Question about General Electric Hardware & Accessories
GE 581700 by intertek 4003187 6 outlet outdoor timer how to set
Can't set the outdoor timer so it works. has a reset 6 plugs up to 8hr hour times.
5 Suggested Answers
  • 16 Answers
SOURCE: resetting outdoor light timer
I would unplug the timer. Change the setting to 6 hours then plug back in.
Posted on Jan 12, 2009
SOURCE: when one timer on my
found a link for PDF instructions:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15077-Manual-eng.pdf
Posted on Oct 07, 2010
SOURCE: need instruction to set a
It seems there is more than 1 Utilitec 014289 outdoor timer.
Each has same buttons, but different words under each button.
One has 'week-hour-min' on top row.
Other has 'manu-mode-prog' on top row
Manuals for both types appear on link below
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
Manuals contain more useful information and illustrations than I can type in an answer and the manuals seem straightforward. If you need help with specific programming steps, add a comment with identification which manual applies to your timer. I will be glad to help for free.
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Posted on Dec 23, 2010
SOURCE: Set up Intermatic outdoor timer 7day/7event
I have misplaced and forgot how to set a Model HB65R timer, can you help, thanks, Murray
Posted on Dec 24, 2010
Westinghouse outdoor timer with 6 outlets instruction manual
1) Copy following link to help identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) After viewing link above, add a comment with clear detail about timer
Dec 22, 2012 | Hardware & Accessories
Jasco Ge 8HR Mechanical Blk Timer 2 Outlet Grnd
1) Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#outdoor
2) Add a comment and describe timer in detail.
Dec 18, 2012 | Jasco Ge 8HR Mechanical Blk Timer 2 Outlet...
I have set the time and day, set program inc. day, off, on. When I switch mode to automatic the timer goes off. Only work in on mode. I have tried this with 3 separate units. What am I doing wrong?
I don't have repair for defective timer.
If following information does not apply to your timer, then add a comment with clear description of timer for possible help.
http://waterheatertimer.org/pdf/Woods-59403.pdf
http://waterheatertimer.org/pdf/GE-15117-Manual.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
1) The only complaint about this 6-button timer sold by Woods, GE and Westek is the MODE doesn't work.
The key to this timer is to finish programming, and then press Clock to return to current time, and at this point the timer is in correct mode.
Then do NOT press mode button ever for any reason, except to reset timer.
2) Try resetting timer by pressing Clock Mode and Prog buttons at same time, and then re-program timer.
3) Timer is not heavy-duty. Load rating is 1000watts incandescent, and 1/4 HP.
If load rating is greater, then timer will not operate as expected.
4) If you have problem with timers, try timer on different load and on different outlet.
Test outlet for polarity using circuit analyzer.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#circuit-analyzer
Aug 22, 2011 | Woods Outdoor 7 Day Digital Two Outlet...
Had to change battery. Since I did this the day will scroll several times and will not let me set the day, nor the time, nor the mode. Is my unit toast ?? As it was working till I changed the battery.
Most digital timers suggest resetting as last-step effort to restore functionality.
This particular timer is reset by removing battery.
Try removing battery again. Otherwise it seems the timer has gone bad.
HB88RC is discontinued product.
Replacement is heavy-duty Intermatic HB800RCL 2-outlet or HB800RCH 1-outlet timer.
http://www.smarthome.com/25078/Intermatic-HB800RCL-Heavy-Duty-Digital-Appliance-Timer/p.aspx
http://www.smarthome.com/48715/Intermatic-HB800RCH-Outdoor-Digital-Timer/p.aspx
Less expensive and less reliable timer Woods 59403 with 1-outlet has quite a few 'timer won't work' questions on fixya.
http://www.amazon.com/Woods-59403-Heavy-Duty-Outdoor-Digital/dp/B002KS7EOK
Jun 19, 2011 | Intermatic HB88RC - 7-Day Programmable...
How do I set the woods outdoor timer model #59730
Woods 59730 is24-hour 6-outlet yard stake with dial located on top
This timer is identical to GE15107 yard stake
Manual.
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
If this is not your timer, look at following page to identify your timer
Add a comment any time
Timer instructions.
Set current time by rotating dial until time lines up with arrowhead located on inner dial
There are segments located around dial.
Look at inner dial > segments are located just outside the inner dial.
Timer comes with segments pushed inward.
To set timer to turn ON, pull segments outward for hours you want timer ON.
All 6 outlets are controlled by timer.
Last step:
There is override switch located on inner dial.
Move switch to TIMER for timer to operate.
Dec 09, 2010 | Woods Outdoor Lighting Timer
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
To override time and turn on Load, move override to ON position.
Dec 06, 2010 | GE 51587 MultiEvent Timer
How do I use SKU: 15112 timer
GE 15112 timer manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15112-Manual-eng-spn.pdf
Same as Tork 652A manual
http://waterheatertimer.org/pdf/651A-652A-manual.pdf
Made for permanent outdoor usage. Outdoor usage only.
Timer has 2 grounded outlets located bottom of timer, maximum wattage for both 1000Watts
50-mini-bulb string of Christmas lights is 25 Watts
Plug timer into 125 Volt GFCI protected outlet.
Do not plug timer into extension cord.
Indicator light shows when timer has power.
Timer turns ON automatically at dusk.
Plug lights, small pump, fountain, motor into grounded outlet located bottom of timer.
Rotate dial to choose timer function.
Rotate dial to select timer function
- ON at dusk & OFF 2, 4, 6, 8 hours later - Rotated dial to number shown on dial
- ON at dusk, OFF at dawn - Rotate dial to dusk-dial
- ON continuously - Rotate dial to ON
-OFF - Rotate dial to OFF
Dec 03, 2010 | Jasco Ge 8HR Mechanical Blk Timer 2 Outlet...
Resetting outdoor light timer
Dec 08, 2008 | Coleman Cable Outdoor Easy Set Timer #4604
Hardware & Accessories Logo
633 people viewed this question
Top General Electric Hardware & Accessories Experts
jdthefixer
Craig Butler
Craig Butler
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
