Question about Plumbing
Ween two 15mm bidet pipes which are about 3 inches apart and slightly at an angle
The connection is for mains pressure cold water supply to the bidet. The connection was previously achieved with plastic "concertina" tubing with jubilee clips at each end. This had begun to drip leak and I have just replaced it with clear plastic tubing and jubilee clips. But is there a more professional and permanent solution. The pipes are in behind and under the bidet and close to the wall, making it difficult to work. Standard flexible 15mm connectors with compression fittings are too long and probably not flexible enough to loop and fit in the limited space between the pipes.
    New Friend:
I don't know all of your situation, but I have found 1/2" flexible connection lines braided or neoprene very adequate. Another suggestion is to use 3/8" plastic tubing with appropriate fittings. Hope this is helpful.
Posted on May 07, 2017
  • Bob williams
    Bob williams May 07, 2017
keemo68
  • 1263 Answers
SOURCE: 1999 Mercury Cougar powersteering hose leak
if that is the case the fitting is probably cracked and unless you replace that fitting it will continue to leak.
Posted on Aug 30, 2008
  • 50 Answers
SOURCE: Dakota power steering leak
That's the power steering pressure switch and it is very easy to replace. I don't know how much the part is, but it cant be very much. It's a very simple switch. I'd just replace it.
Posted on Apr 14, 2009
Murphybanton
  • 2004 Answers
SOURCE: water leak inside car
Try check the AC water outlet hose there must be a leak from there.
Posted on Apr 30, 2009
autotherapis
  • 501 Answers
SOURCE: I have a 1999 taurus 3.0 v6. The trans cooler line
You can buy a snap in replacement end that can be bent and attached to 3/8 th's fuel line and by pass the rotted metal line. I have been doing transmissions Since 1981, and have the same rotted lines on my 01 Windstar. I just went to all hose except the line into trans and into radiator. double clamp the hose on the lines and save a lot of money. make sure you sip tie the hose so it is out of the way and check your trans fuel level when you are done. Let it get hot in park and running when you check the level on the stick.
Hope this helps.
Hope this helps
Posted on Aug 29, 2009
  • 3 Answers
SOURCE: Tow bar trailer socket wiring connection point to car wiring?
The connectors for towing wire harnesses on foresters are generally on the passenger side, below the rear taillight inside the cargo space. some require pulling up the foam block that is between the spare tire compartment and the taillight. Check where you replace the tailights from inside the car, if there isn't a matching connector hanging out there, check around the spare tire compartment, see if you can remove the carpeted foam block next to the compartment and find the plug under there.
Posted on Mar 03, 2010
How can I connect a tiny-150 compact reverse osmosis water filter to the water supply?
Water Supply Connection uses metPure Universal EZ RO Adapter that fits both 1/2" and 3/8" supply stops.
Amazon $20.00
9mhakhhf6wzaqaagfpczwmaaadko7mbaaaa5dhzaaaagplobaaaaeb5ddyaaacgpdobaaaaub6ddqaaacjv1m7+d6jadilb3eqhaaaaaelftksuqmccaa== Express Water RO Feed Adapter Valve Quick Connect for Undersink Reverse...
Apr 06, 2018 | Plumbing
NOn electric bidet with hot and cold water , can I just hook up to cold water only ,because the hot water is bit far from the toilet. Thanks.
If you can stand washing in cold water there is no reason why it should not be connected to only the cold supply though if the bidet is fitted with a combined hot/cold tap (faucet) the hot water inlet should be plugged.
It should be possible to run hot water to the bidet and would be worth the effort. Modern flexible plastic pipe and associated fittings will carry hot water and overcome many plumbing problems.
Sep 05, 2017 | Home
How many fluid ounces in a pipe measuring 5mm X 1m How many fluid ounces in a pipe measuring 15mm X 1m
English? Would that be approximately 3 feet of 1/4 inch pipe? 3 feet of 3/4 inch pipe?
Sep 10, 2013 | Easy Heat Water Pipe Heating Cable
Is it a cold water or hot water fill
It's your choice.There's only a single supply hose and with most dishwashers that means cold fill only, but as this is a compact basic worktop model the manual supplied suggests that users connect to a hot water supply.
