Question about Zoom Music
Zoom r8 microphone issue
I have tried a condenser and two dynamic mikes, but the silhouette hiss still prevails. the ZNR is effective at eliminating background hiss but does not get rid of the mentioned after hiss. I have tried reducing the treble frequency but this after a certain point destroys the clarity.I don't know whether this is an inherant fault or if there may be a solution.I would appreciate your comments.
  • 5603 Answers
SOURCE: Some Headphones have an inherent
Hiss is a problem of statistical noise in electronic devices due to the laws of physics plus circuit design.
One thing to do is to improve the signal to noise ratio (SNR) by properly setting gains. It is POSSIBLE that the IEM's you are using are too low impedance for the receivers resulting in you having to use excessive gain at the receiver. Your receiver gain control should not have to be above 60% of the way up. If you are above that, the ear buds are probably lower impedance than the receiver is designed for... and remember the manufacturer will LIE on the capability of the thing they are trying to sell.
The receiver is speced at 32 ohm drive... IF your ear buds are less than that impedance, they are NOT suitable. Conversely if they are too high, thaat will ALSO cause you to turn up the receiver gain too much and result in poor SNR.
You want to make sure the transmitter is being driven at line level so receivers get adequate input audio so gain doesn't have to be run too high.
Posted on Jan 04, 2011
  • 5603 Answers
SOURCE: I feel that the 'normal'
No, that will not help. The his is a function of the receiver NOT receiving a signal from the transmitter as they apparently do NOT have a "squelch" circuit to mute the receiver noise when no signal is being received. The noise level when no signal is received is pretty high and apparently the volume control is not enough to reduce the hiss.
To solve this, LEAVE the transmitter ON and make yourself a switch at the receiver. DO this using one of those little in line lamp switches that fit on zip cord. Make one on a short length of zip cor with mating connectors to fit the received jack and the headphone plug. Don't worry about unshielded wire as the impedance is very low. Then you use this switch to mute the headphones when you want to. There are other switch types you can use, I am just suggesting what might be readily available to you.
Sennheiser SHOULD have include a mute switch on their unit as turning the power off on the receiver would be a pain. They could have used a volume control with switch to kill the audio line out... simple solution... oversight on their part.
Posted on Mar 25, 2011
  • 28 Answers
SOURCE: i am using the SL
Your dynamic mics should be fine, phantom power provides one positive 48 volt potential to one side of the coil, and a negative 48 volt potential to the other side of the coil so your mics will effectively see 0 volts as these potentials will cancel each other out ( hence the name "phantom" power).
so provided that your microphones are wired properly internally, and your xlr leads are in good condition you will not damage any of your equipment.
I hope this has been helpful
Posted on Apr 03, 2011
  • 5603 Answers
SOURCE: im using a behringer ucg102
Try this using a differeent computer. Some computers generate a lot of digital noise. Also use a lot of gain from the guitar to improve the signal to noise ratio.
Posted on Jul 24, 2011
mrwtech727
  • 75 Answers
SOURCE: My Behringer mixer Eurorack UB802
Here's the manual. page 8 Good Luck!
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000064843.pdf
Posted on Sep 03, 2011
Why zoom g2 point blinking ?
There is damage/burnt at Transistor Q4 or Q3 or both. Usually followed by R8. Replace it.
Q3 = BC337 (SMD marked as 6C) NPN.
Q4 = BC327 (SMD marked as 5A/B/C/D) PNP.
R8 = 470 ohm (SMD marked as 471).
May 06, 2014 | Zoom G2 MultiEffects Guitar Pedal
Casio wk-7600: I just purchased it and trying to set it up. I connected a dynamic mic. in "mic. in" slot as the user manual described. The mic. didn't amplify my voice. Do I have to configure the use
Use only DINAMIC microphon (computer microphons are not dinamic- they are condenser-electret) with MONO jack.
1. Turn knob (beside "mic.in") "mic.volume" (T-7) full clockwise.
2. Press "MIXER" (C-7).
3. Press "<" (R-17) while is shown "MIXER PART>:EXT(M/I)
4. Set (check) Part [ ON]
Volume: [80...127]
N.Tresh [0]
If after microphone disconection there is a noise from speakers - set
PART [off] or N.Tresh [20] (or higher))
Jan 12, 2014 | Casio Music
I am using the SL 2442FX -pro, my question that if i turn on the phantom power switch and i'm using 15 dynamic microphones and only 1 condenser does it affect the performance of the dynamic mics?thank...
Apr 03, 2011 | Behringer XENYX 2442FX Mixer
My new SWR workingpro 12 has a low frequency permanent noise, any idee ? Maybe from the Power supply... Thanks, bolliger_rudolf@bluewin.ch
All amps make a small amount of noise (system hiss) but the amps own power supply should not cause a problem on it's own.
However if the frequency is around 50hz (the G 2 1/2 octaves below middle C on a piano) it is most likely due mains electricity interference or an earth (grounding) issue.
Here are a few things to try to identify the source.
  1. Could be a lack of earth (grounding) This is potentially VERY DANGEROUS and could result in electric shock if you touch a metal part of the amp or touch some other metal object (like a microphone stand at the same time as your guitar strings). Check the earth wire is firmly attached at both ends of the power supply lead.
  2. Could be a defective mains socket - try plugging it in to a different one, preferably on a totally separate circuit.
  3. Could be an earth loop. These can occur if you are using the amp with an output to a public address system or mixer that is also earthed because of a 'potential difference' between the two earths. Solution - use the balanced (xlr) output which incorporates an earth lift rather than the unbalanced jack output.
