Question about Dell W3706MC 37 in. LCD HDTV
Need class D audio amplifier module for Dell flat screen model W3706MC
Module has following I.D. BM-01 E226252 3104 137 0009.2 3104-133 3009.4 Called Dell, they no longer stock. Advice: never buy Dell TV.
That's being specific lol I have the same board what other info do you need?
Posted on Sep 13, 2016
2 Suggested Answers
  • 127 Answers
SOURCE: Dell Tv W3201C Audio Amplifier Module Picture
Please be clear.Can you be more specific?
Posted on Nov 01, 2012
On 05 chev Tahoe 2 wheel drive it want crank code co292 what do I do to fix it
C0292
Lost Communications with Engine Control System
EBCM
DTC C0290 or C0292 in Antilock Brake System
Your best bet ! Take it to a quaified repair shop . Do you know what Class 2 data bus is ?
Class 2 Serial Data Line
The class 2 serial data line on this vehicle is a star configuration. The following modules communicate on the class 2 serial data line:
• Audio Amplifier, w/UQ7 and Y91
• Body Control Module (BCM)
• CD Changer (CDX), w/U1S and Y91
• Digital Radio Receiver (DRR), w/U2K or U2L
• Driver Door Module (DDM)
• Driver Seat Module (DSM), w/AN3
• Electronic Brake Control Module (EBCM)
• Electronic Suspension Control (ESC) Module, w/Z55
• Front Passenger Door Module (FPDM)
• Generator Battery Control Module (GBCM)
• HVAC Control Module
• HVAC Control Module - Rear Auxiliary
• Instrument Panel Cluster (IPC)
• Powertrain Control Module (PCM)
• Radio
• Rear Seat Audio (RSA) Controller, w/UK8
• Rear Seat Entertainment (RSE) Assembly, w/U42
• Rear Wheel Steering Control Module (RWSCM)
• Inflatable Restraint Sensing and Diagnostic Module (SDM)
• Transfer Case Shift Control Module (TCSCM), w/NP1/NP8
• Vehicle Communication Interface Module (OnStar), w/UE1
• Vehicle Theft Deterrent (VTD) Module, w/VD1
The class 2 serial data line allows a scan tool to communicate with these modules for testing purposes, checking for DTCs, and to activate/enable/disable functions. These class 2 serial data circuits are bused together via three splice packs and DLC:
Mar 27, 2017 | Cars & Trucks
Tip
Speakercraft Vital 1250 Class D amplifier
The Vital 1250 is a class D amplifier designed to deliver 170watts per channel (x12) at 4 ohms impedence.
There is however a number of these which are starting to come through with amplifier modules that fail.
There are 6 stereo class D modules using the TDA8970 design.
In breif the issues are down to the transformer secondary windings delivering slightly over spec voltage to the modules. Over time with the audio sense active this initial pulse from the transformer at power up sees off the amplifier chip and in many cases damages the PCB links between the double sided print making it impossible to remedy the exsisting module, so replacement is the only option.
The transformer on this unit is unique to this model and give 6 pairs of outputs for the 6 modules supplying 2x 29V AC which when converted to DC is around 41Vdc to each module, this can surge up on power on for a split second.
The TDA8970 is designed to take an absolute maximum of 39V and there is little or no protection on the output stage to stop a DC output occuring on the speaker outputs.
My therory is that this will be only the case for UK owners on a 240v mains supply as the tollerance may be acceptable for USA 110V users.
I have repaired these units by replacing all 6 modules with better units that have additional output protection between the TDA8970 and the speaker outputs. also adding resistors to the supply rails to help bring them in line with the correct tolerance and give longer life.
I am an engineer at MusicView Services and we speacialise in high end audio products and profesional music sound equipment.
I hope this helps someone with this amp, these problem will be specific to this model and should not be considered to relate to anything other than the Vital 1250.
on Jan 30, 2015 | Audio Players & Recorders
Trying to install a aftermarket radio in my 2004 Oldsmobile Alero I wired color it won't come on
You wired color ? Hooking up an aftermarket radio on your vehicle requires a special interface module , that may not be the name it's called . You better check at a stereo shop that installs radios . Your vehicles radio is connected on what is referred to as class 2 serial data communication network .
