Question about Baumatic BMM174SS 1150 Watts Microwave Oven
I am replacing a broken Baumatic BMC255SS with a new one (like-for-like). The broken one is installed into my kitchen cabinet with a flush fit stainless steel effect surrounding plate and I cant see h
I couldn't find the BMC255SS model on this site so chose a model that has a similar surround plate
My kitchen aid micro wave stopped heating the food. Everything seems to be working. Model Khms155L. I want to replace it but it is no longer in production. Is there a replacement model that is an exact...
Take your measurements and compare them to the measurements from various microwaves online, then go to the store that has the same measurements. I wouldn't use the microwave for fear of a fire.
Dec 25, 2014 | Microwave Ovens
How do you remove the front panel on BMC255SS
Try emailing them: technical@baumatic.co.uk
Nov 03, 2014 | Baumatic Microwave Ovens
I want to replace oven
If you are wanting to know who to replace the unit then I think I can help. If this unit is above the kitchen range then there should be a cabinet above the oven. You need to look there for 2 bolts that go thru the cabinet floor into the microwave. have someone there to help hold the oven as you take out the bolts and the oven will come down it is also in some cases hanging on a lip on the back of oven so let it down slowly. There should be a plug in the cabinet as well so you will need to unplug it. Installing the new one is the reverse.
Apr 28, 2014 | Goldstar MV-1501 Microwave Oven
Replace bulb
You must remove the metal cabinet around the oven, there are machine screws on the back and on the sides, take them out and the cabinet slides off. Make sure you unplug it well before you start work to replace the bulb.
Jun 21, 2012 | Baumatic BTM24 Microwave Oven
I've repaired my (R1460A, over the range, black) mwave several times, after having new cabinets and ceramic tile installed. I want to purchase a new one that will fit the existing wall mount and...
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Ask them about a "drop-in" replacement.
May 26, 2011 | Sharp R-1460 Microwave Oven
My Kitchen Aid Microwave Model no. KHMS155LBL 0 has a broken rack support hook on one side. There are four hooks which snap into a square hole on each side of the microwave cabinet to allow the...
The part you're looking for is Whirlpool number 8204662. Several sources came up from a Google search. Here's one. I've never done business with this site, but their price was the lowest of several I looked at.
Apr 30, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
One stud in the middle for an OTR Microwave Install?
i had the same trouble, yes i used a solid bolt to hold the microwave bracket in the stud then used the biggest toggle bolts that will fit, also the cabinet will not have to be changed. it works fine, if you had a vent a hood dont forget to hook up the exhaust vent. i figure your old exhaust vent is in the cabinet like mine was
Dec 31, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Just purchased house..custom cabinets in kitchen...cabinet for microwave measures..25 1/4 " across..17 1/2 " height and 18 1/2 deep..I have purchased a PEB2060DMCC in bisque and a trim kit...
I would suggest that you contact GE Customer Service here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Aug 01, 2008 | GE Microwave Ovens
Remove built in microwave Baumatic BTM231SS 900 from cabinet
Hi Brunie1,
They are on popers so with a knife being careful not to bend either knife or surround gently prise 2 strips either side of door. this should then reveal the 4 screws
Mar 25, 2008 | Baumatic BTM231SS Microwave Oven
Installation Advice
The trim kit would be passively vented. I would contact the manufacturer's customer service peoiple for details. You may also need to ask to speak to a technician if the customer service folks can't fully answer your inquiry. See http://www.baumatic.co.uk
Apr 18, 2007 | Baumatic BTM25SS Convection Microwave Oven
Baumatic BMM174SS 1150 Watts Microwave Oven Logo
35 people viewed this question
Top Baumatic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Baumatic Microwave Oven Expert? Answer questions, earn points and help others