  4. Unplug any effects pedals, foot-switch etcetera to see if that eliminates the problem. Turn off any internal effects, including bass intensifier.
  5. Make sure any signal cables (guitar leads) have good quality screening and that the screen is well soldered to the jack plugs at both ends.
  6. Ensure signal leads do not lay along side (parallel) close to mains electricity cables but are well separated and only cross at right angles.
  7. Move the amp away form other electrical equipment that may have a powerful magnetic field (especially CD or DVD players, hearing loop amplifiers, radio microphone transmitters / receivers, mobile phones
  8. Turn around or stand in a different position - it might simply be the pick-ups in your guitar causing interference in the magnetic field of the power supply.
  9. Does plugging in or unplugging a signal lead / guitar make any difference? This particular amp requires only mono jack plugs a stereo (trs) plug may be shorting across terminals
  10. Does it change when you touch the strings with your hand? If yes check internal wiring and screening within the guitar.
Feb 09, 2011 | SWR Workingpro 12 200watt 1x12" Bass Combo...
Buzzing noise when not playing
All amplifiers make a little bit of noise (hiss) but it is normally slight and drowned out by playing. However, assuming that this is not normal system hiss, here are a few simple steps to try and locate the source of the problem by process of elimination.
  1. SAFETY FIRST - a common cause of a humming or buzzing sound can be a lack of earth (grounding) on the mains supply. With a 240volt AC supply this hum will be at 50hz (in the UK) - frequency may vary in other countries but should be similar. Check the earth first because of risk of electric shock. Until you are satisfied that this is not the cause of the problem DO NOT touch any metal parts of the amp. Remove the mains lead and try a different one. Try plugging the amp into a different mains outlet socket (preferably one on a completely different circuit).
  2. Turn off other electrical equipment in the vicinity that may be causing interference. Move the amp a bit, try rotating it by 90 degrees to change relationship to things like mains electric cables in the floor.
  3. If you are using the line-out socket to give a feed to a mixer, slave amp or p.a. system unplug this. Sometimes double earthing (through the mains lead of your amp AND the mains lead of the MIXER / PA) will cause an 'earth loop' due to a different resistance at each end. Putting a DI box with an 'earth lift' in between may eliminate this problem. Alternatively there are little gadgets you can buy to do this (I found one intended for car audio systems on Amazon that works very well)
  4. Unplug any instrument leads - to eliminate possibilities of interference affecting cables, effects pedals or guitar pick-ups. Also unplug the foot-switch.
  5. If that stops it plug a lead in without a guitar on the other end - does the noise return? If yes change the lead. If no plug the guitar in.
  6. Try moving the guitar in relation to the amp (turn it around 90 or 180 degrees) - this will be pick-up to amp power supply interference.
  7. Does the sound get better or worse if you touch metal parts of the guitar with your hand? This may be a screening issue within the lead or the guitar itself.
  8. Try turning all the individual channel tone and gain controls to zero, turn off any effects on the amp panel. If that eliminates it only turn up the controls on channels that you are actually using.
Jan 30, 2011 | Marshall Amplification Marshall MG50FX 50...
Hi my zoom g1x fx is having some sound issues,it creates unpleasant noises and the sound kinda fades. I noticed the fading of the sound when i'm picking the thinner strings but it sounds so loud on the...
Hello I have this pedal too and have experienced similar problems..
If you are using battery power only use Duracell Ultra (or equivalent) never re-chargeable batteries. However I am assuming you are using the mains power adapter rather than batteries.
Start by eliminating external issues. Change your guitar lead and output lead - if you don't have spares swap them over or swap the ends round to make sure it is not a contact issue in the jack sockets.
I found this problem occurred most often when I was using headphones plugged directly into the pedal rather than an amp. I was usually able to solve it by wiggling the output jack plug slightly so came to the conclusion that it was just a poor quality plug or socket.
Having said that I think that there might be a bug in the processor unit itself because I have occasionally experienced the problem when playing through an amp. I resolved it by unplugging everything and starting again but this is a bit annoying either during a gig or half way through a recording session.
Does it do it on every patch or only on some? I have one patch that is completely clean (straight through) with no effects, noise reduction, boost, with the tone set at flat. You could try setting a patch like that up as a comparison and see if it still does it.
Lastly you could try recalibrating the expression pedal.
  1. Unplug the input jack to turn the unit off.
  2. Hold down the pedal assign button whilst plugging the input jack back in.
  3. The display should read 'dn'
  4. Raise the pedal fully and press the store key
  5. The display now reads 'UP'
  6. Push the pedal fully down to the stop and then release it (it will return slightly)
  7. Press the store key again
  8. Job done (unless the display reads 'Er' - in which case repeat from step 4)
Jan 30, 2011 | Zoom G1x Guitar Multi Effects Pedal with...
Only a dynamic mic works on my lap top not condenser mic
Make sure the 48 volt phantom power is on.
Remember this preamp has TRS BALANCED output. If you run this with a stereo adapter into your laptop, the signal and the inverse will be sent into the L and R channels of your laptop and they will CANCEL!
You need to use a special cable that takes say just the tip of the cable from the ultragain connecting to BOTH the left and right inputs of your laptop.
Sep 21, 2009 | Samson Audio C01upak C01u Microphone and...
Music Logo
Top Zoom Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Barry Webster
Level 1 Expert
Are you a Zoom Music Expert? Answer questions, earn points and help others
