Question about Ricoh Office Equipment & Supplies
Disconnecting Ricoh finisher
I have a Ricoh 9001 copier and a Ricoh C6000. I need to move them to a different spot. How do I disconnect the finisher from each copier.
5 Suggested Answers
NALDZ
  • 38 Answers
SOURCE: Ricoh Aficio 450 copier
FINISHER MEANS... A STAPLE SECTION...IF YOU DO NOT WANT TO USE THIS UNPLUG THE PINISHER... REMOVE THE WIRE WERE CONNECTED.
Posted on Jul 06, 2007
goalie39
  • 469 Answers
SOURCE: Ricoh Aficio 220 - moved copier to clean behind
Check the power cord, make sure you have not just pulled the copier end out of place. the power cords are often replacable and can pull out of the copier.
Hope this is of some help.
Ed
Posted on May 08, 2009
  • 990 Answers
SOURCE: detach RICOH SR790 Finisher
Hello sir; Open the finisher door on the mid of right hand side ther have a cross bar fasten by one screw, loose the screw pull out the cross bar, it will detach from the machine.
Posted on Aug 14, 2009
Testimonial: "Thank you very much for your assistance. Simple when you know how ! WOuld be nice if Ricoh supplied this type of information direct to people."
  • 149 Answers
SOURCE: error 0000500-0000. Finisher error. Ran through
sounds like the DC controller and or the Finisher controller have gone bad. Unfortunatly there is no easy fix for this problem. you will need to get someone out to have them checked but if you leave the finisher off of the copier it should still work so at least you can make the copies.
Posted on Jun 11, 2010
Testimonial: "Very good information. Also the most cooperative source I've encountered. Great guy!"
Sc 995 ricoh mp4500
This error code can mean several things. However the most likely problem has do do with the finisher attached to the copier unit. The finisher may have been disconnected to the bridge unit or lost power. Check your connections to the finisher and make sure it latched to the main unit properly.
If you live in Southeast Florida Advanced business computers is a great source for help. Computer network repair, printer and copier maintenance repairs, leasing and supplies.
Oct 24, 2015 | Ricoh Office Equipment & Supplies
I have moved my ricoh mpc3500. Now the paper will not go into the finishing unit. can you tell me what to look for?
Try to disconnect all the paper trays, clean the rollers that pick up paper and reassemble the unit
Nov 27, 2014 | Ricoh MPC3500
How do I disconnect finisher for Canon IR3300. Can I get a picture of the specific part?
Disconnecting the sorter if you have the external finisher is easy. Just follow the cable from the finisher/sorter to the copier and unplug it. However, if you have the internal type sorter, the disassembly to remove / disconnect it is quite involved/difficult. You'll certainly need a tech, if that's the case.
Sep 02, 2014 | Office Equipment & Supplies
I want to relocate my Ricoh Aficio MP 3300
disconnect the finisher reset it and then it will be a monster roll
Jan 05, 2014 | Ricoh SR 790 - Finisher - 1000 sheets -...
Ricoh aficio mp c6000 factory reset
1. Press the * key and the # XXXXX on the Ricoh copier at the same time and hold for 10 seconds.
2 After 10 seconds or so, the printer will restart itself and will be factory reset.
Dec 09, 2013 | Ricoh Aficio MP-C6000
I have a SC564 code with Ricoh Aficip C6000...can anyone help??
check power supply board or replace tirmistor and thermostatic sometime lamp could be week
Nov 26, 2012 | Ricoh Aficio 2022 Black and White Copier
MY RICOH AFICIO MP C6000 IS SHOWING AN ERROR CODE SC326
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Mar 05, 2011 | Ricoh Aficio 1035 Copier
Second hand Ricoh FT7950. Paper wont feed from
Going strictly from memory as this is an older model.
With the machine sitting ready to make a copy open the finisher door and close it . Are there any signs of life ie rollers spin tray moves stpler homes up?
IF yes I would look at the finisher entrance sensor as these get pretty dirty ith paper dust(or could be out of alinment from moving.
IF No then I would look at the finisher connector inspect for any damage .
Hope this gets you in the right area
Apr 03, 2010 | Ricoh FT7950 Copier
Detach RICOH SR790 Finisher
Aug 14, 2009 | Ricoh Office Equipment & Supplies
37 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