In real-life situations though, the water drawn from the hot supply often isn't instantly hot so all you do is drain cold or tepid water from the supply pipe and let it get replaced with wasted hot water which then cools in the pipe! If the machine features condenser drying like many dishwashers, then cold water is essential for it to work. A final consideration is that unless your hot water is supplied at mains pressure (such as in a combi-boiler or megaflo system) then the water pressure from a hot water storage tank will not often be high enough and you'll have to use the cold supply.
Jul 13, 2011 | Bush DW5F 22 in. Dishwasher
I have a quote from a contractor to install a Rinnai R75 tankless water heater. The heater normally requires 3/4 piping. My home has 1/2" piping. The contractor says 3/4" is better but 1/2"...
There are advantages and disadvantages to both pipe sizes. Typically, most houses utilize 3/4 inch or larger to supply high volume circuits like the circuit from the meter (or well) to the hot water heater, outside spigot, or water softener. Distribution from water heaters is usually 3/4 for the main branch but this is reduced for the runs to the sink, dishwasher, washing maching. The reason for reducing the size is to reduce the volume of water in the tube or to reduce the amount of cold water you run down the drain before it turns hot.
Since your house seems to have 1/2 inch supply to the current water heater, I would suggest staying with the current size. The option is to enlarge the tubing from supply to distribution which can be a major plumbing task. If your current water pressure (at the faucet) is ok, then go with what you have.
Jan 31, 2011 | Kitchen Ranges
I have a hotpoint hot water heater it's about 6 years old. When I turn the hot water on it runs very slowly the water pressure is very low and it's like this throughout the house how do I fix this problem...
You have clog in the water line.
Since all hot water pipes are involved, clog is probably near water heater.
Buy pressure gauge at hardware store that threads onto hose connection.
Brady BTG 100 at Amazon
Picture of gauge
Check outdoor pressure for baseline pressure in your home.
Turn off electricity to hot water heater for an hour or two so there is not scalding water.
Open drain valve on water heater to see if water heater is clogged with sediment.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Put pressure gauge on drain valve and compare with outside pressure.
Open hot water spigot on bathtub and see if tank pressure drops ... if tank pressure drops significantly with bathtub spigot on, then clog is on incoming cold water before tank, and could be on outgoing hot water pipes too.
If tank pressure stays about the same, then clog is on outgoing hot water pipes.
Clog can be sediment caught in cold water shut off valve located above tank. Open and close valve and test pressure again. Take apart incoming cold water pipes above tank and check for sediment. Replace valve. Look at condition of cold water nipple on top of tank.
Sediment caught at hot water elbow near tank.
Sediment can fill up old pipes. Take apart hot water pipes above water heater and see condition.
Look at condition of hot water nipple on top of tank.
You may have to take apart pipes up to first or second elbow.
Pipes can decay at joint where copper pipe connects to galvanized pipe. Check for copper to galvanized connections on cold or hot pipes and replace section of galvanized pipe. Copper pipe will probably be good, the galvanized pipe will deteriorate. Replace copper-to-galvanized joint with 3/4" non-conducting union from hardware store
Dec 06, 2010 | Water Heaters
Condensation on toilet tank that drip a lot on the floor. Could you help me of what to do. These toilets were expensive and I do not want to change them.
This is usually the result of long hot showers and lack of ventilation. Open a window, or install an exhaust fan that runs whenever the light is on or kick those kids out of the shower. Another (maybe silly) option is to run a detour in the supply cold water-- that is, make the water supply that feeds these toilets run through a long section of 3/4 inch copper pipe in the basement so that the water can warm up a little before it fills the tank. 50 ft of 3/4 inch pipe holds about a gallon. (That would run you about $75 plus fittings.)
Jul 29, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
A plumber has just installed a shower which has uneven water supply pressure. The low pressure hot water from a head tank had a 3/4" pipe supply whichin spite of being questioned the plumber has reduced...
You aren't the first to run into this dilemna.
The size of thhe pipe will affect your system in this way.
