Question about KitchenAid Food Mixers
Put kitcheraid meat grinder back together
After taking the grinder apart for cleaning, I cannot seem to get the parts to fit right
  • 145 Answers
Proper assembly of the Food Grinder Attachment is covered in the attachment's Use and Care Guide.
Posted on Jul 08, 2009
Was using a spatula to push meat down into the grinder and it is now stuck how do I fix?
Either muscle it out or get to the motor from underneath and manually turn it in opposite direction to free up the item.
Aug 12, 2016 | Food Mixers
How to use food grinder attachment
The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Mar 04, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
Where can I get the service manual for this model?
Hi, Bricklayer.
You can find the parts diagram here: http://www.mendingshed.com/ka6pro.html
And you can order replacement parts there.
How old is your mixer? There was a time that they shipped with a plastic gearbox, and it frequently failed. Kitchenaid went back to all-metal parts after a while.
I have the same issue, but there were no parts - just an attachment drive gear that does not turn.
Mar 22, 2013 | KitchenAid KP2671 Professional 6 Series...
The machine seems loose and it rocks. Also, the pasta attachment (meat grinder) will not lock in. Can I adjust where the grind worm goes in?
Hello Darlenescott,
About the machine rocks, the whole machine rocks or just the Head? If it is just the Head you may want to check to see if the set screw that holds the lock in place is still there or lose. The scress is located on the right side of the machine if you are looking straight at it in use. It is at the bottom of the head close to where the head attaches to the pedistool. If it is missing post back to this discussion and I will find the part # and place that you can purchase the part.
The second issue, the pasta attachment is not locking in properly. There is no way to ajust how the pasta attachment fits. I would try and return the attachment and exchange it for another as they are mass produced and may not have got the shaft down to the proper tolerances to fit.
I hope this helped and please post any other questions you have to this thread.
Thank you for choosinf FIxYa for your solution.
Mar 06, 2011 | KitchenAid Artisan Series Tilt-Head Stand...
The attachment for grinding meat on the front wont work ? mixing arm in bowl works fine ! why wont it engage?
Firstly I would check it is fully engaged. If it is, remove the food grinder and look into the hole. You should be able to see a square hole inside. Turn on the mixer, the square hole should spin, if it does not, one of the gears inside the head has most likely broken. To repair this you will need to take the head apart.
The other possibility is that I misread your problem and that the grinder is turning, but the meat wont go through the plates at the end. This is a common issue which happens if the blade is not put in the end of the grinder. The blade is shaped like a cross and cuts the meat when it reaches the end of the screw.
Jan 25, 2010 | KitchenAid K45SS Classic Stand Mixer
Older A200 Reessembly
just did mine a200f. try this, if all gears are in line place bearing cap back on planitary this is the cap on top. this should hold bearing in check from moving up and down. if this works for you remember not to over tigthen bottom jam nut, lower end should move freely. post to let me know if this solves your problem. Harry Ooooooooo
Jan 13, 2009 | Hobart A200 Stand Mixer
Black Residue on meat using Kitchenaid meat grinder attachment
This is a common issue with the Kitchenaid food grinder. The black residue is a product of the meat itself.
With Kitchenaid Food Grinder Attachments, it is recommended that the meat be partially frozen before grinding. This is to ensure a quality grind and to make sure the meat holds all its juices while grinding.
If any juices from the meat are leaked into the food grinder, the friction will cause a chemical reaction and turn the juice from the meat into a black substance.
Dec 17, 2008 | KitchenAid K45SS Classic Stand Mixer
My kitchenaid sausage maker does not stuff the sausage casings
This may be a problem with assembly of the Sausage Stuffer Attachment. Your Use and Care Guide for both the Food Grinder and Sausage Stuffer could illustrate the assembly for you in detail.
Also, it may take up to 4 minutes after meat is fed through the top of the Food Grinder for it to start stuff into the casings. The meat is fed into the Food Grinder, ground, and then pressure is built up behind this ground meat to push into casings.
Jun 01, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Food Mixers Logo
297 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
