Question about 2wire (1000-000005-002) 802.11g/b Wireless Adapter
I need some simple help. I want to change my WEP Key so that someone who had the wepkey cannot access my wireless network any longer. My router is a 2wire...can you help?
  • Anonymous May 08, 2009
    Ronnie, that was useless advice. He told you what kind of router he has.
    Problem Solver:
  • 11 Answers
Hi Steve,
Do you use a Wireless Router? If so, logon to the router, go to wireless security and change the wep-key there.
If not, do you host the wireless network on your PC?
What kind of Router do you have if you have one?
Regards Ronnie
Posted on Jan 11, 2009
What is lynksysn600 wepkey?
WEP is a type of security mode for wireless networks. It is associated with a specific SSID. You have to know the WEP key to be able to use the WLAN that is protected by it. If you own the router, you can change the WEP key in the config. If you do not, you'd need to get the key from the owner.
Sep 01, 2014 | Linksys Zyxel Prestige 600 Series 645 Adsl...
I need the wep
you can find this out by connecting to your linksys router with a cat 5 cable.
in your browser such as internet explorer or firefox type
192.168.1.1
login with your login/pass that you assigned to it.
go to the wireless tab and go to security
it will show the the WEP key that is needed in order for your laptop or wireless devices to connect.
BTW I would recommended using WPA as WEP is not secured.
Mar 06, 2011 | Linksys Wireless-G WRT54G Router
Where do I find the WEPkey for Arris TM502G? The question is posted all over the internet, but no real answers.
The WEP key is a encryption key that is configured in the wireless settings of the wireless router. This setting is then applied to the wireless card in the computer so it can connect to the wireless router.
To secure your wireless network from unauthorized access, please click on this link and follow my instrucrions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Sep 19, 2010 | Arris Touchstone 450a (CM450) Modem
How to secure my internet connection via smc router
If you plan to have a wireless network, you should set it up so that only people you choose can access it. Here are a few options for wireless network security.
Wired Equivalent Privacy (WEP)
WEP is a widely used network security method. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. The receiving computer needs the key to decode the information so that it's difficult for someone on another computer to get onto your network and access files without your permission.
Wi-Fi Protected Access (WPA)
WPA was created to improve the security of WEP. Like WEP, WPA encrypts information, but it also checks to make sure that the network security key has not been modified. WPA also authenticates users to help ensure that only authorized people can access the network. If your networking hardware works with both WEP and WPA security, we recommend that you use WPA.
There are two types of WPA authentication: WPA and WPA2. WPA is designed to work with all wireless network adapters, but it might not work with older routers or access points. WPA2 is more secure than WPA, but it will not work with some older network adapters. WPA is designed to be used with an 802.1X authentication server, which distributes different keys to each user. This is referred to as WPA-Enterprise or WPA2-Enterprise. It can also be used in a pre-shared key (PSK) mode, where every user is given the same passphrase. This is referred to as WPA-Personal or WPA2-Personal.
802.1X authentication can help enhance security for 802.11 wireless networks and wired Ethernet networks. 802.1X uses an authentication server to validate users and provide network access. On wireless networks, 802.1X can work with Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) keys. This type of authentication is typically used when connecting to a workplace network.
IF THIS ALL DOSEN'T WORK TRY THE FOLLOWING:
Wireless network security recommendations
If you have a wireless network, there are some additional security precautions that you should take.
Use a network security key
If you have a wireless network, you should set up a network security key, which turns on encryption. With encryption, people can't connect to your network without the security key. Also, any information that is sent across your network is encrypted so that only computers that have the key to decrypt the information can read it. This can help avert attempts to access your network and files without your permission. Common wireless network encryption methods are Wired Equivalent Privacy (WEP) and Wi-Fi Protected Access (WPA) and WPA-2.
Change the default administrator name and password on your router or access point
If you have a router or access point, you probably used a default name and password to set up the equipment. Most manufacturers use the same default name and password for all of their equipment, which someone could use to access your router or access point without you knowing it. To avoid that risk, change the default administrator user name and password for your router. Check the information that came with your device for instructions about how to change the name and password.
Change the default SSID
Routers and access points use a wireless network name called a service set identifier (SSID). Most manufacturers use the same SSID for all of their routers and access points. We recommend that you change the default SSID to keep your wireless network from overlapping with other wireless networks that might be using the default SSID. It makes it easier for you to identify which wireless network is yours, if there is more than one nearby, because the SSID is typically shown in the list of available networks. Check the information that came with your device for instructions about how to change the default SSID.
Position your router or access point carefully
Wireless signals can transmit a few hundred feet, so the signal from your network could be broadcast outside of your home. You can help limit the area that your wireless signal reaches by positioning your router or access point close to the center of your home rather than near an outside wall or window.
Aug 03, 2010 | SMC Barricade 7004VWBR Wireless Router
Changing Wireless network password without resetting the router
For that access your router with
http://192.168.1.1
or http://192.168.0.1
if you cant able access it then reset it
Press RESET button for 10 seconds it is in back sid of router.
then access above link.
type user name "admin' and password as "admin' or blank or "password'
then go to wi fi security first configure your router as WEP then go to wi fi security in advancwed then set WEP key it is your password to connect wi fi .
Aug 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
How do I put an encryption on my linksys router?
Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
  • Enabling WEP or WPA on the Router
  • Enabling Wireless MAC filter on the Router
  • Disabling SSID Broadcast on the Router
NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
Enabling WEP on the Router
Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
Enabling WPA on the Router
Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
  • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
  • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
To enable WPA, click here.
Enabling Wireless MAC Filter on the Router
Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
To permit wireless computers to connect to your wireless network, click here.
To prevent wireless computers to connect to your wireless network, click here.
Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
Jul 11, 2009 | Linksys Wireless-G WRT54G Router
Wepkey/wpa
wep key and the wpa pass phrase is a wireless security option in the wireless option you got it to protect the wireless connection and you have the wireless router or modem or access point in that option you got it for the wireless security.
May 12, 2009 | 2wire 2700HG-B Router (2700HGB)
I want to connect a PSP on a router with wep
sure you can do that but you will need to know the wep key first
if you dont then contact you network administrator to get the wep key from them.....
if it is a new wireless router then the wep key should be on the back of the router (its a 10 digit hexa).
enter the wepkey and you will get wireless connection.
cheers
Aug 30, 2008 | Computers & Internet
Buffalo router-WYR-GR4
you need to access your router's setup page in order to get the wep key. follow the steps below
- open a web browser and type http://192.168.11.1 on the address bar. the default username is "root" and leave the password blank
- you will be prompted with your router's page, go to the wireless settings
- then go to wireless security, there you will find your wep key or the encryption that you needed to connect wirelessly
hope this'll help and just ask me if you have other concern
ciao!
Jul 17, 2008 | Buffalo Technology WHR-G54S Wireless...
Psp2 wep key
You will need to logon the router and find the security tab and from there you should be able to find the wep key. Access the router setup page by opening internet explorer and enter the following with the correct IP of the router exp. http://192.168.1.1
Once you access the router you will be asked for the username and password. username will either be blank 'NO NAME" or admin. The password will either be 1234 or admin BPCS
Dec 29, 2007 | Linksys Wireless-G WRT54G Router
2wire (1000-000005-002) 802.11g/b Wireless Adapter Logo
80 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