If you start 85lbs of pressure in the water main, The meterhas a 1" pipe inlet and a 3/4" outlet. The meter reduced thhe pressure to60 psi and then it is reduced again at the point of entering the structure dropping to 1/2" pipe. By resucing the pressure is upped approx 5-7 lbs. The point of regulator and pipe size is the only time the pressure changes. The lowest pressure will drive a rainbird spribkler,actually several. But too many rainbirds won't affect by pressure as much as volume. The pressure will push whatever is available.By reducing the 3/4 to 1/2" didn't affect your pressure as much as it did your volume.. The reason your hot water starts to run cold sooner is that now you do not have the volume ratio between the cold and hot.It 's 1:1 now instead of 1.25:1. Hot more than cold. It takes more hot water to heat cold water than ittakescold to cool hot. Plus, the hot water you use is being replaced by cold water and that water is cooling what hot water is in the tank as the heat moves to the cold. The heater cannot heat al that water fast enough, but the cold water line is happy as can be.No pressure changes and no temperature changes. Before, you had to turn up the cold to bring the temp down to comfortable or safe. I just had my shower redone and everything is the sme size. Here is something to think about. Ck the shower head. They clog up and cause poor mixing over time. Yoou should be ok. How old is the water heater? Over time they get a build up of calcium and lime which is very detrimental to the heaters efficiency and recovery time. I hope this all made sense to you. At times when we have things done right it seems to be wrong because we are accustomed to the way it was. You will get accustomed to it and find your water heater gobbling less energy. Good luck and I hope it all works out, There is no need to fret. Sincerely -Ned-
May 21, 2010 | Home
Inlet Valve leaking
I would try PLUMBER'S GOOP (hardware store) on the copper pipe. Remove it and put a liberal amount of goop on the end about a quarter inch back from the tip -- insert and smooth the goop around the connection -- let it cure for 24 hours -- turn water back on.
Charlie
Aug 22, 2009 | Home
How to install diswasher
To get the water to the dishwasher, it depends on your plumbing setup. If you have shutoffs under your sink(1/2" X 3/8" compression angle stop), you will need to buy a 1/2" x 3/8" compression double stop. This will be easy to change.
#1 Drill a 1 1/2" hole in the back bottom of the cabinet to run your water, drain line, and power cord through.
#2 First turn off the water at the Hot Water Tank, or the House supply, and turn on the sink to relieve the pressure.
#3 Next remove the Hot supply stop, and install the double stop.( The nut and ferrul do not have to be removed, as they will attach to the double stop. Reinstall the hot supply to the sink to one of the connections on the double stop.
#4 Install a 3/8" x 3/8" x 48" braided flex with the 1/2" MIP
x 3/8" compression ell at the dishwasher.
#5 Install the drain hose supplied with your dishwasher at the bottom of the dishwasher.
#6 Install a 6' pigtail power cord to the power box under your dishwasher.
#7 Feed the drain line, power cord and water supply through the hole in the back of the cabinet at the bottom. As you push the dishwasher back into the enclosure, you will need to feed the 3 lines into the cabinet under the sink.
#8 Attach the water line to the open connection on the double stop.
#9 The drain line will attach to your garbage disposal.(If you have one) Be sure to knock the small piece of plastic out of the drain connection, and retrieve it out of the disposal, before connecting the dishwasher drain line.
#11 Raise the middle of the drain line as high as possible under the cabinet under the sink, preferably attach it to a screw to the bottom of the counter top. This will keep the dishwasher from drawing a back siphonage and getting a bad odor.
#12 Plug in the dishwasher. Assuming you have electrical under your sink. Otherwise an electrical outlet may need to be installed.
#13 Balance the dishwasher using the front legs. After you adjust the depth of the dishwasher, and the level. Use the 2 mounting screws included with the dishwasher to fasten the 2 clips above the door to the bottom of the counter top.
#14 Remove the installation manual and styrofoam from the tray, and turn the dishwasher on. Inspect for leaks as you run a cycle.
#15 Attach the bottom kick panels
You are done.
If you have any questions, please let me know.
Jan 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Plumbing Logo
567 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
