Question about Vacuums
VAX POWER 6 PET...BACK FILTER CONSTANTLY BLOWING OFF....HOW CLEANED FILTERS NO CHANGE
Back filter blows of every few minutes....have cleaned filters but this did not help
  • 25 Answers
SOURCE: Hoover Light on
ALTHOUGH MOST FILTERS SAY WASHABLE THEY DO STILL NEED TO BE REPLACE AS WASHING THEM SHRINKS THE FILTER AND EVENTUALLY CLOSES THE AIRWAYS. WHICH ALSO IF NOT REPLACE WILL OVER HEAT MOTOR IN MACHINE AND CAUSE MOTOR FAILURE.
Posted on Mar 27, 2008
SOURCE: shop vac
Vacuum is less than a year old and died in the middle of a use. No power... tried to plug it into 3 known, good outlets. Suggestions?
Posted on Jul 06, 2008
  • 5 Answers
SOURCE: vax 2400 perfomance pet overheating??
take it in to get looked at! it could be a elec. short which might cause an accident(ie. fire, shocking, explode....)
Posted on Feb 19, 2009
SOURCE: My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Posted on Apr 23, 2010
SOURCE: vax 2400 performance pet overheating
Unfortunately there is no permanent solution.It is a terrible vacuum cleaner and im getting rid of mine today. I have been maintaining it for 6 months cleaning filters , swapping filters, swapping carbon brushes all to no avail.Dump it. it would'nt **** the air out of a balloon.
Posted on May 02, 2011
Blowing noise when after a few minutes of switching on a dyson dc07
Hello, where is it blowing to/from? Take out all the filters and run the machine without them, did it go away? Is you bin empty? Have you cleaned out the cyclone recently/ever? (See Youtube, "DC07 cyclone") are all you pipes clear? Is there a hole in the flexi hose in the beater head? Does it blow in the upright position as well as the vacuuming position? Pull off the access parts and check them for a blockage.
Checking these things will help find the problem, also try another cyclone unit from a friend and check results.
Feb 01, 2015 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vax power midi 2 , exhaust filter keeps blowing out of machine
Usually a filter blowing out means it is clogged and needs replaced
Jan 04, 2014 | Vacuums
Can anyone help with an older Euro Pro EP055, It has very little suction.
Cleaning filters on a bagless vacuum helps but filters should be replaced frequently, as often as every 3 to 6 months on some vacuums. Foam filters aren't as critical to replace because the pores are very large (which also means they don't filter out the small particles) so they don't clog as easily but paper filters have much tighter pores which become clogged and restrict the airflow. Cleaning paper style filters with water which can pack the fine dust into the pores clogging the airflow even more.
I recommend replacing filters st least onceor twice per year and cleaning them after each use for best performance and longer vacuum life. Blowing the dust out with an air compressor is my preferred method.
Changing filters frequently on a bagged vacuum isn't as critical because the bag collects most of the fine dust, dirt and gunk. The surface area of a bag is much greater than that of a filter so a bag is less likely to get clogged than a filter. Most homeowners change the bag once per month which keeps the air flowing smoothly.
Sep 30, 2017 | Euro-Pro EP055 Bagged Canister Vacuum
The vacuum i've had for 6 months has very liittle suction power. checked that the belt is on. cleaned filter. checked to see if hoses were clogged. I used a super vac to suction any debris out of...
as this unit has 3 filters on it, a lot of people forget about the one filter that will cause all of your trouble here.
There is the exhaust hepa filter, no problem, your unit is pretty new, it shouldn't be a problem.
There is the circular filter in the chamber where all your dust and debris collects. It is in the top portion and will come out with a twist. This filter is washable. Warm water and no soap.
The third filter, and this is the one that is most commonly overlooked, is just below the dirt container you can take out and clean. It is in a grey "tray" that pulls out and the sponge filter is in the tray. As a word of warning, it is probably pretty dirty. Again just wash it, warm water no soap, and you should be good to go.
PLEASE make sure that the filters are DRY before putting them back into your machine.
Good luck.
Nov 05, 2010 | Bissell Upright Vacuum - The Pet Hair...
My Hoover runs for a few minutes and shuts off.
It's possible the thermal reset is defective. It shuts the motor off if it gets hot. Remove the bag door and take the bag off, remove both filters and then turn the vacuum on, just leave it sit there with the motor running. This eliminates the bag or filters causing any airflow resistance. If it still shuts off after a few minutes it's likely the thermal reset is bad. Some vacuums have an external thermal reset button which can be replaced if necessary but on your model it is built into the motor and you must replace the motor. If the motor runs fine put the bag and the filter under the bag back in - (make sure the filter is clean and not restricting airflow) put the bag cover on then turn it on again. If it overheats and shuts off then you may have a clog on there somewhere restricting the airflow. If so check the power nozzle area, the hose coming from the power nozzle, the extension hose and wands for clogs or restrictions.
Sep 22, 2017 | Hoover U6426-900 Bagged Upright Vacuum
Envirovac kicks debris back at my feet and is loud
It's clogged!
Many so-called "environmentally friendly" vacuum cleaners have multiple stage filters; the usual configuration is a standard filter followed by a HEPA filter or equivalent. Standard filters can be a paper bag or a bagless, removable container.
From time to time, the secondary filter will get clogged, so it doesn't matter whether you change the bag or empty the container, performance will not improve.
If you have access to compressed air, try removing the secondary filter and blowing it clean with a high pressure air nozzle. If that doesn't work, check the hose to make sure it's clear. If you are using a rug beater attachment, make sure it has not clogged at its inlet.
Sep 06, 2009 | Eureka High Filtration s Mighty Mite...
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
Vax 2400 performance pet overheating
Jan 29, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
360 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
