Question about Diesel DZ7221
Diesel DZ7221 Time 2 not displaying
Can't figure out how to get the digital time to display, the manual isnt much help either.
Same here after getting the stem replaced under warranty, now the digital time is blank... is there a separate battery for the digital time?
Posted on Aug 23, 2013
Digital display not working
If it is brand new take it back! Maybe the battery died or you did not follow the instructions.
If you have a voltmeter check out the battery voltage.
Sep 10, 2015 | Diesel DZ7221
Diesel watch dz7125 the digital display for TIME 2 has gone blank. Analog times (1,3 & 4) still run, and keep time.
probably needs a new battery there will be two batteries one for digital and one for analog,,
Aug 11, 2013 | Watches
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
Bought a generic clip watch from walmart with no manufacture's name on it. The back says MSP74582W batery CR1616 and then A126. Looking to find instructions on how to set alarm, date, and figure out...
Just got one, and haven't lost the instructions yet. First, the 4 buttons are:
S1 - at 4 - Lap/Rst
S2 - at 2 - St/Stp
S3 - at 8 - Mode
Light - at 10
Watch Control
Normal Display: Hour, Minute, Second
Push S1: Alarm time in Hours and Minutes
Push S2: Month, Date
S3: Change function
Alarm and Chime
In Normal Time Hold S1 and the alarm time will be displayed.
Press S2 once and Hourly chime will be on.
Press S2 twice and Alarm will be on.
Press S2 three times and Chime will be off.
Press S2 four times and Alarm will be off.
Press S1 and display will change to normal time immediately.
Setting Alarm Time
In normal time, hold S3 for about 3 seconds, the hour digit will flash and is advanced by pressing the S1 button. Then push the S2 button to change to minutes and change those by pressing the S1 button as above. Push S3 to return to normal time.
To silence the alarm, press S1.
May 15, 2011 | Watches
I cant figure out how to set time and date
Hi idarr,
Please follow these steps to set the time and date of your Armitron Digital Sport #40/8125BLK Watch.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
Mar 13, 2011 | Armitron 40/8125BLK Digital Sport Watch
I have purchased some cheap wrist watches from Hong Kong. They are the rubberised type with a digital display but have no instruction as to how to alter them. Can you help please?
mcdevito75 here, I'm figureing you have only one (1) button on your watches, some, even cheap digitals have two (2) buttons, one of which is ususlly for a light. Some have two (2) buttons, one says MODE the other says SET. For one button (1) digitals, This will usually say set, when you press this button you should see the display change, to month then press set agin to see date, press set again to go back to time of day. NOW!! look for a DIMPLE, an INDENTATION on the side of the watch fairly close to the other button, press this DIMPLE in with a tooth pick, pin or the point of a pen, this is your MODE, press once, see the display flash, now with the set button, set whatever display is flashing, press MODE again, set this next display, when all displays, Month, Day, Date and time of day, hour and minute are set, press MODE again to see steady display. when you press set now, you can see the corrected display, press the set button for each display you want to view until you come back to the time of day display. That"s it.
Jul 18, 2010 | Watches
How to set time on a bulova marine star 96C30
For some reason you cannot find the manuals on the Bulova web site any longer. But don't worry....
I have the manual for the Bulova Marine Star 96C30 Watch. This is easily fixable.
Below, I have typed the instruction on how to fix this issue as well as reset the time and calendar and a few extra tips in case you forgot....
Here is what it says to do if the hands don't match up with the display time (usually happens after you change the battery).
First, you must locate the buttons on the watch.
The "A" button is at the 2 o'clock position (upper right). The "B" button is at the 10 o'clock position (upper left) The "C" button is at the 8 o'clock position (lower left) The "M" (mode) button is at the 4 o'clock position (lower right), and is the only button you can pull out to set the times, calendar and programming.
To RESET the watch and do the ZERO POSITIONING after changing a battery or having a display error, do the following.
RESET 1. Pull the "M" button out to the setting position. 2. hold down the "A", "B", and "C" buttons simultaneously for 3 seconds, then release them. All digit segments will turn on and display completely.
ZERO POSITIONING 1. Press the "B" button and all the segments in the digital time will reset to zero, with "UTC" showing in the main digital window. 2. Zero the "UTC" minute and hour hand (located in 12 o'clock sub-dial) to the 24 o'clock maker (straight up). Button "A" will move the hands clockwise, and button "C" will move the hands counter clockwise. 3. Press button "B" - "HR" shows in the main digital window. Adjust the main (large) hour hand to the 12 o'clock (midnight) position using "A" and "C" buttons. At the same time, observe the synchronized 24 hour hand (small dial to the left of the main dial), to insure that it also moves to point to "24". 4. Press button "B". "MIN" shows in the display window. Adjust the large minute hand to also point to the 12 using the "A" and "C" buttons. 5. Push the "M" (mode) button back in to its normal position. The watch beeps and at the same time the hands jump slightly. ALL RESET and ZERO POSITIONING are now complete. 6. Reset the time, calendar and other modes.
To set the time. Note that changing the time in any of the cities will automatically update the time for all the cities. 1. Press the "M" button to move the mode hand to (TME) 2. Press either the "A" or "C" button to move to the desired city. 3. Pull the "M" button out to the setting position. 4. Press the "A" button. SECONDS will blink. Set them with "C". 5. Press the "A" button again, and MINUTES will blink. Set them with the "C" button. 6. Press the "A" button again, and HOURS will blink. Set with the "C" button. 7. Press the "A" button again, and 12 or 24 hours tim format will appear. 8. Push in the "M" button to its normal position.
To set the calender 1. push the "M" button to move the mode hand to (CAL) 2. Set the city using the "A" or "C" buttons. 3. Pull out the "M" button to the "setting" position. The numbers of the "month" starts to blink. this is an "american" date system with the month first, day second, and year third. Use "C" button to adjust the month. 4. Push the "A" button. The date (day) will flash. Adjust with the "C" button. 5. Push the "A" button. The YEAR flashes. Adjust with the "C" button. 6. Push the "M" button back in. The calender is simultaneously adjusted for all cities.
Couple of other "tips".
Switching the time on the digital display with the time shown on the hands: 1. Press the "M" button until the mode hand is in (TME) or (CAL) mode. 2. Pressing the "A" and "C" button together. The time will switch the between the main hands (analog) and the digital display.
Temporary Hand Retraction Pressing and holding the "B" button will move the hands out of the way of the display. Repressing the "B" button will put the hands back at the correct time.
hope this helps.
Feb 23, 2009 | Bulova Marine Star 96C30 watch
Diesel Digital Watch DZ7069
I finally figured out how to set the time on this watch! Like others the included manual didn't have instructions for this model.
Hold down all four buttons on the watch, this will do a factory reset.
Hold down the top left button, which brings you into the configuration mode.
Pressing the bottom left button will cycle you through all the settings for the time. For each setting, the top right button increments and the bottom right decrements.
When you are done, press the top left again.
Dec 28, 2007 | Diesel Audio Diesel Watch
How to set time on Diesel DZ 7071 Watch
Just figured it out!! Press and hold Set/El button. Wait until LIGHT On/Off (or similar) flashes on screen. When it does then press the Mode button to scroll through various functions including setting the time. Hope this makes sense and helps
Dec 20, 2007 | Watches
Diesel DZ7221 Logo
568 people viewed this question
Top Diesel Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Diesel Watch Expert? Answer questions, earn points and help others
