...
Starting up Dell Lattitude D600
Hit F12 as soon as you see the Dell Logo...... then pick CD/DVD Rom....
Jan 07, 2008 | Dell Inspiron 2200 Notebook
Inspiron 1100 monitor
Any of the system LEDs come on when you turn it on? Can you hear the hard drive spin up? What was the original problem that lead you to clean the laptop fan? Please post the answers and any other pertinent information and we?ll start up.
Mar 07, 2007 | Dell Inspiron 1100 Notebook
Dell Inspiron 1100 Notebook Logo
64 people viewed this question
Alun Cox
