Wiring digram for colman brc00421bd central ac unit
22yooper
  • 828 Answers
SOURCE: I have a colman ac
On my computer screen these two problems are not the same.
To "garys2003" Clicking you hear is the contactor closing in calling for cooling. If no power is being supplied to the outside unit high voltage the unit will not run. Check your circuit breaker or fuses in the outside power box. If the outside power box is of the non-fused disconnect, check that the disconnect is inserted properly.
To Trenina: Is your unit a self contained unit outside ducted to the inside as with a Mobile Home. If so your evaporator cooling coil may be frozen over stopping air movement, turn the cooling off and set your fan to on until it defrosts, then return to normal operation and leave the fan on during cooling.
If nothing comes on inside as with a central A/C system you may have a problem with the blower motor itself.
Posted on May 13, 2008
bobicehouse
  • 1524 Answers
SOURCE: Real unit won't come on
Visit www.bcaparts.com
Posted on Apr 27, 2009
  • 12 Answers
SOURCE: intertherm central heat/ac unit has power but nothing will work
your contactor coil might be burned out
Posted on May 01, 2009
  • 3074 Answers
SOURCE: I installed a new colman mack thermostat in my
if it is a programmable thermostat you can unhook thermostat and when it comes on select 3 instead of 1. As it sounds as though it is short cycling this happens in older houses with drafts. Hope this helps Tim
Posted on Sep 07, 2010
SOURCE: need wiring diagram ,colman central
I have the diagram pasted to the cover over the sequencer. I only have a 5 megapixel camera, but I am willing to try and get a picture of it if it will help.
Posted on Jan 01, 2011
Hi, I have an older mobil home with a Colman AC
Your unit uses both the capacitor and a contactor (relay) to start your compressor and motor. With the indications you are giving it would either be the capacitor or the contactor - and since you have already changed the cap - then replace the contractor!
NOTE: We always recommend that you change the capacitor and relay at the same time, because they seem to fail at about the same time.
Jul 28, 2011 | Coleman Heating & Cooling
Need wiring diagram ,colman central electric furnace 3500a816
Nov 03, 2010 | Coleman Heating & Cooling
I installed a new colman mack thermostat in my camper witch has a colman ac unit now ac unit runs 5 min then shuts off for 3 min then starts again and keeps doing this . so I by past thermostat and it will...
Sep 07, 2010 | Coleman Mach III Air Conditioner
Colman evcon ''B'' relay connection on new programmable t/stat
Hello The B wire now goes to the O termnal on new thermostat.
Apr 03, 2010 | Coleman Heating & Cooling
Colman unit is getting no power
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Sep 10, 2009 | Coleman Mach III Air Conditioner
Goodman CK30-1A Central AC Unit will not run by thermostat
double check your t-stat wiring your not getting 24volts to the contact at the cond. unit outside
Jun 20, 2009 | Heating & Cooling
No cool air
It is the capacitor write down the wiring colors to the capacitor and then disconnect the safety disconnect on side of house. And even turn off the breaker to the condensing unit. Okay now that no power is going to the unit take out the capacitor you wrote down what wires went where and ohm out the herm side go from the center post to herm side. Should be bad wont get a reading. Get new capacitor and re install. good luck ken
If not capacitor get back to me. And please leave good feed back
Apr 29, 2009 | Coleman Heating & Cooling
Apr 27, 2009 | Heating & Cooling
I have a colman ac unit and the outside unit will not come on. i hear it clicking but nothing happens
May 12, 2008 | Heating & Cooling
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
