I would like too rest my laptop back to factory specs i tried too backup the system but did not work
  • 142 Answers
When you go to the system restore menu, (after pressing f10 on the loadup screen) you can select how far back you would want to restore your computer to.
Posted on Jan 11, 2009
My Dell Inspiron r15 n5110 will not reset to factory settings
it may of lost its backup windows system if it has then you will need to try and backup your system using discs.
May 25, 2014 | Dell Computers & Internet
I want to restore my Acer AOA 150 ( mini netbook) to factory default setting. The problem is that Acer Recovery Management is not working. when i click on it No action it takes plz tell me the...
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer mini notebook to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer mini notebook to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer mini notebook is reset to factory settings.
Tips: You can also create a backup copy of your notebook data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Dec 25, 2010 | Acer Aspire One AOA150-1504 Netbook
How to reset back to factory settings
To reset your laptop to its factory state you need to restart or turn it on, then just tap F10, It will ask you on how would you loke to restore then select Restore system to factory settings. Usually it would ask you for a password just etern six zeros "000000" it should work. Please wait until the restore process is completed.
Note: All data will be deleted so make sure you back up them first before you do a Restore to Factory Settings
Thanks for using Fixya
Aug 01, 2010 | Acer Aspire One PC Notebook
Im trying to reset my acer to factory settings and evreything i try will not work. how do you reset the laptop to its factory settings
In order to reset your computer to factory setting you have to have the system restore disk and put it in your cd drive and reboot your computer with it inside... after pc boots up, a screen should popup click on restore to factory settings... if you dont have a disk reply back and i can give you a link for download..
Jun 10, 2010 | Acer Aspire 3000 Notebook
I have ran into a problem with my Acer Aspire 7520g. I started the laptop as usual and it started no problem. I then left the room and when i returned the laptop was switched off. When i now try to boot it...
Ok, you need to boot from your DVD with a Widows, install boot disc, inserted, and boot up on that DVD, then do a startup repair. OR... Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
May 22, 2010 | Computers & Internet
My acer aspire 4315 stuck at boot with white screen, when using external monitor it show acer boot screen and stuck there. I can press F2 for setup but nothing happen.
http://tim.id.au/laptops/acer/aspire%204715z%204315.pdf
Above is a link for your Service manual, inside is everything you need to know to troubleshoot and repair your machine, this is the manual that us engineers use to repair these units.
This could be your HDD, failed. Work through, the troubleshooting procedures.
Anyway try this below first. Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
May 14, 2010 | Acer Aspire 4315 Notebook
I want to reset it
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
Apr 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
Recovery doesn't work on either user or factory default
send back to the factory they can reimage it aka reinstall the os on there and u can start working with it again
May 22, 2009 | Computers & Internet
Can't restore to factory spects
Beat me to it pontelemon.....lol.
Just as the Guru said and mine is...see below.
Restore and recovery
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
4 Follow the instructions on screen to complete the process.
Apr 09, 2009 | Computers & Internet
Acer laptop restore factory settings?
If windows is running you can start it by going to Programs, Acer Empowering Technology and run the Acer eRecovery Management. Note that on the bottom of the eRecovery Management window are 3 choices, Backup, Burn Disk and Restore. Click on Restore. Here you have the choice of select Restore System to Factory Default.
If windows is not working but the system boots -
Reboot the system and when the Acer logo appears, hold down the ALT key and press F10. This starts the recovery process, just follow the instructions.
Oct 19, 2008 | Acer Aspire 5050-3242 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
