Question about Frigidaire ATF6000ES Front Load Washer
Washer won't drain and clothes stay soaked
After a complete wash cycle, the load stays completely soaked because the spin cycle won't engage as a part of the complete wash cycle. After we pull out the clothes and put them in the dryer, we have to manually rotate the drum in the washer to completely eliminate the standing water. The drain hose isn't pinched at all and there is no damage of any kind that I can see externally. What do you suggest?
  • 4 more comments
  • suttonea Jan 11, 2009
    I found out more info on this. The model number is LTF2940ES0 (Frigidaire). I just sat in front of it and selected the SPIN/DRAIN for a 13 minute time period. It didn't spin at all, but when I select the RINSE/SPIN setting on the dial, it spins while pumping in water. It seems that the high spin isn't working. There are no noises at all and I hear it drain but the high spin never engages. I can't hear a belt slipping and when I manually spin the drum, it feels unrestricted. The front display correctly displays what I set it to. I hope this is all you need on this. Thank you.
  • suttonea Jan 24, 2009
    I just did an error code check and found that "Board thinks the door PTC circuit is open in spin" and then the test states "Remove the door lock assembly and measure the resistance of the PTC" and then it states that I have a defective control board and then to replace the control board. Is there a way to fix the door lock assembly? If not, how much does a control board cost?
  • Tracye Jan 26, 2009
    My washer won't drain well either. I have to tip it backwards until most of the water is out. When or if the drum begins to spin, it drains better but it is getting progressively worse. I have to repeat the process a few times. It makes a LOUD noise and can take up to 3 hours to wash 1 load!
  • MOMMY25 Jan 27, 2009
    EVERYTHINGS DIGITAL,AND THE CLOTHES STAY SOAKED ,ITS NOT CLOGGED ,BUT WHEN I PUT IT ON SPIN AND DRAIN ITS A 15 MINUTE CYCLE AND WHEN IT GETS TO 6 MIN LEFT IT SHUTS OFF,AGIAN THE CLOTHES REMAIN SOAKED.
  • bean5955 May 11, 2010
    is your pump turning free and is your belt slipping
  • Anonymous Mar 14, 2014
    agitator stuck and tub will not spin to drain. clothes are completely soaked upon full cycle
    Sergeant:
  • 311 Answers
You need to clean your drain punp,if its is clean[which i think it wont be,and i have fixed thousands of washers]you need to do a voltage check at the pump.if its getting voltage and not draining replace pump.your washer can not go into high spin unless it pumps the water out.to get to the pump remove bottom panel,pump on the right.it has two hoses to it and to wires.it is white or tan in color.i hope this helps,God bless ,tom
Posted on Jan 11, 2009
  • Thomas Malailua
    Thomas Malailua Jan 30, 2009
    the pump is the most common no drain problem.also the washer computer will not allow the washer to spin if there is water in the washer.also i had the pump go bad it was getting voltage but would work intermidintly[the little impeller in the pump would not spin with a load of water on it ,,,,but some times it would.i replaced it and problem solved.
  • 52 Answers
Can you give me a model and brand name. Does the washer drain at any time during the wash cycle?
Will it go into a spin at all in any setting? heavy duty, normal and delicate cycle? is water not draining?
  • Kevin O'Leary Jan 11, 2009
    Try to unplug unit and let it sit for 1 minute and plug it back in. See if this will reset the unit
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
I own a Fridgiaire washer Model# FXW223LB56. The machine will not spin on the final spin cycle and leaves the clothes soaking wet. Tub does drain but does not spin. Sounds like it's engaging but still...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
=- =- =0
Sep 10, 2011 | Frigidaire Washing Machines
Washer is completing all cycles, but water from wash cycle.is left.in washer and clothes are still soaking wet. No water drains out.
check the Lid safety switch, if its shorted the spin cycle won't work, so your left with wet clothes ,, you can jumper the 2 wires together to test the switch , if that makes the cycle work, Replace that switch
Jul 06, 2011 | Washing Machines
My washer won't complete the final spin cycle. It goes through the wash and drain OK but won't spin, clothes are soaking wet. I removed the drain pipe and made sure it was not blocked, also removed and...
Hello, problem here is the spin control board is bad. Remove panel under the door and you can locate the spin control at the rear right of the machine screwed to the floor. Replace it and you will be all set. Mike
Nov 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi ZWC1300W Front Load w'Machine
is it spinning during spin cycle
your timer may have gone
Jan 18, 2009 | Zanussi ZWC1300W Front Load Washer
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
How can i fix my washer myself?
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
804 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