Class 2 Serial Data Link
The following modules use the class 2 serial data link to communicate with each other:
The body control module (BCM)
The digital radio receiver (DRR)
The electronic brake control module (EBCM)
The inflatable restraint sensing and diagnostic module (SDM)
The powertrain control module (PCM)
The radio
The vehicle theft deterrent (VTD)
The class 2 serial data link also allows a scan tool to communicate with the above modules for diagnostic and testing purposes.
The class 2 serial data link on this vehicle is configured in a star pattern. There is no redundant path for the serial data to flow through. If a class 2 serial data circuit develops an open condition, the module connected by that circuit will not be able to communicate.
If not hooked up right the vehicle may not even start .
Jul 31, 2016 | Oldsmobile Cars & Trucks
Why does my battery drain over night on my 2003 cheverolet 2500 hd
One of the modules may be doing it , interior light lit -glove box ! Hard to say on newer vehicles , after 1996 ! You vehicle has some of these modules if not all !
The digital radio reciever
The driver door module (DDM)
The front passenger door module (FPDM)
The HVAC control module
The instrument panel cluster (IPC)
The memory seat module (MSM)
The radio
The radio amplifier
The rear seat audio (RSA) controller
The rear seat entertainment (RSE) assembly w/U42
The rear wheel steering control module
The remote playback device-CD player w/U1S
The transfer case shift control module
The transmission control module (TCM) w/Allison Transmission
The theft deterrent control module
The vehicle communication interface module (VCIM) w/UE1
The way to find the drain on the battery is to do a Parasitic Draw Test ! I'll send a link for Eric the car guy !
How To Perform Parasitic Draw Test EricTheCarGuy
Mar 11, 2015 | Cars & Trucks
Nov 01, 2012 | Dell Televison & Video
WHERE CAN I PURCHASE A SOUND MODULE PART #MVUS325 AND SBX1768-01 FOR MY STANDARD 27' TOSHIBA TV. THERE IS NO SOUND AFTER THE TV RUNS FOR 5 MINUTES. PLEASE ADVISE WHERE WHICH STORE HAS THIS...
I found it at:
Encompass & HBF Electronics . This part is quickly falling off the radar and many places list it as NLA (no longer available), meaning they are no longer being produced. When they're gone - they're gone. Buy one if you want it while you can.
I hope this helps and good luck. Please rate my reply. Thank you.
Apr 13, 2011 | Toshiba 27A30 27" TV
I get nothing on the screen. The blue light on the underbottom of the panel indicates power is on. There is no audio or visual data. I tried connecting to wall cable and HD antenna but I get nothing. I...
i just fixed this same problem on same model - its the main board on the back of the tv - find the part number off of the main board (the board with all of the av input jacks) replace it and that will solve your problem.
thanks,
phatcav
Jan 15, 2011 | Dell W3706MC 37 in. LCD HDTV
Laptop randomly shuts down
Random shutdowns can be hardware or software related. General advice is as follows:
Go to support.dell.com and download the latest BIOS Flash, Video Driver and audio driver for your system and install them, once installed and rebooted see if the issue is resolved.
If not, start, run MSCONFIG, edit the entries in the startup group disabling all except antivirus entries, reboot and see if any change.
If issue no longer occurs, then you can add items back one at a time until you isolate items that cause the issue.
If the software editing has had no effect, try ram modules individually (System will operate on one) and see if issue is isolated to one module or slot.
Jan 15, 2011 | Dell Inspiron 1525 Notebook
Dell tv stopped working
Power Supply board is dead.Replaced it with a reburbish power supply board.Buy it at Websites Shopjimmy.com,Ebay.com to buy a replacement.
Mar 23, 2010 | Dell SP2009W 20 in. TV
Dell W3706MC 37 in. LCD HDTV Logo
344 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
