Question about Electronics - Others
Wiring Diagram Needed: Tote-A-Volt 12v to 110v Inverter
Wiring diagram needed for circa-1980's Tote-A-Volt power inverter.
brainyass
  • 242 Answers
SOURCE: power inverter
Most likely a fuse. Check for a fuse on the inverter itself or one inline with the plug. Usually you can screw off the tip of the plug and replace the fuse inside.
Posted on Oct 24, 2008
  • 21 Answers
SOURCE: Want To Install a 1250 W Power Inverter on a Class A Motorhome
You are definitely on the right track. When you choose your power inverter consider the following: buy the inverter for around 40% more of your anticiapted load. You will need a double pole transfer switch to isolate the inverter from the generator(and visa versa). A simple double throw double pole switch with fuse or breaker protection should do it. You wouldn't necessarily have to isolate the curbside circuit as the double pole double throw switch would simply be switching the power from the existing generator to your new inverter for only the roadside circuit; i.e. you don't need to worry about the curbside power source as it will always be connected to the other branch circuit. Even if your generator or other source came on the system would be protected no matter what the the roadside configuration was set to as only one source of the 2 roadside power sources would be connected at any give time to the roadside circuit. The six dots represent the connecions for the double pole, double throw switch; shown supplying the new inverter to the roadside circuit while the source from the existing generator or inverter is disconnected via this switch from the roadside circuit:
existing * *------* new power inverter; switched to source
Middle 2 dots represent your roadside circuit and represent the "throw arm" of the switch. Safe and simple! If you don't have a voltage meter for your batteries you can purchase one for a few bucks. Just run it across the terminals so you will know battery condition as it is being drained (you may already have this indicator) You can find a transfer switch at an electrical supply place, maybe even Lowes. Make sure you get the switch that will be in a protected enclosre. The enclosurre can be purchased seperately if you can't find the switch/enclosure package together.
Good luck....gary
Posted on Mar 14, 2009
SOURCE: Inverter Question
Where can I download Instruction manual for Fuji FVR-E7S?
Posted on May 23, 2009
Molson02536
  • 3854 Answers
SOURCE: 2008 Dodge Gr. Caravan 115 volt outlet
If there is power to the inverter from the switch, then there is a good chance that the inverter has gone bad. It looks like your van is a year old and the inverter may still be covered under warranty. Good luck and hope this helps. Good Luck and keep me posted, Be glad to help. The other thing to, the inverter it self may have a fuse on it that may have gone bad too, but i am not sure. Start with the warranty first and we can go from there, may be one of the technician can confirm that there is a extra fuse in the inverter.
Posted on Jun 22, 2009
  • 30 Answers
SOURCE: wiring diagram for body mount voltage regulator
http://www.ncttora.com/fsm/1993/index.html
Posted on Aug 08, 2009
Need Help with burned resistors value. Please.
have you repaired the component that burned these resistors out? if not then you cannot replace them as they will just cook again.
Nov 06, 2015 | Cobra CPI 1575 1500 Watt 12 Volt DC to 120...
Belling GHU573 Gas Cooktop
hello,
If the electricity is needed to ignite that cooktop, you can install power inverter from DC to AC. you can use 24 volt battery and inverted to 110V or 220V or depending on the power input of the cooktop..may this help,
melnavz
Apr 08, 2008 | Belling 27 in. GHU573 Gas Cooktop
I have a 24' travelaire 1989 rv. is there a switch to go from electrical hook up to battery operated lights in the camper
there is a power inverter,somewhere near the front of the trailer, RV Basics 12 Volt DC Systems
http://www.winnebagoind.com/resources/manuals/pdfs/Winnebago_Catalog.pdf
Atwood Mobile Products: 574-264-2131
Carefree of Colorado: 800-621-2617
Carriage Carpets (Shaw Flooring): 877-706-3054
CCI Controls: 800-521-5228
Coleman: 316-832-4357
Denso: call Fleetwood 800-322-8216
Dometic: 800-544-4881
Fantastic Vent: 800-521-0298
Generac: 888-GENERAC
Intellitec: 800-251-2408
Kidde Safety Products: 800-880-6788
Kwikee Products: 800-736-9961
Magic Chef 800-688-1120
Magnadyne: 800-638-3600
Norcold 800-543-1219
Onan: 800-888-6626
Power Gear: 800-334-471
Riverpark: 800-442-7717
Suburban: 423-775-2131
Suburban Dynatrail Furnace Manuals
Thetford: 800-521-3032
Velvac: 800-783-8871
Winegard: 800-288-8094
Xantrex (invertor/chargers and control panels )
http://www.rverscorner.com/wiring/index.html
Manuals 1989 older RVing The Midwest Connection
May 14, 2015 | Camper Vehicle Parts & Accessories
Inverter wiring diagram
Better get an electrician to test it if you don't want to damage the inverter.
Dec 09, 2013 | Electronics - Others
Tote-A-volt wiring diagram
where can I get a wiring diagram for a tote a volt 250 A
Apr 18, 2012 | Toys
Resistors burnt out & I cant make out the colour code as they are burnt black. how do I know what resistance they are so I can replace them?
Hello, resistors burnt out, why? If you replace the resistors will the new ones burn out? What you need is a diagram of the unit and you can get the resistance readings from that. But the question still remains, what caused the burn in the first place and have you repaired that?
Feb 20, 2011 | PowerBright Power Bright 3500 Watt Power...
Wiring the 1750 watt eliminator direct to the main panel
DO NOT DO THIS! If I understand you correctly you want to have three ways to have 110 power in your motor home--- (1)Vehicle 12V to inverter to main panel. (2)Generator to main panel. (3)plug the main panel into 110V. If any two of these are connected at the same time and they are both live, somethings going to blow. That's because with AC, the two sources must be synchronized in their cycles very precisely. The utility company connects their power plants together on the grid only with the aid of precise controls. But the really serious problem is the same reason they invented transfers switches for home generators -- if you were connected to (3) and the power went out, and you connected (1) or (2) without disconnecting the dead (3), you will backfeed power to the line outside and you just might kill the lineman who is trying to fix the power outage.
May 20, 2010 | Eliminator MotoMaster Mobile Power...
Electronics - Others Logo
321 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
