Question about Kohler Plumbing
The handle on our Kohler Vinnata K-691 came off loose. Is there a way to screw it back on and do we need a part for it?
5 Suggested Answers
  • 83 Answers
SOURCE: i have no screw in the top of the handle.does the
need to turn it not the handle..the part just under it
Posted on Nov 20, 2010
packrat1948
  • 528 Answers
SOURCE: I have Kohler single handle
Ok I am take a stab at this. If it is a L shaped handle it is not steel but an aloy and at the end of the long part of the handle is a end cap that either screws off or pops out when pry on. The set screw should be in the handle under that.
If that is not true then the set screw has to be somewhere around the base of the handle near the shower cover plate maybe headen under a little cover that would look like a small push-in cap.
Posted on Feb 05, 2011
SOURCE: I have a single handed Kohler Vinnata kitchen
I'm running into the same problem. I have the Kohler Vinnata 691 kitchen faucet. I have replaced the cartridge in the handle at the base of the faucet and am still finding water leakage as before. Are there other parts I need to check?
Posted on Nov 08, 2012
  • 51 Answers
SOURCE: Leaking Kohler Vinnata kitchen faucet.
you must use genuine kohler parts,if you got something from lowes or home depot that was some other brand they usually leak. also look for calcium build up inside the valve body,you can use 1500 grit wet sand paper to remove it just be carefull and dont sand too much,then apply water proof plumbers grease inside the valve body befor you install the new cartridge.
Posted on Dec 18, 2012
How do you remove the lever of a kitchen kohler clairette faucet, it seems to be stuck
On the front of the faucet handle, there is a small plastic cover with an emblem on it. Gently pry it off with a sharp knife blade. Next you will notice a small "allen" screw head. Remove it by turning it counter clockwise until it's loose. (lefty loosie - righty tighty) Lift the handle straight up to remove.
Jun 23, 2014 | Kohler K-15160-7 Coralais single-control...
Nov 08, 2012 | Kohler K-690-VS Vinnata kitchen sink...
The cold-water handle on my Kohnler K-454-4S Memoirs Widespread Lavatory Faucet is dripping. Kohler sent me replacement cylinder GP77006-RP, but my handyman can't remove the handle without fear of...
He needs a handle puller. Once the screw is removed the handle puller has a long point on it that goes into where the screw was and then the outside of the handel puller clamps around the handle. You then turn the T part of the puller and up come the handle with no damage
Best of luck Rich
Sep 03, 2011 | Kohler K-454-4S Memoirs Widespread...
Handle is loose enough that it doesn't catch to turn the valve. Not really sure how to tighten this
There is normally a cap on top that needs to be popped of to gain access to the screw. Look closely to be sure before prying it off, it could have threads.
Apr 01, 2011 | Kohler K-12265-4-BN Fairfax Lavatory...
Handle loose. how do I tighten?
should be a very small set screw at rear base of handle
Mar 10, 2011 | Kohler Forte Two Handle Centerset Lavatory...
My lever on my single handle kohler shower faucet is very, very loose. How do I tighten the lever. I don't see any screws or place for an allen wrench
There should be a screw hidden under a cap. depending on the model/style it may be as small around as a pencil diameter or as large as a half dollar (the larger is most common on acrylic handles) Just gently pry this off and you should find a phillips screw underneath.
Feb 04, 2011 | Home
Kohler fairfax k12175 cp took out button plug and screw - lever handle and bonnet won't come out - how do I get them out
Place a few drops of vinegar into the screw hole and wait a little bit. Try removing the handle again, sounds like it is just stuck on the cartridge stem. The handle should come off first, and then the bonnet. Here's the parts breakdown for your faucet from Kohler.
Sep 07, 2010 | Kohler Plumbing
I have a single handed Kohler Vinnata kitchen faucet that is leaking from the handle. Cartridge has been replaced and hasn't stopped leak. What now?
turn off water remove handle and check retaining nut remove cartridge and check o-rings for damage or replace replace and tighten cartridge check for leak
Nov 04, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Plumbing Logo
97 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
